[PROJ] What is the syntax for a vertical datum change?
Even Rouault even.rouault at spatialys.com
Fri Mar 22 12:30:20 PDT 2024
Le 22/03/2024 à 20:24, Ulises Ibarra via PROJ a écrit :
> Hello:
> Continuing with the attempt to change from ellipsoidal heights to
> orthometric heights. I executed the instruction:
> echo 578174.247 3593725.312 1295.083 2010.0 | cct +proj=pipeline +step
> +inv +proj=utm +zone=11 +ellps=WGS84 +step +proj=utm +zone=11
> +ellps=WGS84 +proj=vgridshift +grids=/nubes/geoides/GGM10_GEO.gtx
>   578174.2470   3593725.3120     1295.0830     2010.0000
Steps 2 and 3 should be inverted, and here's a missing +step keyword. It
should rather be something like
+proj=pipeline +step +inv +proj=utm +zone=11 +ellps=WGS84 +step
+proj=vgridshift +grids=/nubes/geoides/GGM10_GEO.gtx +step +proj=utm
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240322/66ca817f/attachment.htm>
More information about the PROJ mailing list
