[PROJ] PROJ 9.4.0RC1 & PROJ-data 1.17RC1
Sebastiaan Couwenberg sebastic at xs4all.nl
Wed Feb 28 22:13:54 PST 2024
On 2/29/24 6:27 AM, Kristian Evers via PROJ wrote:
>> `tar tzvf proj-data-1.17RC2.tar.gz` does work on Mac, but it ignores the ._ files, they are also not present after unpacking the archive.
> That explains why I couldn’t see the same files as you guys. I did run that exact command, as well as unpacking the files using two separate tools. Based on that I felt quite comfortable no bad files were in RC2 and RC3. Sneaky stuff.
> Thanks for helping clear this up. I am not sure how to avoid this in the future. For now I think the best thing I can do is to delete my local copy of the PROJ-data repo and make a new clone. Hopefully that leaves me with a set of files without any extra MacOS attributes. That method doesn’t feel particularly foolproof though, so I think it is time to look into automating the release process. For another project I am working on, I have been looking into saving artifacts from GitHub Action runs and publishing them as releases on GitHub. I don’t think that would be too difficult to setup for PROJ-data.
Removing the extended attributes from your working copy should suffice.
Adding `xattr -c` to the release procedure may help.
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
More information about the PROJ mailing list
