[Pywps-dev] [ GSOC 2014 ] Database output storage - PostGIS and SQLite
Mendes de Jesus, Jorge jorge.mendesdejesus at wur.nl
Sun Mar 2 07:01:11 PST 2014
Hi to all
1) Python versions
If I'm not mistaken we agreed on using python2.7 and python3.3 as minimal requirements. Therefore all code has to work on both interpreters.
As an extra pypy should be supported (latest version seems to be working fine with PyWPS)
2) werkzeug error
I've upgraded my werkzeug package to your version and tried to recreate the tox (tox -e ) but hit some other error with module import
py27 runtests: commands[0] | python tests/__init__.py
  File "tests/__init__.py", line 4, in <module>
    import parse
  File "/home/jesus/src/pywps4/pywps-4/tests/parse/__init__.py", line 11, in <module>
    from pywps import request
  File "/home/jesus/src/pywps4/pywps-4/pywps/__init__.py", line 24, in <module>
    from pywps.app import (
  File "/home/jesus/src/pywps4/pywps-4/pywps/app.py", line 283, in <module>
    class ComplexOutput(inout.ComplexOutput):
AttributeError: 'module' object has no attribute 'ComplexOutput'
And then on py33
py33 runtests: commands[0] | python tests/__init__.py
    import parse
  File "/home/jesus/src/pywps4/pywps-4/pywps/app.py", line 15, in <module>
    from pywps import inout
ImportError: bad magic number in 'pywps.inout': b'\x03\xf3\r\n'
@Naveen:
I can't replicate your problem :(, also on Wednesday we merged one branch into the master (try to use this code), the above error messages were probably caused by the merge.
Today I dont have much time, but either me or Jachym will give a look at the problems on the master code.
Cheers
Jorge
________________________________________
Sent: 02 March 2014 05:37
To: Jachym Cepicky
Cc: pywps-dev at lists.osgeo.org; Mendes de Jesus, Jorge
Subject: Re: [ GSOC 2014 ] Database output storage - PostGIS and SQLite
Sorry, I forgot to mention that,
I have Ubuntu 12.04 (Linux) , 64 bit machine.
On Sat, Mar 1, 2014 at 8:53 PM, Jachym Cepicky <jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>> wrote:
On which platform are you operating? Linux? Which distro?
I have
>>> werkzeug.__version__
'0.9.4'
What about you?
Jachym
On Sat, Mar 01, 2014 at 11:00:02PM +0530, Naveen Panwar wrote:
>    Hello sir,
>    As you suggested I have forked github (/jachym/pywps-4). Run it on my
>    machine I got following output as a result of "tox" command.
>    do I really need to have python3.3 ?? as it already successfully build
>    with python2.7.
>    last 10 lines --
>    Test GML validator ... ok
>    Ran 58 tests in 16.374s
>    OK (skipped=21)
>    py33 create: /home/naveen/pywps-4/.tox/py33
>    ERROR: InterpreterNotFound: python3.3
>    _______________________________________________________________________________
>    summary
>    ________________________________________________________________________________
>    py27: commands succeeded
>    ERROR:   py33: InterpreterNotFound: python3.3
>    Also when I run "python tests/__init__.py", I got following error.
>    File "__init__.py", line 4, in <module>
>        import parse
>      File "/home/naveen/pywps-4/tests/parse/__init__.py", line 11, in
>    <module>
>      File "/home/naveen/pywps-4/pywps/__init__.py", line 24, in <module>
>      File "/home/naveen/pywps-4/pywps/app.py", line 8, in <module>
>        from pywps.exceptions import InvalidParameterValue, \
>      File "/home/naveen/pywps-4/pywps/exceptions.py", line 10, in <module>
>        from werkzeug._compat import text_type
>    ImportError: No module named _compat
>    Could you please suggest anything about the error ?
>    On Thu, Feb 27, 2014 at 2:21 AM, Jachym Cepicky
>    <[1]jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>> wrote:
>      Hi,
>      sorry for late answer - we were waiting till OSGeo is accepted as
>      mentoring
>      organisation.
>      You can start working any time (join the mailing list -
>      [2]pywps-dev at lists.osgeo.org<mailto:pywps-dev at lists.osgeo.org>), fork github (/jachym/pywps-4), join
>      hangout
>      ([3]http://doodle.com/4wm7umivegm5sr4x),
>      or wait till the 10 March: 19:00 UTC, when the application period opens
>      (according to
>      [4]https://www.google-melange.com/gsoc/events/google/gsoc2014) and
>      proceed the standard way
>      Expect pywps-4 to be one big building place right now, we are shifting
>      big parts
>      of code from one side to another, some of the ideas are just in our
>      heads right
>      now, but we are approaching.
>      cheers
>      Jachym
>      On Mon, Feb 17, 2014 at 07:16:50PM +0530, Naveen Panwar wrote:
>      >    Hello Sir,
>      >    I am currently pursuing my master in Spatial Informatics at�[1]Lab
>      for
>      >    Spatial Informatics.
>      >    I am interested in the development of the project "Database output
>      >    storage" both in PostGIS and Sqlite. Because I have worked before,
>      both in
>      >    Python and Spatial Databases.�
>      >    And these project provided me the good�opportunity of development
>      in
>      >    python with my research areas.�
>      >    My programming skills -�C, C++, Python, Java.
>      >    Also I am families with open source development.
>      >    I build "VRGeo SMS tool" which is a open source crowd sourcing
>      platform to
>      >    collect the data from user using SMS. In this project we used
>      PostgreSQL
>      >    as a Database storage.
>      >    Please let me know how can I start working for the same. As the
>      students
>      >    application for GSOC-2014 will start on March 10, 2014.
>      >    Regards,
>      >    Naveen Panwar
>      >    IIIT-Hyderabad, India.
>      >    +91-9030736015
>      >    [2][5]http://lsi.iiit.ac.in/naveen.panwar
>      > References
>      >    Visible links
>      >    1. [6]http://lsi.iiit.ac.in/
>      >    2. [7]http://lsi.iiit.ac.in/naveen.panwar
>      Jachym Cepicky
>      URL: [8]http://les-ejk.cz
>      e-mail: jachym.cepicky at gmail com
>      PGP: [9]http://les-ejk.cz/pgp/JachymCepicky.pgp
>      @jachymc
>    Regards,
>    Naveen Panwar
>    Senior Undergraduate Student
>    [10]http://lsi.iiit.ac.in/naveen.panwar
> References
>    Visible links
>    1. mailto:jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>
>    2. mailto:pywps-dev at lists.osgeo.org<mailto:pywps-dev at lists.osgeo.org>
>    3. http://doodle.com/4wm7umivegm5sr4x
>    4. https://www.google-melange.com/gsoc/events/google/gsoc2014
>    5. http://lsi.iiit.ac.in/naveen.panwar
>    6. http://lsi.iiit.ac.in/
>    7. http://lsi.iiit.ac.in/naveen.panwar
>    8. http://les-ejk.cz/
>    9. http://les-ejk.cz/pgp/JachymCepicky.pgp
>   10. http://lsi.iiit.ac.in/naveen.panwar
Jachym Cepicky
URL: http://les-ejk.cz
PGP: http://les-ejk.cz/pgp/JachymCepicky.pgp
@jachymc
Regards,
Naveen Panwar
More information about the pywps-dev mailing list
