[PROJ] Is your the geoid model from your country in PROJ?
Even Rouault even.rouault at spatialys.com
Thu Apr 25 13:16:05 PDT 2024
I figured it out. The files_removed.geojson file at
https://github.com/OSGeo/PROJ-data/blob/master/files_removed.geojson
lacked a "version_removed" property, which caused the final
files.geojson file used by projsync to also lack it. And without the
information of the version where a file has been removed, projsync is
conservative and tries to download it since it doesn't know if it might
be useful or not.
I've fixed it in
https://github.com/OSGeo/PROJ-data/commit/5e84d7936226f70442f1360077ffafbf1dea2f9a
, also adding consistency checks so we properly fill metadata when
removing a file
But the bottom line is that we can't just remove a file from the CDN
without breaking projsync of older PROJ versions. We might remove it one
day when we are reasonably confident that nobody longer used a PROJ
version that uses a PROJ.data that is lower than the version where the
file was removed. But that's more a 5+ years horizon to be on the safe side
Le 25/04/2024 à 21:15, Even Rouault via PROJ a écrit :
> I thought I was going to regret it: it broke "projsync --all", at
> least in the context of build GDAL master docker images (it shouldn't
> in theory, but in practice it does, and I don't have time to
> investigate that at the moment).  So I've re-uploaded the file to the
> CDN to the version it was at
> https://github.com/OSGeo/PROJ-data/blob/0531fe9dbc818beb156df75eb5b3a8cac0278ef0/nl_nsgi/nl_nsgi_naptrans2018.tif
> Le 25/04/2024 à 17:14, Even Rouault via PROJ a écrit :
>> I've just removed it from the CDN
>> Le 23/04/2024 à 14:37, Even Rouault via PROJ a écrit :
>>> We use to keep old grids on the CDN even when they are removed in a
>>> later version of PROJ-data. That way people things will still work
>>> for people that use an older PROJ version
>>> Are we completely sure that nobody no longer use
>>> nl_nsgi_naptrans2018.tif ?
>>> Le 23/04/2024 à 13:18, Lesparre, Jochem via PROJ a écrit :
>>>> I noticed that CDN still contains the from VDatum (gtx) to GeoTIFF
>>>> (tif) converted geoid grid
>>>> https://cdn.proj.org/nl_nsgi_naptrans2018.tif for the Netherlands,
>>>> although it isn’t listed in https://cdn.proj.org/nl_nsgi_README.txt
>>>>  I thought I removed that grid from PROJ when I corrected the
>>>> metadata of the other GeoTIFF grids for the Netherlands, but
>>>> apparently I missed something. It doesn’t make sense to distribute
>>>> that grid as GeoTIFF, because it is only usable for PROJ versions
>>>> that did not yet support GeoTIFF.
>>>> Can someone help to get the GeoTIFF version removed completely?
>>>> Jochem
>>>> Disclaimer:
>>>> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd
>>>> voor de geadresseerde(n).
>>>> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
>>>> verstrekking van deze informatie aan derden is niet toegestaan.
>>>> Op al onze producten en diensten zijn onze algemene
>>>> leveringsvoorwaarden van toepassing
>>>> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
>>>> Disclaimer:
>>>> This email and any files transmitted with it are confidential and
>>>> intended solely for the use of the individual or entity to whom
>>>> they are addressed.
>>>> If you are not the intended recipient, you are notified that
>>>> disclosing, copying, distributing or taking any action in reliance
>>>> on the contents of this information is strictly prohibited.
>>>> Our general terms and conditions of delivery apply to all our
>>>> products and services
>>>> [https://www.kadaster.com/general-terms-and-conditions].
>>>> _______________________________________________
>>>> PROJ mailing list
>>>> PROJ at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/proj
>>> http://www.spatialys.com
>>> My software is free, but my time generally not.
>>> PROJ mailing list
>> PROJ mailing list
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240425/a8305f04/attachment.htm>
More information about the PROJ mailing list
