[PROJ] What is the syntax for a vertical datum change?
Even Rouault even.rouault at spatialys.com
Fri Mar 15 00:42:27 PDT 2024
Le 15/03/2024 à 06:27, Ulises Ibarra via PROJ a écrit :
> Hello:
> I am trying to change the vertical datum of a LIDAR LAS file. But
> first I must understand the syntax of proj, but I can't understand it.
> If I use the following expression:
> echo 747194.732 2307402.892 2037.133 | proj +proj=vgridshift
> +grids=C:/clouds/geoids/GGM10_GEO.gtx
"proj" is a legacy tool only for 2D cartographic projections. You want
to use cct instead: https://proj.org/en/9.4/apps/cct.html
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240315/df98eb2d/attachment.htm>
More information about the PROJ mailing list
