[Pywps-dev] [ GSOC 2014 ] Database output storage - PostGIS and SQLite
Naveen Panwar panwarn09 at gmail.com
Tue Mar 4 22:02:34 PST 2014
Problem is resolved. When I re-install Python3.3, Python2.7 and *werkzeug
package.*
Thanks!!!
On Mon, Mar 3, 2014 at 10:11 AM, Naveen Panwar <panwarn09 at gmail.com> wrote:
> I have set the PYTHONPATH.
> following is the output of two command which you asked me to run.
> >>> *werkzeug.__version__*
> '0.9.4'
> >>> *from werkzeug._compat import text_type*
> Traceback (most recent call last):
>   File "<stdin>", line 1, in <module>
> ImportError: No module named _compat
> On Mon, Mar 3, 2014 at 1:45 PM, Jachym Cepicky <jachym.cepicky at gmail.com>wrote:
>> Hi,
>> regarding the complexouput error, I use
>> export PYTHONPATH=./tests/:./:./pywps:
>> before I call 'tox', python3 seems then to work
>> regarding werkzeug: did you try to run in from command line?
>> python
>> >>> from werkzeug.__compat import text_type
>> and see, if it works?
>> J
>> > On Sun, Mar 02, 2014 at 03:01:11PM +0000, Mendes de Jesus, Jorge wrote:
>> > Hi to all
>> > 1) Python versions
>> > If I'm not mistaken we agreed on using python2.7 and python3.3 as
>> minimal requirements. Therefore all code has to work on both interpreters.
>> > As an extra pypy should be supported (latest version seems to be
>> working fine with PyWPS)
>> > 2) werkzeug error
>> > I've upgraded my werkzeug package to your version and tried to recreate
>> the tox (tox -e ) but hit some other error with module import
>> > py27 runtests: commands[0] | python tests/__init__.py
>> >   File "tests/__init__.py", line 4, in <module>
>> >     import parse
>> >   File "/home/jesus/src/pywps4/pywps-4/tests/parse/__init__.py", line
>> 11, in <module>
>> >     from pywps import request
>> >   File "/home/jesus/src/pywps4/pywps-4/pywps/__init__.py", line 24, in
>> <module>
>> >     from pywps.app import (
>> >   File "/home/jesus/src/pywps4/pywps-4/pywps/app.py", line 283, in
>> <module>
>> >     class ComplexOutput(inout.ComplexOutput):
>> > AttributeError: 'module' object has no attribute 'ComplexOutput'
>> > And then on py33
>> > py33 runtests: commands[0] | python tests/__init__.py
>> >     import parse
>> 11, in <module>
>> <module>
>> >   File "/home/jesus/src/pywps4/pywps-4/pywps/app.py", line 15, in
>> <module>
>> >     from pywps import inout
>> > ImportError: bad magic number in 'pywps.inout': b'\x03\xf3\r\n'
>> > @Naveen:
>> > I can't replicate your problem :(, also on Wednesday we merged one
>> branch into the master (try to use this code), the above error messages
>> were probably caused by the merge.
>> > Today I dont have much time, but either me or Jachym will give a look
>> at the problems on the master code.
>> > Cheers
>> > Jorge
>> > ________________________________________
>> > From: Naveen Panwar [panwarn09 at gmail.com]
>> > Sent: 02 March 2014 05:37
>> > To: Jachym Cepicky
>> > Cc: pywps-dev at lists.osgeo.org; Mendes de Jesus, Jorge
>> > Subject: Re: [ GSOC 2014 ] Database output storage - PostGIS and SQLite
>> > Sorry, I forgot to mention that,
>> > I have Ubuntu 12.04 (Linux) , 64 bit machine.
>> > On Sat, Mar 1, 2014 at 8:53 PM, Jachym Cepicky <
>> jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>> wrote:
>> > On which platform are you operating? Linux? Which distro?
>> > I have
>> > '0.9.4'
>> > What about you?
>> > Jachym
>> > On Sat, Mar 01, 2014 at 11:00:02PM +0530, Naveen Panwar wrote:
>> > >    Hello sir,
>> > >    As you suggested I have forked github (/jachym/pywps-4). Run it on
>> my
>> > >    machine I got following output as a result of "tox" command.
>> > >    do I really need to have python3.3 ?? as it already successfully
>> build
>> > >    with python2.7.
>> > >    last 10 lines --
>> > >    Test GML validator ... ok
>> > >    Ran 58 tests in 16.374s
>> > >    OK (skipped=21)
>> > >    py33 create: /home/naveen/pywps-4/.tox/py33
>> > >    ERROR: InterpreterNotFound: python3.3
>>  _______________________________________________________________________________
>> > >    summary
>>  ________________________________________________________________________________
>> > >    py27: commands succeeded
>> > >    ERROR:   py33: InterpreterNotFound: python3.3
>> > >    Also when I run "python tests/__init__.py", I got following error.
