[PROJ] Unexpected CRS Validation Error
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Mar 27 23:55:29 PDT 2024
The definition of the CRS is in the .prj file of the shapefile, as plain
text. In this case:
GEOGCS["WGS84(DD)", DATUM["WGS84", SPHEROID["WGS84", 6378137.0,
298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree",
0.017453292519943295], AXIS["Geodetic longitude", EAST], AXIS["Geodetic
latitude", NORTH], AUTHORITY["EPSG","4326"]]
That formal definition of EPSG:4326 is northing-easting, and that WKT is
saying easting-northing. So there is an inconsistency in the definition of
the system, because at the end it says that the authority is EPSG:4326
You can either remove the axis or the final authority (the error message
says that proj is removing the authority ;)
The axis order I think is not used to read the coordinates in a shp file,
so the outputs should be the same.
The actual definition of EPSG:4326 in ESRI (from
https://spatialreference.org/ref/epsg/4326/esriwkt.txt)
GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
In case anybody needs an equivalent to EPSG:4326 but easting-northing in
other context, there is https://spatialreference.org/ref/ogc/CRS84/
Cheers,
Javier
On Thu, 28 Mar 2024 at 03:06, Simon Eves via PROJ <proj at lists.osgeo.org>
wrote:
> When trying to import this Shapefile bundle into our system with GDAL...
> https://drive.google.com/file/d/13Mwhnugcy8HrnGlc81gyroxnp9s15Skt/view?usp=sharing
> ...we get an *OGRERR_CORRUPT_DATA* from *OGRSpatialReference::Validate()*
> on the SR obtained from the first feature.
> Tracing through the GDAL and PROJ code, this appears to be because the
> PROJ import of that CRS results in the following WKT Import Error from
> PROJ...
> *Coordinate system of GeographicCRS in the WKT definition is different
> from the one of the authority. Unsetting the identifier to avoid confusion*
> ...and any WKT Import Error makes GDAL report that error code.
> The PROJ code throws this in *WKTParser::Private::buildGeodeticCRS*
> (io.cpp:3229 in 9.3.0) which is old code (although the second branch which
> can throw the same error was seemingly added between 8.2 and 9.3 in
> https://github.com/OSGeo/PROJ/pull/3274 ...but it's the first branch
> that's triggering in this case).
> *ogrinfo* on the Shapefile reports no errors or warnings, although it
> does report a CRS ID of 9001 even though it reports WGS84 elsewhere in the
> CRS block.
> I was able to trivially *ogr2ogr* it to GeoJSON, also with no errors or
> warnings, and that imports with no issue.
> Is there an actual problem (a bad file) here, or are we doing something
> wrong?
> Thanks, as ever, in advance.
> Simon Eves
> Senior Rendering Engineer
> +1 (415) 902-1996
> simon.eves at heavy.ai
> <http://www.heavy.ai>
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240328/c0de0704/attachment.htm>
More information about the PROJ mailing list
