[PROJ] What is the syntax for a vertical datum change?
Ulises Ibarra ulisesmartinibarra at gmail.com
Fri Mar 22 12:57:21 PDT 2024
Thank you very much Even, it seems to work perfectly:
echo 578174.247 3593725.312 1295.083 2010.0 | cct +proj=pipeline +step +inv
+proj=utm +zone=11 +ellps=WGS84 +step +proj=vgridshift
+grids=/nubes/geoides/GGM10_GEO.gtx +step +proj=utm +zone=11 +ellps=WGS84
  578174.2470   3593725.3120     1329.6219     2010.0000
Ulises
El vie, 22 mar 2024 a las 13:30, Even Rouault (<even.rouault at spatialys.com>)
escribió:
> Le 22/03/2024 à 20:24, Ulises Ibarra via PROJ a écrit :
> Hello:
> Continuing with the attempt to change from ellipsoidal heights to
> orthometric heights. I executed the instruction:
> +inv +proj=utm +zone=11 +ellps=WGS84 +step +proj=utm +zone=11 +ellps=WGS84
> +proj=vgridshift +grids=/nubes/geoides/GGM10_GEO.gtx
>   578174.2470   3593725.3120     1295.0830     2010.0000
> Steps 2 and 3 should be inverted, and here's a missing +step keyword. It
> should rather be something like
> +proj=pipeline +step +inv +proj=utm +zone=11 +ellps=WGS84 +step
> +proj=vgridshift +grids=/nubes/geoides/GGM10_GEO.gtx +step +proj=utm
> Even
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240322/a315a595/attachment.htm>
More information about the PROJ mailing list
