[Pywps-dev] [ GSOC 2014 ] Database output storage - PostGIS and SQLite
Jachym Cepicky jachym.cepicky at gmail.com
Mon Mar 3 00:15:50 PST 2014
regarding the complexouput error, I use
export PYTHONPATH=./tests/:./:./pywps:
before I call 'tox', python3 seems then to work
regarding werkzeug: did you try to run in from command line?
python
>>> from werkzeug.__compat import text_type
and see, if it works?
J
> On Sun, Mar 02, 2014 at 03:01:11PM +0000, Mendes de Jesus, Jorge wrote:
> Hi to all
> 1) Python versions
> If I'm not mistaken we agreed on using python2.7 and python3.3 as minimal requirements. Therefore all code has to work on both interpreters.
> As an extra pypy should be supported (latest version seems to be working fine with PyWPS)
> 2) werkzeug error
> I've upgraded my werkzeug package to your version and tried to recreate the tox (tox -e ) but hit some other error with module import
> py27 runtests: commands[0] | python tests/__init__.py
> Traceback (most recent call last):
>   File "tests/__init__.py", line 4, in <module>
>     import parse
>   File "/home/jesus/src/pywps4/pywps-4/tests/parse/__init__.py", line 11, in <module>
>     from pywps import request
>   File "/home/jesus/src/pywps4/pywps-4/pywps/__init__.py", line 24, in <module>
>     from pywps.app import (
>   File "/home/jesus/src/pywps4/pywps-4/pywps/app.py", line 283, in <module>
>     class ComplexOutput(inout.ComplexOutput):
> AttributeError: 'module' object has no attribute 'ComplexOutput'
> And then on py33
> py33 runtests: commands[0] | python tests/__init__.py
>     import parse
>   File "/home/jesus/src/pywps4/pywps-4/pywps/app.py", line 15, in <module>
>     from pywps import inout
> ImportError: bad magic number in 'pywps.inout': b'\x03\xf3\r\n'
> @Naveen:
> I can't replicate your problem :(, also on Wednesday we merged one branch into the master (try to use this code), the above error messages were probably caused by the merge.
> Today I dont have much time, but either me or Jachym will give a look at the problems on the master code.
> Cheers
> Jorge
> ________________________________________
> From: Naveen Panwar [panwarn09 at gmail.com]
> Sent: 02 March 2014 05:37
> To: Jachym Cepicky
> Cc: pywps-dev at lists.osgeo.org; Mendes de Jesus, Jorge
> Subject: Re: [ GSOC 2014 ] Database output storage - PostGIS and SQLite
> Sorry, I forgot to mention that,
> I have Ubuntu 12.04 (Linux) , 64 bit machine.
> On Sat, Mar 1, 2014 at 8:53 PM, Jachym Cepicky <jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>> wrote:
> On which platform are you operating? Linux? Which distro?
> I have
> >>> werkzeug.__version__
> '0.9.4'
> What about you?
> Jachym
> On Sat, Mar 01, 2014 at 11:00:02PM +0530, Naveen Panwar wrote:
> >    Hello sir,
> >    As you suggested I have forked github (/jachym/pywps-4). Run it on my
> >    machine I got following output as a result of "tox" command.
> >    do I really need to have python3.3 ?? as it already successfully build
> >    with python2.7.
> >    last 10 lines --
> >    Test GML validator ... ok
> >    Ran 58 tests in 16.374s
> >    OK (skipped=21)
> >    py33 create: /home/naveen/pywps-4/.tox/py33
> >    ERROR: InterpreterNotFound: python3.3
> >    _______________________________________________________________________________
> >    summary
> >    ________________________________________________________________________________
> >    py27: commands succeeded
> >    ERROR:   py33: InterpreterNotFound: python3.3
> >    Also when I run "python tests/__init__.py", I got following error.
> >    File "__init__.py", line 4, in <module>
> >        import parse
> >      File "/home/naveen/pywps-4/tests/parse/__init__.py", line 11, in
> >    <module>
> >      File "/home/naveen/pywps-4/pywps/__init__.py", line 24, in <module>
> >      File "/home/naveen/pywps-4/pywps/app.py", line 8, in <module>
> >        from pywps.exceptions import InvalidParameterValue, \
> >      File "/home/naveen/pywps-4/pywps/exceptions.py", line 10, in <module>
> >        from werkzeug._compat import text_type
> >    ImportError: No module named _compat
> >    Could you please suggest anything about the error ?
