[PROJ] Path of the installed library files of PROJ
Javier Jimenez Shaw j1 at jimenezshaw.com
Sat Apr 20 00:27:12 PDT 2024
I think that to compile you need the package "libproj-dev"
On Sat, 20 Apr 2024 at 01:26, Manoj via PROJ <proj at lists.osgeo.org> wrote:
> I am using g++ (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0 .
> I installed PROJ the following way.
> *$ sudo apt-get install proj-bin*
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> The following NEW packages will be installed:
>   proj-bin
> 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
> Need to get 32.3 kB of archives.
> After this operation, 110 kB of additional disk space will be used.
> Get:1 http://archive.ubuntu.com/ubuntu bionic/universe amd64 proj-bin
> amd64 4.9.3-2 [32.3 kB]
> Fetched 32.3 kB in 1s (30.2 kB/s)
> Selecting previously unselected package proj-bin.
> (Reading database ... 113308 files and directories currently installed.)
> Preparing to unpack .../proj-bin_4.9.3-2_amd64.deb ...
> Unpacking proj-bin (4.9.3-2) ...
> Setting up proj-bin (4.9.3-2) ...
> Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
> How can I find all the .so or .a or header installed ?
>  PROJ is necessary to compile libgeotiff. After the above installation,
> when I am compiling libgeotiff, it cannot find proj.h.
> The command of compilation are shown bellow.
> ./autogen.sh
> ./configure
> The error at the ./confugure was
> checking proj.h usability... no
> checking proj.h presence... no
> checking for proj.h... no
> configure: error: proj.h not found
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240420/708c944e/attachment.htm>
More information about the PROJ mailing list
