[PROJ] Gridshift files
Mladen Mijatovic kapadokija at gmail.com
Mon Sep 25 02:56:03 PDT 2023
Dear,
We are trying to substitute old Proj 5.1 in our project and use new Proj
9.2.1.
When crs is defind with proj4string or wkt, we do not have issue with
transforming coordinates from/to EPSG:4326, except when we are using
grid files e.g.
+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100000
+datum=OSGB36 +units=m +ellps=airy +no_defs
+nadgrids=OSTN15_NTv2_OSGBtoETRS.gsb  +type=crs
PROJCS["ED50 / 3-degree Gauss-Kruger zone 10",
     GEOGCS["ED50",
         DATUM["European_Datum_1950",
             SPHEROID["International 1924",6378388,297],
             EXTENSION["PROJ4_GRIDS","SPED2ETV2.gsb"]],
         PRIMEM["Greenwich",0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.0174532925199433,
             AUTHORITY["EPSG","9122"]],
         AUTHORITY["EPSG","4230"]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",30],
     PARAMETER["scale_factor",1],
     PARAMETER["false_easting",10500000],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AUTHORITY["EPSG","2207"]]
Conversion fails with (HUGE_VAL, HUGE_VAL) coordinates.
If we allow user to define crs by proj4string or wkt and use gridshift
files:
- How proj4string/wkt need to looks like?
- What c++ functions we need to call to get these coordinates converted
without any errors?
Best regards,
Mladen.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230925/8b13584f/attachment.htm>
More information about the PROJ mailing list
