[pycsw-devel] AttributeError: 'module' object has no attribute 'get_config'
Junichi Nagai Nagai.Junichi at imslab.co.jp
Thu Jul 21 23:45:58 EDT 2011
Dear Tom Kralidis,
I'm Junichi Nagai.
Thank you for updating configuration parsing.
It works about creating the necessary tables and values for the repository.
But I got another problem.
(different from [pycsw-devel] About "GetRecords-filter-bbox Request")
I imported all *.xml records(pycsw samples) by using
"./sbin/load_records.py".
(1)
I sent "GetRecords-all Request" to my pycsw
server(http://localhost/cgi-bin/pycsw/csw.py) at
"http://localhost/tester/index.html".
I got collect response from my pycsw
No problem.
(2)
I sent "GetRecords-Element Request" to my pycsw server.
I got collect response.
No problem.
(3)
I sent "GetRecords-filter-bbox Request" to my pycsw server.
I couldn't got collect response.
I got below error.
 <ows:Exception locator="constraint" exceptionCode="InvalidParameterValue">
    <ows:ExceptionText>Invalid query: (InternalError) plpython: function
"query_spatial" failed
DETAIL:  &lt;type 'exceptions.ImportError'&gt;: No module named lxml
 "SELECT records.identifier AS records_identifier, records.typename AS
records_typename, records.schema AS records_schema, records.bbox AS
records_bbox, records.xml AS records_xml, records.source AS records_source,
records.insert_date AS records_insert_date \nFROM records \nWHERE
records.typename IN (%(typename_1)s) AND query_spatial(bbox,'POLYGON((-5.00
47.00, -5.00 55.00, 20.00 55.00, 20.00 47.00, -5.00 47.00))','bbox','false')
= 'true'" {'typename_1': 'csw:Record'}</ows:ExceptionText>
  </ows:Exception>
I have installed "lxml version 2.3".
It works for (1),(2).
I think that "FUNCTION_QUERY_SPATIAL" of database don't know where "lxml"
is.
Could you tell me what's wrong?
I use below.
  pycsw:version1.0.0(http://sourceforge.net/projects/pycsw/files/1.0.0/)
  OS:Windows XP
  Python:Version 2.7
  Database:postgres8.3
  lxml:version 2.3
More information about the Pycsw-devel mailing list
