[Pywps-dev] [ GSOC 2014 ] Database output storage - PostGIS and SQLite
Naveen Panwar panwarn09 at gmail.com
Mon Mar 3 02:11:51 PST 2014
I have set the PYTHONPATH.
following is the output of two command which you asked me to run.
>>> *werkzeug.__version__*
'0.9.4'
>>> *from werkzeug._compat import text_type*
  File "<stdin>", line 1, in <module>
ImportError: No module named _compat
On Mon, Mar 3, 2014 at 1:45 PM, Jachym Cepicky <jachym.cepicky at gmail.com>wrote:
> Hi,
> regarding the complexouput error, I use
> export PYTHONPATH=./tests/:./:./pywps:
> before I call 'tox', python3 seems then to work
> regarding werkzeug: did you try to run in from command line?
> python
> >>> from werkzeug.__compat import text_type
> and see, if it works?
> J
> > On Sun, Mar 02, 2014 at 03:01:11PM +0000, Mendes de Jesus, Jorge wrote:
> > Hi to all
> > 1) Python versions
> > If I'm not mistaken we agreed on using python2.7 and python3.3 as
> minimal requirements. Therefore all code has to work on both interpreters.
> > As an extra pypy should be supported (latest version seems to be working
> fine with PyWPS)
> > 2) werkzeug error
> > I've upgraded my werkzeug package to your version and tried to recreate
> the tox (tox -e ) but hit some other error with module import
> > py27 runtests: commands[0] | python tests/__init__.py
> >   File "tests/__init__.py", line 4, in <module>
> >     import parse
> >   File "/home/jesus/src/pywps4/pywps-4/tests/parse/__init__.py", line
> 11, in <module>
> >     from pywps import request
> >   File "/home/jesus/src/pywps4/pywps-4/pywps/__init__.py", line 24, in
> <module>
> >     from pywps.app import (
> >   File "/home/jesus/src/pywps4/pywps-4/pywps/app.py", line 283, in
> <module>
> >     class ComplexOutput(inout.ComplexOutput):
> > AttributeError: 'module' object has no attribute 'ComplexOutput'
> > And then on py33
> > py33 runtests: commands[0] | python tests/__init__.py
> >     import parse
> 11, in <module>
> <module>
> >   File "/home/jesus/src/pywps4/pywps-4/pywps/app.py", line 15, in
> <module>
> >     from pywps import inout
> > ImportError: bad magic number in 'pywps.inout': b'\x03\xf3\r\n'
> > @Naveen:
> > I can't replicate your problem :(, also on Wednesday we merged one
> branch into the master (try to use this code), the above error messages
> were probably caused by the merge.
> > Today I dont have much time, but either me or Jachym will give a look at
> the problems on the master code.
> > Cheers
> > Jorge
> > ________________________________________
> > From: Naveen Panwar [panwarn09 at gmail.com]
> > Sent: 02 March 2014 05:37
> > To: Jachym Cepicky
> > Cc: pywps-dev at lists.osgeo.org; Mendes de Jesus, Jorge
> > Subject: Re: [ GSOC 2014 ] Database output storage - PostGIS and SQLite
> > Sorry, I forgot to mention that,
> > I have Ubuntu 12.04 (Linux) , 64 bit machine.
> > On Sat, Mar 1, 2014 at 8:53 PM, Jachym Cepicky <jachym.cepicky at gmail.com
> <mailto:jachym.cepicky at gmail.com>> wrote:
> > On which platform are you operating? Linux? Which distro?
> > I have
> > '0.9.4'
> > What about you?
> > Jachym
> > On Sat, Mar 01, 2014 at 11:00:02PM +0530, Naveen Panwar wrote:
> > >    Hello sir,
> > >    As you suggested I have forked github (/jachym/pywps-4). Run it on
> my
> > >    machine I got following output as a result of "tox" command.
> > >    do I really need to have python3.3 ?? as it already successfully
> build
> > >    with python2.7.
> > >    last 10 lines --
> > >    Test GML validator ... ok
> > >    Ran 58 tests in 16.374s
> > >    OK (skipped=21)
> > >    py33 create: /home/naveen/pywps-4/.tox/py33
> > >    ERROR: InterpreterNotFound: python3.3
>  _______________________________________________________________________________
> > >    summary
>  ________________________________________________________________________________
> > >    py27: commands succeeded
> > >    ERROR:   py33: InterpreterNotFound: python3.3
> > >    Also when I run "python tests/__init__.py", I got following error.
