[PROJ] stripVerticalComponent vs demoteTo2D
Even Rouault even.rouault at spatialys.com
Fri Apr 26 08:02:14 PDT 2024
Javier,
Embarrassingly, probably just the result of me having forgotten
stripVerticalComponent() existed when demoteTo2D() was needed. I've just
issued https://github.com/OSGeo/PROJ/pull/4127
"CRS::stripVerticalComponent(): Redirect it to demoteTo2D(std::string(),
nullptr)"
Even
Le 26/04/2024 à 16:28, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> In the class CRS I see two methods: stripVerticalComponent vs demoteTo2D
> The implementations are different. But, is there any practical
> difference in the result?
> (Except that demoteTo2D is looking in the database in case there is an
> equivalent definition there to assign an id, and that you can change
> the name)
> Thanks.
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240426/ff56a4c9/attachment.htm>
More information about the PROJ mailing list
