[PROJ] Gridshift files
Erixen Cruz erixen_cruz at earthbrain.com
Mon Sep 25 08:12:12 PDT 2023
Mladen,
See this thread where Even suggests how to use arbitrary grid shift in WKT CRS definition.
https://lists.osgeo.org/pipermail/proj/2019-December/009143.html
You would need to use ABRIDGEDTRANSFORMATION. https://docs.ogc.org/is/18-010r7/18-010r7.html#151
Sincerely, Erixen
From: PROJ <proj-bounces at lists.osgeo.org> on behalf of Mladen Mijatovic via PROJ <proj at lists.osgeo.org>
Sent: Monday, September 25, 2023 5:56 AM
To: proj at lists.osgeo.org <proj at lists.osgeo.org>
Subject: [PROJ] Gridshift files
Dear,
We are trying to substitute old Proj 5.1 in our project and use new Proj
9.2.1.
When crs is defind with proj4string or wkt, we do not have issue with
transforming coordinates from/to EPSG:4326, except when we are using
grid files e.g.
+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100000
+datum=OSGB36 +units=m +ellps=airy +no_defs
+nadgrids=OSTN15_NTv2_OSGBtoETRS.gsb  +type=crs
PROJCS["ED50 / 3-degree Gauss-Kruger zone 10",
     GEOGCS["ED50",
         DATUM["European_Datum_1950",
             SPHEROID["International 1924",6378388,297],
             EXTENSION["PROJ4_GRIDS","SPED2ETV2.gsb"]],
         PRIMEM["Greenwich",0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.0174532925199433,
             AUTHORITY["EPSG","9122"]],
         AUTHORITY["EPSG","4230"]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",30],
     PARAMETER["scale_factor",1],
     PARAMETER["false_easting",10500000],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AUTHORITY["EPSG","2207"]]
Conversion fails with (HUGE_VAL, HUGE_VAL) coordinates.
If we allow user to define crs by proj4string or wkt and use gridshift
files:
- How proj4string/wkt need to looks like?
- What c++ functions we need to call to get these coordinates converted
without any errors?
Best regards,
Mladen.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230925/4510b4f5/attachment.htm>
More information about the PROJ mailing list
