[PROJ] Is your the geoid model from your country in PROJ?
Even Rouault even.rouault at spatialys.com
Tue Apr 23 05:37:43 PDT 2024
We use to keep old grids on the CDN even when they are removed in a
later version of PROJ-data. That way people things will still work for
people that use an older PROJ version
Are we completely sure that nobody no longer use nl_nsgi_naptrans2018.tif ?
Le 23/04/2024 à 13:18, Lesparre, Jochem via PROJ a écrit :
> I noticed that CDN still contains the from VDatum (gtx) to GeoTIFF
> (tif) converted geoid grid
> https://cdn.proj.org/nl_nsgi_naptrans2018.tif for the Netherlands,
> although it isn’t listed in https://cdn.proj.org/nl_nsgi_README.txt  I
> thought I removed that grid from PROJ when I corrected the metadata of
> the other GeoTIFF grids for the Netherlands, but apparently I missed
> something. It doesn’t make sense to distribute that grid as GeoTIFF,
> because it is only usable for PROJ versions that did not yet support
> GeoTIFF.
> Can someone help to get the GeoTIFF version removed completely?
> Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor
> de geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene
> leveringsvoorwaarden van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed.
> If you are not the intended recipient, you are notified that
> disclosing, copying, distributing or taking any action in reliance on
> the contents of this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products
> and services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240423/afe7d7ce/attachment.htm>
More information about the PROJ mailing list