>> > >    File "__init__.py", line 4, in <module>
>> > >        import parse
>> > >      File "/home/naveen/pywps-4/tests/parse/__init__.py", line 11, in
>> > >    <module>
>> > >      File "/home/naveen/pywps-4/pywps/__init__.py", line 24, in
>> <module>
>> > >      File "/home/naveen/pywps-4/pywps/app.py", line 8, in <module>
>> > >        from pywps.exceptions import InvalidParameterValue, \
>> > >      File "/home/naveen/pywps-4/pywps/exceptions.py", line 10, in
>> <module>
>> > >    Could you please suggest anything about the error ?
>> > >    On Thu, Feb 27, 2014 at 2:21 AM, Jachym Cepicky
>> > >    <[1]jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com>>
>> wrote:
>> > >      Hi,
>> > >      sorry for late answer - we were waiting till OSGeo is accepted as
>> > >      mentoring
>> > >      organisation.
>> > >      You can start working any time (join the mailing list -
>> > >      [2]pywps-dev at lists.osgeo.org<mailto:pywps-dev at lists.osgeo.org>),
>> fork github (/jachym/pywps-4), join
>> > >      hangout
>> > >      ([3]http://doodle.com/4wm7umivegm5sr4x),
>> > >      or wait till the 10 March: 19:00 UTC, when the application
>> period opens
>> > >      (according to
>> > >      [4]https://www.google-melange.com/gsoc/events/google/gsoc2014)
>> and
>> > >      proceed the standard way
>> > >      Expect pywps-4 to be one big building place right now, we are
>> shifting
>> > >      big parts
>> > >      of code from one side to another, some of the ideas are just in
>> our
>> > >      heads right
>> > >      now, but we are approaching.
>> > >      cheers
>> > >      Jachym
>> > >      On Mon, Feb 17, 2014 at 07:16:50PM +0530, Naveen Panwar wrote:
>> > >      >    Hello Sir,
>> > >      >    I am currently pursuing my master in Spatial Informatics
>> at�[1]Lab
>> > >      for
>> > >      >    Spatial Informatics.
>> > >      >    I am interested in the development of the project "Database
>> output
>> > >      >    storage" both in PostGIS and Sqlite. Because I have worked
>> before,
>> > >      both in
>> > >      >    Python and Spatial Databases.�
>> > >      >    And these project provided me the good�opportunity of
>> development
>> > >      in
>> > >      >    python with my research areas.�
>> > >      >    My programming skills -�C, C++, Python, Java.
>> > >      >    Also I am families with open source development.
>> > >      >    I build "VRGeo SMS tool" which is a open source crowd
>> sourcing
>> > >      platform to
>> > >      >    collect the data from user using SMS. In this project we
>> used
>> > >      PostgreSQL
>> > >      >    as a Database storage.
>> > >      >    Please let me know how can I start working for the same. As
>> the
>> > >      students
>> > >      >    application for GSOC-2014 will start on March 10, 2014.
>> > >      >    Regards,
>> > >      >    Naveen Panwar
>> > >      >    IIIT-Hyderabad, India.
>> > >      >    +91-9030736015
>> > >      >    [2][5]http://lsi.iiit.ac.in/naveen.panwar
>> > >      > References
>> > >      >    Visible links
>> > >      >    1. [6]http://lsi.iiit.ac.in/
>> > >      >    2. [7]http://lsi.iiit.ac.in/naveen.panwar
>> > >      Jachym Cepicky
>> > >      URL: [8]http://les-ejk.cz
>> > >      e-mail: jachym.cepicky at gmail com
>> > >      PGP: [9]http://les-ejk.cz/pgp/JachymCepicky.pgp
>> > >      @jachymc
>> > >    Regards,
>> > >    Naveen Panwar
>> > >    Senior Undergraduate Student
>> > >    [10]http://lsi.iiit.ac.in/naveen.panwar
>> > > References
>> > >    Visible links
>> > >    1. mailto:jachym.cepicky at gmail.com<mailto:jachym.cepicky at gmail.com
>> > >    2. mailto:pywps-dev at lists.osgeo.org<mailto:
>> > >    3. http://doodle.com/4wm7umivegm5sr4x
>> > >    4. https://www.google-melange.com/gsoc/events/google/gsoc2014
>> > >    5. http://lsi.iiit.ac.in/naveen.panwar
>> > >    6. http://lsi.iiit.ac.in/
>> > >    7. http://lsi.iiit.ac.in/naveen.panwar
>> > >    8. http://les-ejk.cz/
>> > >    9. http://les-ejk.cz/pgp/JachymCepicky.pgp
>> > >   10. http://lsi.iiit.ac.in/naveen.panwar
>> > Jachym Cepicky
>> > URL: http://les-ejk.cz
>> > PGP: http://les-ejk.cz/pgp/JachymCepicky.pgp
>> > @jachymc
>> > Regards,
>> > Naveen Panwar
>> Jachym Cepicky
>> @jachymc
> Regards,
> Naveen Panwar
Regards,
Naveen Panwar
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20140305/5ae2bde0/attachment-0001.html>
More information about the pywps-dev mailing list