> > >    File "__init__.py", line 4, in <module>
> > >        import parse
> > >      File "/home/naveen/pywps-4/tests/parse/__init__.py", line 11, in
> > >    <module>
> > >      File "/home/naveen/pywps-4/pywps/__init__.py", line 24, in
> <module>
> > >      File "/home/naveen/pywps-4/pywps/app.py", line 8, in <module>
> > >        from pywps.exceptions import InvalidParameterValue, \
> > >      File "/home/naveen/pywps-4/pywps/exceptions.py", line 10, in
> <module>
> > >    Could you please suggest anything about the error ?
> > >    On Thu, Feb 27, 2014 at 2:21 AM, Jachym Cepicky
> > >    <[1]jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>>
> wrote:
> > >      Hi,
> > >      sorry for late answer - we were waiting till OSGeo is accepted as
> > >      mentoring
> > >      organisation.
> > >      You can start working any time (join the mailing list -
> > >      [2]pywps-dev at lists.osgeo.org<mailto:pywps-dev at lists.osgeo.org>),
> fork github (/jachym/pywps-4), join
> > >      hangout
> > >      ([3]http://doodle.com/4wm7umivegm5sr4x),
> > >      or wait till the 10 March: 19:00 UTC, when the application period
> opens
> > >      (according to
> > >      [4]https://www.google-melange.com/gsoc/events/google/gsoc2014)
> and
> > >      proceed the standard way
> > >      Expect pywps-4 to be one big building place right now, we are
> shifting
> > >      big parts
> > >      of code from one side to another, some of the ideas are just in
> our
> > >      heads right
> > >      now, but we are approaching.
> > >      cheers
> > >      Jachym
> > >      On Mon, Feb 17, 2014 at 07:16:50PM +0530, Naveen Panwar wrote:
> > >      >    Hello Sir,
> > >      >    I am currently pursuing my master in Spatial Informatics
> at�[1]Lab
> > >      for
> > >      >    Spatial Informatics.
> > >      >    I am interested in the development of the project "Database
> output
> > >      >    storage" both in PostGIS and Sqlite. Because I have worked
> before,
> > >      both in
> > >      >    Python and Spatial Databases.�
> > >      >    And these project provided me the good�opportunity of
> development
> > >      in
> > >      >    python with my research areas.�
> > >      >    My programming skills -�C, C++, Python, Java.
> > >      >    Also I am families with open source development.
> > >      >    I build "VRGeo SMS tool" which is a open source crowd
> sourcing
> > >      platform to
> > >      >    collect the data from user using SMS. In this project we used
> > >      PostgreSQL
> > >      >    as a Database storage.
> > >      >    Please let me know how can I start working for the same. As
> the
> > >      students
> > >      >    application for GSOC-2014 will start on March 10, 2014.
> > >      >    Regards,
> > >      >    Naveen Panwar
> > >      >    IIIT-Hyderabad, India.
> > >      >    +91-9030736015
> > >      >    [2][5]http://lsi.iiit.ac.in/naveen.panwar
> > >      > References
> > >      >    Visible links
> > >      >    1. [6]http://lsi.iiit.ac.in/
> > >      >    2. [7]http://lsi.iiit.ac.in/naveen.panwar
> > >      Jachym Cepicky
> > >      URL: [8]http://les-ejk.cz
> > >      e-mail: jachym.cepicky at gmail com
> > >      PGP: [9]http://les-ejk.cz/pgp/JachymCepicky.pgp
> > >      @jachymc
> > >    Regards,
> > >    Naveen Panwar
> > >    Senior Undergraduate Student
> > >    [10]http://lsi.iiit.ac.in/naveen.panwar
> > > References
> > >    Visible links
> > >    1. mailto:jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>
> > >    2. mailto:pywps-dev at lists.osgeo.org<mailto:
> > >    3. http://doodle.com/4wm7umivegm5sr4x
> > >    4. https://www.google-melange.com/gsoc/events/google/gsoc2014
> > >    5. http://lsi.iiit.ac.in/naveen.panwar
> > >    6. http://lsi.iiit.ac.in/
> > >    7. http://lsi.iiit.ac.in/naveen.panwar
> > >    8. http://les-ejk.cz/
> > >    9. http://les-ejk.cz/pgp/JachymCepicky.pgp
> > >   10. http://lsi.iiit.ac.in/naveen.panwar
> > Jachym Cepicky
> > URL: http://les-ejk.cz
> > PGP: http://les-ejk.cz/pgp/JachymCepicky.pgp
> > @jachymc
> > Regards,
> > Naveen Panwar
> Jachym Cepicky
> @jachymc
Regards,
Naveen Panwar
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20140303/65137fdd/attachment-0001.html>
More information about the pywps-dev mailing list
