[PROJ] Is your the geoid model from your country in PROJ?
Even Rouault even.rouault at spatialys.com
Thu Apr 25 12:15:17 PDT 2024
I thought I was going to regret it: it broke "projsync --all", at least
in the context of build GDAL master docker images (it shouldn't in
theory, but in practice it does, and I don't have time to investigate
that at the moment).  So I've re-uploaded the file to the CDN to the
version it was at
https://github.com/OSGeo/PROJ-data/blob/0531fe9dbc818beb156df75eb5b3a8cac0278ef0/nl_nsgi/nl_nsgi_naptrans2018.tif
Le 25/04/2024 à 17:14, Even Rouault via PROJ a écrit :
> I've just removed it from the CDN
> Le 23/04/2024 à 14:37, Even Rouault via PROJ a écrit :
>> We use to keep old grids on the CDN even when they are removed in a
>> later version of PROJ-data. That way people things will still work
>> for people that use an older PROJ version
>> Are we completely sure that nobody no longer use
>> nl_nsgi_naptrans2018.tif ?
>> Le 23/04/2024 à 13:18, Lesparre, Jochem via PROJ a écrit :
>>> I noticed that CDN still contains the from VDatum (gtx) to GeoTIFF
>>> (tif) converted geoid grid
>>> https://cdn.proj.org/nl_nsgi_naptrans2018.tif for the Netherlands,
>>> although it isn’t listed in https://cdn.proj.org/nl_nsgi_README.txt
>>>  I thought I removed that grid from PROJ when I corrected the
>>> metadata of the other GeoTIFF grids for the Netherlands, but
>>> apparently I missed something. It doesn’t make sense to distribute
>>> that grid as GeoTIFF, because it is only usable for PROJ versions
>>> that did not yet support GeoTIFF.
>>> Can someone help to get the GeoTIFF version removed completely?
>>> Jochem
>>> Disclaimer:
>>> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd
>>> voor de geadresseerde(n).
>>> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
>>> verstrekking van deze informatie aan derden is niet toegestaan.
>>> Op al onze producten en diensten zijn onze algemene
>>> leveringsvoorwaarden van toepassing
>>> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
>>> Disclaimer:
>>> This email and any files transmitted with it are confidential and
>>> intended solely for the use of the individual or entity to whom they
>>> are addressed.
>>> If you are not the intended recipient, you are notified that
>>> disclosing, copying, distributing or taking any action in reliance
>>> on the contents of this information is strictly prohibited.
>>> Our general terms and conditions of delivery apply to all our
>>> products and services
>>> [https://www.kadaster.com/general-terms-and-conditions].
>>> PROJ mailing list
>>> PROJ at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/proj
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> PROJ mailing list
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240425/8ab3ce00/attachment.htm>
More information about the PROJ mailing list
