[Pywps-dev] [ GSOC 2014 ] Database output storage idea.
Jachym Cepicky jachym.cepicky at geosense.cz
Mon Mar 10 16:31:41 PDT 2014
On Tue, Mar 11, 2014 at 01:02:08AM +0530, Naveen Panwar wrote:
>    Respected Sir,
>    As you suggested in previous mail I have gone through Pywps [1]Cookbook
>    Documentation[1].  As there are three types of inputs and outputs are
>    defined in the OGC standard: LiteralData, ComplexData, BoundingBox data.
>    But as you mentioned we have to take care of ComplexData.
Not true: also literal and bbox data can be stored in database (but they are
much simplier task to be done thought).
>    Currently ComplexData data store in two manner, One with xml as GML
>    format, Second with binary raster data encoded in base64.
>    these data stored as a file in system. Now we need database for the better
>    access and availability.
>    I following questions in my mind.
>    1. Do we have write database module so that user can configure there own
>    database server by providing db URL and user credential, like standard db
>    connectivity ?
This case
>    2. Or we have to design our own database and provide db connection object
>    to user, so that they can write to the DB ?
User should be able to setup everything using configuration file.
>    3. How are we supposed to store the data in DB as both vector and raster
>    data present in different format ?
PostGIS should do this. SQLite has support for some raster formats as well
>    4. What kind of database support do we need ? Relational DB(PostgreSQL,
>    MySQL) or NOSql DB (as we have Cassandra by pycassa ) ?
PostgreSQL/PostGIS, SQLite for the first steps. NOSql you nemntioned at the
second.
>    5. What should be the schema of the database ? is it predefine or define
>    by the user ?
User should define, which schema schould be used.
>    and last but not the least when will be next hangout 13 march or 26 march
>    ? sorry bit confuse.
sorry for the mess
http://www.timeanddate.com/worldclock/fixedtime.html?iso=20140313T20&ah=1
we are still aranging, how to define timeslots
J
>    [1] -
>    [2]http://netmar.nersc.no/sites/netmar.nersc.no/files/D7.7_WPS_Cookbook_r1_20111229.pdf
>    On Mon, Mar 10, 2014 at 2:33 AM, Jachym Cepicky
>    <[3]jachym.cepicky at gmail.com> wrote:
>      Hi,
>      On Sun, Mar 09, 2014 at 05:46:09PM +0000, Mendes de Jesus, Jorge wrote:
>      > Hi to all
>      > @Naveen, first give a look at the WPS standard 1.0.0[1] and we have a
>      wiki [2]and doc online [3] (all document refer to the old 3.2 version
>      but still a good source of information and technical know-how
>      > @Jachym, correct me when wrong
>      > WPS defines one output as ComplexData, meaning a raster images,
>      vetorial data etc etc can be contained between the element tags
>      <ComplexData /> The output data can be stored in the server when the
>      user requests an async result, the data stored is then fetch by an URL
>      location indicates by a status response.
>      > So,
>      > 1) The data stored in the server is currently saved on the filesystem
>      and we need it in a DB
>      better say: we would like to offer option, that all generated output
>      data could
>      be stored in some database, instead of file system
>      > 2) URLs will have to point to some function/service/DBrequest that
>      will fetch the results to the user
>      so service will have to be written/configured (using
>      mapserver/geoserver/custom
>      something), which will do the serving
>      > 3) DB structure should contain metadata on the request, datatype  etc
>      etc etc
>      > 4) We are currently  working on new code and things are not 100%
>      stable, nor I have a clear knowledge of the code therefore I can't give
>      you a direct answer to were in the code this has to be hookedup (Maybe
>      during the next hangout 13-March I/we will check it out).Please give a
>      look at the pywps4.0 documentation [4]
>      currently, first version of file storage is implemented - just storing,
>      no data
>      exporting
>      [4]https://github.com/jachym/pywps-4/blob/master/pywps/inout.py#L227
>      (will be moved to separate file soon, or maybe package)
>      J
>      > [1] [5]http://www.opengeospatial.org/standards/wps
>      > [2] [6]http://wiki.rsg.pml.ac.uk/pywps/Main_Page
>      > [3] [7]http://pywps.wald.intevation.org/documentation/
>      > [4] [8]http://pywps.readthedocs.or
>      > I will try to give you more information on the following days
>      > Jorge
>      > ________________________________________
>      > From: Naveen Panwar [[9]panwarn09 at gmail.com]
>      > Sent: 07 March 2014 10:00
>      > To: Mendes de Jesus, Jorge; Jáchym Čepický
>      > Subject: [ GSOC 2014 ] Database output storage idea.
>      > Hello Sir,
>      > As we know students application starts on March 10th.
>      > For that I have to write proposal for the idea "Database output
>      storage - PostGIS and SQLite".
>      > So could you suggest anything in this direction. What should be in the
>      IDEA related to Pywps.
>      > Also could you suggest on which modules we have to add database
>      interaction
>      > in Pywps code base.
>      > Regards,
>      > Naveen Panwar
>      > Senior Undergraduate Student
>      > IIIT-Hyderabad, India.
>      > [10]http://lsi.iiit.ac.in/naveen.panwar
>      Jachym Cepicky
>      URL: [11]http://les-ejk.cz
>      e-mail: jachym.cepicky at gmail com
>      PGP: [12]http://les-ejk.cz/pgp/JachymCepicky.pgp
>      @jachymc
>    Regards,
>    Naveen Panwar
>    [13]http://lsi.iiit.ac.in/naveen.panwar
> References
>    Visible links
>    1. http://netmar.nersc.no/sites/netmar.nersc.no/files/D7.7_WPS_Cookbook_r1_20111229.pdf
>    2. http://netmar.nersc.no/sites/netmar.nersc.no/files/D7.7_WPS_Cookbook_r1_20111229.pdf
>    3. mailto:jachym.cepicky at gmail.com
>    4. https://github.com/jachym/pywps-4/blob/master/pywps/inout.py#L227
>    5. http://www.opengeospatial.org/standards/wps
>    6. http://wiki.rsg.pml.ac.uk/pywps/Main_Page
>    7. http://pywps.wald.intevation.org/documentation/
>    8. http://pywps.readthedocs.or/
>    9. mailto:panwarn09 at gmail.com
>   10. http://lsi.iiit.ac.in/naveen.panwar
>   11. http://les-ejk.cz/
>   12. http://les-ejk.cz/pgp/JachymCepicky.pgp
>   13. http://lsi.iiit.ac.in/naveen.panwar
Jachym Cepicky
URL: http://geosense.cz
e-mail: jachym.cepicky at geosense cz
PGP: http://les-ejk.cz/pgp/JachymCepicky.pgp
@jachymc
More information about the pywps-dev mailing list
