[PROJ] Grid shift files
Mladen Mijatovic kapadokija at gmail.com
Wed Jan 31 05:06:58 PST 2024
Many thanks to you all!
сре, 31. јан 2024. у 08:42 Javier Jimenez Shaw <j1 at jimenezshaw.com> је
написао/ла:
> More info:
> https://proj.org/en/9.3/resource_files.html#where-are-proj-resource-files-looked-for
> On Wed, 31 Jan 2024, 07:35 Luí­s Moreira de Sousa, <
> luis.de.sousa at protonmail.ch> wrote:
>> Yes it is. Something like:
>> PROJ_DATA=/path/to/custom.file;/path/to/proj.db
>> Regards.
>> Luís Moreira de Sousa
>> Sent from Proton Mail mobile
>> -------- Original Message --------
>> On 31 Jan 2024, 01:36, Mladen Mijatovic via PROJ < proj at lists.osgeo.org>
>> wrote:
>> Yes, I am thinking about the location on the hard drive, on a local
>> machine where the app is running.
>> Is it mandatory to place db file there too? I would like to keep them
>> separtely, not to allow user to mess with the db and ini files.
>> On Wed, Jan 31, 2024, 00:18 Javier Jimenez Shaw <j1 at jimenezshaw.com>
>> wrote:
>>> Do you mean a custom location in your hard drive?
>>> Then using PROJ_DATA environment variable is an easy solution. See that
>>> is like a "PATH", separating folders with ":" or ";" depending on your OS,
>>> and it should include also the folder that contains "proj.db".
>>> On Tue, 30 Jan 2024 at 19:15, Mladen Mijatovic via PROJ <
>>> proj at lists.osgeo.org> wrote:
>>>> Dear all,
>>>> My application is using proj 9.3.1. I would like to enable the user to
>>>> set a custom location for his own grid files used for horizontal
>>>> transformations. Is there a way to make proj using a custom location for
>>>> search of these files?
>>>> Best regards,
>>>> Mladen.
>>>> _______________________________________________
>>>> PROJ mailing list
>>>> PROJ at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240131/7c6f9aff/attachment-0001.htm>
More information about the PROJ mailing list
