[Pywps-dev] [ GSOC 2014 ] Database output storage idea.
Naveen Panwar panwarn09 at gmail.com
Mon Mar 10 12:32:08 PDT 2014
Respected Sir,
As you suggested in previous mail I have gone through Pywps Cookbook
Documentation<http://netmar.nersc.no/sites/netmar.nersc.no/files/D7.7_WPS_Cookbook_r1_20111229.pdf>[1].
As there are three types of inputs and outputs are defined in the OGC
standard: LiteralData, ComplexData, BoundingBox data. But as you mentioned
we have to take care of ComplexData.
Currently ComplexData data store in two manner, One with xml as GML format,
Second with binary raster data encoded in base64.
these data stored as a file in system. Now we need database for the better
access and availability.
I following questions in my mind.
1. Do we have write database module so that user can configure there own
database server by providing db URL and user credential, like standard db
connectivity ?
2. Or we have to design our own database and provide db connection object
to user, so that they can write to the DB ?
3. How are we supposed to store the data in DB as both vector and raster
data present in different format ?
4. What kind of database support do we need ? Relational DB(PostgreSQL,
MySQL) or NOSql DB (as we have Cassandra by pycassa ) ?
5. What should be the *schema *of the database ? is it predefine or define
by the user ?
and last but not the least when will be next hangout 13 march or 26 march ?
sorry bit confuse.
[1] -
On Mon, Mar 10, 2014 at 2:33 AM, Jachym Cepicky <jachym.cepicky at gmail.com>wrote:
> Hi,
> On Sun, Mar 09, 2014 at 05:46:09PM +0000, Mendes de Jesus, Jorge wrote:
> > Hi to all
> > @Naveen, first give a look at the WPS standard 1.0.0[1] and we have a
> wiki [2]and doc online [3] (all document refer to the old 3.2 version but
> still a good source of information and technical know-how
> > @Jachym, correct me when wrong
> > WPS defines one output as ComplexData, meaning a raster images, vetorial
> data etc etc can be contained between the element tags <ComplexData /> The
> output data can be stored in the server when the user requests an async
> result, the data stored is then fetch by an URL location indicates by a
> status response.
> > So,
> > 1) The data stored in the server is currently saved on the filesystem
> and we need it in a DB
> better say: we would like to offer option, that all generated output data
> could
> be stored in some database, instead of file system
> > 2) URLs will have to point to some function/service/DBrequest that will
> fetch the results to the user
> so service will have to be written/configured (using
> mapserver/geoserver/custom
> something), which will do the serving
> > 3) DB structure should contain metadata on the request, datatype  etc
> etc etc
> > 4) We are currently  working on new code and things are not 100% stable,
> nor I have a clear knowledge of the code therefore I can't give you a
> direct answer to were in the code this has to be hookedup (Maybe during the
> next hangout 13-March I/we will check it out).Please give a look at the
> pywps4.0 documentation [4]
> currently, first version of file storage is implemented - just storing, no
> data
> exporting
> https://github.com/jachym/pywps-4/blob/master/pywps/inout.py#L227
> (will be moved to separate file soon, or maybe package)
> J
> > [1] http://www.opengeospatial.org/standards/wps
> > [2] http://wiki.rsg.pml.ac.uk/pywps/Main_Page
> > [3] http://pywps.wald.intevation.org/documentation/
> > [4] http://pywps.readthedocs.or
> > I will try to give you more information on the following days
> > Jorge
> > ________________________________________
> > From: Naveen Panwar [panwarn09 at gmail.com]
> > Sent: 07 March 2014 10:00
> > To: Mendes de Jesus, Jorge; Jáchym Čepický
> > Subject: [ GSOC 2014 ] Database output storage idea.
> > Hello Sir,
> > As we know students application starts on March 10th.
> > For that I have to write proposal for the idea "Database output storage
> - PostGIS and SQLite".
> > So could you suggest anything in this direction. What should be in the
> IDEA related to Pywps.
> > Also could you suggest on which modules we have to add database
> interaction
> > in Pywps code base.
> > Regards,
> > Naveen Panwar
> > Senior Undergraduate Student
> > IIIT-Hyderabad, India.
> > http://lsi.iiit.ac.in/naveen.panwar
> Jachym Cepicky
> URL: http://les-ejk.cz
> e-mail: jachym.cepicky at gmail com
> PGP: http://les-ejk.cz/pgp/JachymCepicky.pgp
> @jachymc
Regards,
Naveen Panwar
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20140311/cb12cd84/attachment.html>
More information about the pywps-dev mailing list
