[Pywps-dev] [ GSOC 2014 ] Database output storage idea.
Naveen Panwar panwarn09 at gmail.com
Thu Mar 13 08:43:19 PDT 2014
Respected Sir,
Followings are the points which needed to be answer regarding the proposal
according to OSGeo Guideline.
1. Introduction --
2. Background --
3. The idea --
4. Project plan [ Detailed Time-line (Probably *13-week* ) ] --
5. Future ideas / How can your idea be expanded ?
I think we should consider these points on tonight hangout
>>      > On 03/11/2014 12:31 AM, Jachym Cepicky wrote:
> >>      > > Hi,
> >>      > > On Tue, Mar 11, 2014 at 01:02:08AM +0530, Naveen Panwar wrote:
> >>      > >>    Respected Sir,
> >>      > >>    As you suggested in previous mail I have gone through Pywps
> >>      [1]Cookbook
> >>      > >>    Documentation[1].  As there are three types of inputs and
> >>      outputs are
> >>      > >>    defined in the OGC standard: LiteralData, ComplexData,
> >>      BoundingBox data.
> >>      > >>    But as you mentioned we have to take care of ComplexData.
> >>      > > Not true: also literal and bbox data can be stored in database
> (but
> >>      they are
> >>      > > much simplier task to be done thought).
> >>      > >>    Currently ComplexData data store in two manner, One with
> xml as
> >>      GML
> >>      > >>    format, Second with binary raster data encoded in base64.
> >>      > >>    these data stored as a file in system. Now we need
> database for
> >>      the better
> >>      > >>    access and availability.
> >>      > >>    I following questions in my mind.
> >>      > >>    1. Do we have write database module so that user can
> configure
> >>      there own
> >>      > >>    database server by providing db URL and user credential,
> like
> >>      standard db
> >>      > >>    connectivity ?
> >>      > > This case
> >>      > >>    2. Or we have to design our own database and provide db
> >>      connection object
> >>      > >>    to user, so that they can write to the DB ?
> >>      > > User should be able to setup everything using configuration
> file.
> >>      > >>    3. How are we supposed to store the data in DB as both
> vector
> >>      and raster
> >>      > >>    data present in different format ?
> >>      > > PostGIS should do this. SQLite has support for some raster
> formats
> >>      as well
> >>      > >>    4. What kind of database support do we need ? Relational
> >>      DB(PostgreSQL,
> >>      > >>    MySQL) or NOSql DB (as we have Cassandra by pycassa ) ?
> >>      > > PostgreSQL/PostGIS, SQLite for the first steps. NOSql you
> nemntioned
> >>      at the
> >>      > > second.
> >>      > >>    5. What should be the schema of the database ? is it
> predefine
> >>      or define
> >>      > >>    by the user ?
> >>      > > User should define, which schema schould be used.
> >>      > >>    and last but not the least when will be next hangout 13
> march or
> >>      26 march
> >>      > >>    ? sorry bit confuse.
> >>      > > sorry for the mess
> >>      [3]
> http://www.timeanddate.com/worldclock/fixedtime.html?iso=20140313T20&ah=1
> >>      > > we are still aranging, how to define timeslots
> >>      > > J
> >>      > >>    [1] -
> >>       [2][4]
> http://netmar.nersc.no/sites/netmar.nersc.no/files/D7.7_WPS_Cookbook_r1_20111229.pdf
> >>      > >>    On Mon, Mar 10, 2014 at 2:33 AM, Jachym Cepicky
> >>      > >>    <[3][5]jachym.cepicky at gmail.com> wrote:
> >>      > >>      Hi,
> >>      > >>      On Sun, Mar 09, 2014 at 05:46:09PM +0000, Mendes de
> Jesus,
> >>      Jorge wrote:
> >>      > >>      > Hi to all
> >>      > >>      > @Naveen, first give a look at the WPS standard
> 1.0.0[1] and
> >>      we have a
> >>      > >>      wiki [2]and doc online [3] (all document refer to the
> old 3.2
> >>      version
> >>      > >>      but still a good source of information and technical
> know-how
> >>      > >>      > @Jachym, correct me when wrong
> >>      > >>      > WPS defines one output as ComplexData, meaning a raster
> >>      images,
> >>      > >>      vetorial data etc etc can be contained between the
> element
> >>      tags
> >>      > >>      <ComplexData /> The output data can be stored in the
> server
> >>      when the
> >>      > >>      user requests an async result, the data stored is then
> fetch
> >>      by an URL
> >>      > >>      location indicates by a status response.
