[PROJ] Path of the installed library files of PROJ
Manoj member at cessay.org
Fri Apr 19 16:26:21 PDT 2024
I am using g++ (Ubuntu 7.5.0-3ubuntu1~18.04) 7.5.0 .
I installed PROJ the following way.
$ sudo apt-get install proj-bin
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
  proj-bin
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 32.3 kB of archives.
After this operation, 110 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu bionic/universe amd64 proj-bin amd64 4.9.3-2 [32.3 kB]
Fetched 32.3 kB in 1s (30.2 kB/s)
Selecting previously unselected package proj-bin.
(Reading database ... 113308 files and directories currently installed.)
Preparing to unpack .../proj-bin_4.9.3-2_amd64.deb ...
Unpacking proj-bin (4.9.3-2) ...
Setting up proj-bin (4.9.3-2) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
How can I find all the .so or .a or header installed ?
 PROJ is necessary to compile libgeotiff. After the above installation, when I am compiling libgeotiff, it cannot find proj.h.
The command of compilation are shown bellow.
./autogen.sh
./configure
The error at the ./confugure was
checking proj.h usability... no
checking proj.h presence... no
checking for proj.h... no
configure: error: proj.h not found
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240419/e33e9b87/attachment.htm>
More information about the PROJ mailing list
