[PROJ] Path of the installed library files of PROJ
Mike Taves mwtoews at gmail.com
Sat Apr 20 14:15:02 PDT 2024
On Sat, 20 Apr 2024 at 11:50, Manoj via PROJ <proj at lists.osgeo.org> wrote:
> Get:1 http://archive.ubuntu.com/ubuntu bionic/universe amd64 proj-bin amd64 4.9.3-2 [32.3 kB]
> checking for proj.h... no
> configure: error: proj.h not found
Ubuntu bionic (18.04) had a really old PROJ 4.9.3 which predated
proj.h. Your options are to use an older libgeotiff (that supported
older PROJ) or install a more modern PROJ version. Or use a more
modern Ubuntu release (probably 20.04 or later).
More information about the PROJ mailing list