> >    On Thu, Feb 27, 2014 at 2:21 AM, Jachym Cepicky
> >    <[1]jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>> wrote:
> >      Hi,
> >      sorry for late answer - we were waiting till OSGeo is accepted as
> >      mentoring
> >      organisation.
> >      You can start working any time (join the mailing list -
> >      [2]pywps-dev at lists.osgeo.org<mailto:pywps-dev at lists.osgeo.org>), fork github (/jachym/pywps-4), join
> >      hangout
> >      ([3]http://doodle.com/4wm7umivegm5sr4x),
> >      or wait till the 10 March: 19:00 UTC, when the application period opens
> >      (according to
> >      [4]https://www.google-melange.com/gsoc/events/google/gsoc2014) and
> >      proceed the standard way
> >      Expect pywps-4 to be one big building place right now, we are shifting
> >      big parts
> >      of code from one side to another, some of the ideas are just in our
> >      heads right
> >      now, but we are approaching.
> >      cheers
> >      Jachym
> >      On Mon, Feb 17, 2014 at 07:16:50PM +0530, Naveen Panwar wrote:
> >      >    Hello Sir,
> >      >    I am currently pursuing my master in Spatial Informatics at�[1]Lab
> >      for
> >      >    Spatial Informatics.
> >      >    I am interested in the development of the project "Database output
> >      >    storage" both in PostGIS and Sqlite. Because I have worked before,
> >      both in
> >      >    Python and Spatial Databases.�
> >      >    And these project provided me the good�opportunity of development
> >      in
> >      >    python with my research areas.�
> >      >    My programming skills -�C, C++, Python, Java.
> >      >    Also I am families with open source development.
> >      >    I build "VRGeo SMS tool" which is a open source crowd sourcing
> >      platform to
> >      >    collect the data from user using SMS. In this project we used
> >      PostgreSQL
> >      >    as a Database storage.
> >      >    Please let me know how can I start working for the same. As the
> >      students
> >      >    application for GSOC-2014 will start on March 10, 2014.
> >      >    Regards,
> >      >    Naveen Panwar
> >      >    IIIT-Hyderabad, India.
> >      >    +91-9030736015
> >      >    [2][5]http://lsi.iiit.ac.in/naveen.panwar
> >      > References
> >      >    Visible links
> >      >    1. [6]http://lsi.iiit.ac.in/
> >      >    2. [7]http://lsi.iiit.ac.in/naveen.panwar
> >      Jachym Cepicky
> >      URL: [8]http://les-ejk.cz
> >      e-mail: jachym.cepicky at gmail com
> >      PGP: [9]http://les-ejk.cz/pgp/JachymCepicky.pgp
> >      @jachymc
> >    Regards,
> >    Naveen Panwar
> >    Senior Undergraduate Student
> >    [10]http://lsi.iiit.ac.in/naveen.panwar
> > References
> >    Visible links
> >    1. mailto:jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>
> >    2. mailto:pywps-dev at lists.osgeo.org<mailto:pywps-dev at lists.osgeo.org>
> >    3. http://doodle.com/4wm7umivegm5sr4x
> >    4. https://www.google-melange.com/gsoc/events/google/gsoc2014
> >    5. http://lsi.iiit.ac.in/naveen.panwar
> >    6. http://lsi.iiit.ac.in/
> >    7. http://lsi.iiit.ac.in/naveen.panwar
> >    8. http://les-ejk.cz/
> >    9. http://les-ejk.cz/pgp/JachymCepicky.pgp
> >   10. http://lsi.iiit.ac.in/naveen.panwar
> Jachym Cepicky
> URL: http://les-ejk.cz
> PGP: http://les-ejk.cz/pgp/JachymCepicky.pgp
> @jachymc
> Regards,
> Naveen Panwar
Jachym Cepicky
@jachymc
More information about the pywps-dev mailing list
