[PROJ] Is your the geoid model from your country in PROJ?
Even Rouault even.rouault at spatialys.com
Thu Apr 25 08:14:20 PDT 2024
I've just removed it from the CDN
Le 23/04/2024 à 14:37, Even Rouault via PROJ a écrit :
> We use to keep old grids on the CDN even when they are removed in a
> later version of PROJ-data. That way people things will still work for
> people that use an older PROJ version
> Are we completely sure that nobody no longer use
> nl_nsgi_naptrans2018.tif ?
> Le 23/04/2024 à 13:18, Lesparre, Jochem via PROJ a écrit :
>> I noticed that CDN still contains the from VDatum (gtx) to GeoTIFF
>> (tif) converted geoid grid
>> https://cdn.proj.org/nl_nsgi_naptrans2018.tif for the Netherlands,
>> although it isn’t listed in https://cdn.proj.org/nl_nsgi_README.txt
>>  I thought I removed that grid from PROJ when I corrected the
>> metadata of the other GeoTIFF grids for the Netherlands, but
>> apparently I missed something. It doesn’t make sense to distribute
>> that grid as GeoTIFF, because it is only usable for PROJ versions
>> that did not yet support GeoTIFF.
>> Can someone help to get the GeoTIFF version removed completely?
>> Jochem
>> Disclaimer:
>> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd
>> voor de geadresseerde(n).
>> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
>> verstrekking van deze informatie aan derden is niet toegestaan.
>> Op al onze producten en diensten zijn onze algemene
>> leveringsvoorwaarden van toepassing
>> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
>> Disclaimer:
>> This email and any files transmitted with it are confidential and
>> intended solely for the use of the individual or entity to whom they
>> are addressed.
>> If you are not the intended recipient, you are notified that
>> disclosing, copying, distributing or taking any action in reliance on
>> the contents of this information is strictly prohibited.
>> Our general terms and conditions of delivery apply to all our
>> products and services
>> [https://www.kadaster.com/general-terms-and-conditions].
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240425/69cd2234/attachment.htm>
More information about the PROJ mailing list
