[PROJ] Grid shift files
Mladen Mijatovic kapadokija at gmail.com
Wed Jan 31 05:07:29 PST 2024
Is there another way? Just to know what are the alternatives.
сре, 31. јан 2024. у 14:06 Mladen Mijatovic <kapadokija at gmail.com> је
написао/ла:
> Many thanks to you all!
> сре, 31. јан 2024. у 08:42 Javier Jimenez Shaw <j1 at jimenezshaw.com> је
> написао/ла:
>> More info:
>> https://proj.org/en/9.3/resource_files.html#where-are-proj-resource-files-looked-for
>> On Wed, 31 Jan 2024, 07:35 Luí­s Moreira de Sousa, <
>> luis.de.sousa at protonmail.ch> wrote:
>>> Yes it is. Something like:
>>> PROJ_DATA=/path/to/custom.file;/path/to/proj.db
>>> Regards.
>>> Luís Moreira de Sousa
>>> Sent from Proton Mail mobile
>>> -------- Original Message --------
>>> On 31 Jan 2024, 01:36, Mladen Mijatovic via PROJ < proj at lists.osgeo.org>
>>> wrote:
>>> Yes, I am thinking about the location on the hard drive, on a local
>>> machine where the app is running.
>>> Is it mandatory to place db file there too? I would like to keep them
>>> separtely, not to allow user to mess with the db and ini files.
>>> On Wed, Jan 31, 2024, 00:18 Javier Jimenez Shaw <j1 at jimenezshaw.com>
>>> wrote:
>>>> Do you mean a custom location in your hard drive?
>>>> Then using PROJ_DATA environment variable is an easy solution. See that
>>>> is like a "PATH", separating folders with ":" or ";" depending on your OS,
>>>> and it should include also the folder that contains "proj.db".
>>>> On Tue, 30 Jan 2024 at 19:15, Mladen Mijatovic via PROJ <
>>>> proj at lists.osgeo.org> wrote:
>>>>> Dear all,
>>>>> My application is using proj 9.3.1. I would like to enable the user to
>>>>> set a custom location for his own grid files used for horizontal
>>>>> transformations. Is there a way to make proj using a custom location for
>>>>> search of these files?
>>>>> Best regards,
>>>>> Mladen.
>>>>> _______________________________________________
>>>>> PROJ mailing list
>>>>> PROJ at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240131/4944993f/attachment.htm>
More information about the PROJ mailing list
