[PROJ] Is your the geoid model from your country in PROJ?
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Thu Apr 25 07:51:57 PDT 2024
> Are we completely sure that nobody no longer use nl_nsgi_naptrans2018.tif ?
No, but I think there has never been a reason to use nl_nsgi_naptrans2018.tif. The only difference between nl_nsgi_naptrans2018.tif and nl_nsgi_nlgeo2018.tif is the interpolation CRS. In theory somebody could use nl_nsgi_naptrans2018.tif in a PROJ pipeline, e.g.:
cct +proj=pipeline
+step +proj=hgridshift +inv +grids=nl_nsgi_rdtrans2018.tif
+step +proj=vgridshift +grids=nl_nsgi_naptrans2018.tif
+step +proj=sterea +lat_0=52.156160556 +lon_0=5.387638889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
However, we never published such a PROJ pipeline, since the need for a interpolation CRS other than ETRS89 could always be avoided in a pipeline, e.g.:
cct +proj=pipeline
+step +proj=vgridshift +grids=nl_nsgi_nlgeo2018.tif
The only reason we created nl_nsgi_naptrans2018.gtx is that PROJ4-style strings in older PROJ versions (that did not yet support GeoTIFF) needed it:
+proj=sterea +lat_0=52.156160556 +lon_0=5.387638889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +nadgrids=nl_nsgi_rdtrans2018.gsb +wktext +geoidgrids=nl_nsgi_naptrans2018.gtx +no_defs
With PROJ 6 and newer this grid is no longer needed for PROJ4-style strings either:
+proj=sterea +lat_0=52.156160556 +lon_0=5.387638889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +nadgrids=nl_nsgi_rdtrans2018.tif +geoidgrids=nl_nsgi_nlgeo2018.tif +geoid_crs=WGS84 +type=crs
So the conversion from VDatum (.gtx) to GeoTIFF (.tif) was never needed for nl_nsgi_naptrans2018.gtx, but should we keep it now is there?
Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240425/5b89ec19/attachment-0001.htm>
More information about the PROJ mailing list