> >>      > >>      > So,
> >>      > >>      > 1) The data stored in the server is currently saved on
> the
> >>      filesystem
> >>      > >>      and we need it in a DB
> >>      > >>      better say: we would like to offer option, that all
> generated
> >>      output
> >>      > >>      data could
> >>      > >>      be stored in some database, instead of file system
> >>      > >>      > 2) URLs will have to point to some
> >>      function/service/DBrequest that
> >>      > >>      will fetch the results to the user
> >>      > >>      so service will have to be written/configured (using
> >>      > >>      mapserver/geoserver/custom
> >>      > >>      something), which will do the serving
> >>      > >>      > 3) DB structure should contain metadata on the request,
> >>      datatype  etc
> >>      > >>      etc etc
> >>      > >>      > 4) We are currently  working on new code and things
> are not
> >>      100%
> >>      > >>      stable, nor I have a clear knowledge of the code
> therefore I
> >>      can't give
> >>      > >>      you a direct answer to were in the code this has to be
> >>      hookedup (Maybe
> >>      > >>      during the next hangout 13-March I/we will check it
> >>      out).Please give a
> >>      > >>      look at the pywps4.0 documentation [4]
> >>      > >>      currently, first version of file storage is implemented
> - just
> >>      storing,
> >>      > >>      no data
> >>      > >>      exporting
> >>       [4][6]
> https://github.com/jachym/pywps-4/blob/master/pywps/inout.py#L227
> >>      > >>      (will be moved to separate file soon, or maybe package)
> >>      > >>      J
> >>      > >>      > [1] [5][7]http://www.opengeospatial.org/standards/wps
> >>      > >>      > [2] [6][8]http://wiki.rsg.pml.ac.uk/pywps/Main_Page
> >>      > >>      > [3] [7][9]
> http://pywps.wald.intevation.org/documentation/
> >>      > >>      > [4] [8][10]http://pywps.readthedocs.or
> >>      > >>      > I will try to give you more information on the
> following
> >>      days
> >>      > >>      > Jorge
> >>      > >>      > ________________________________________
> >>      > >>      > From: Naveen Panwar [[9][11]panwarn09 at gmail.com]
> >>      > >>      > Sent: 07 March 2014 10:00
> >>      > >>      > To: Mendes de Jesus, Jorge; Jáchym Čepický
> >>      > >>      > Subject: [ GSOC 2014 ] Database output storage idea.
> >>      > >>      > Hello Sir,
> >>      > >>      > As we know students application starts on March 10th.
> >>      > >>      > For that I have to write proposal for the idea
> "Database
> >>      output
> >>      > >>      storage - PostGIS and SQLite".
> >>      > >>      > So could you suggest anything in this direction. What
> should
> >>      be in the
> >>      > >>      IDEA related to Pywps.
> >>      > >>      > Also could you suggest on which modules we have to add
> >>      database
> >>      > >>      interaction
> >>      > >>      > in Pywps code base.
> >>      > >>      > Regards,
> >>      > >>      > Naveen Panwar
> >>      > >>      > Senior Undergraduate Student
> >>      > >>      > IIIT-Hyderabad, India.
> >>      > >>      > [10][12]http://lsi.iiit.ac.in/naveen.panwar
> >>      > >>      Jachym Cepicky
> >>      > >>      URL: [11][13]http://les-ejk.cz
> >>      > >>      e-mail: jachym.cepicky at gmail com
> >>      > >>      PGP: [12][14]http://les-ejk.cz/pgp/JachymCepicky.pgp
> >>      > >>      @jachymc
> >>      > >>    Regards,
> >>      > >>    Naveen Panwar
> >>      > >>    [13][15]http://lsi.iiit.ac.in/naveen.panwar
> >>      > >> References
> >>      > >>    Visible links
> >>      > >>    1.
> >>      [16]
> >>      > >>    2.
> >>      [17]
> >>      > >>    3. mailto:[18]jachym.cepicky at gmail.com
> >>      > >>    4.
> >>      [19]
> >>      > >>    5. [20]http://www.opengeospatial.org/standards/wps
> >>      > >>    6. [21]http://wiki.rsg.pml.ac.uk/pywps/Main_Page
> >>      > >>    7. [22]http://pywps.wald.intevation.org/documentation/
> >>      > >>    8. [23]http://pywps.readthedocs.or/
> >>      > >>    9. mailto:[24]panwarn09 at gmail.com
> >>      > >>   10. [25]http://lsi.iiit.ac.in/naveen.panwar
> >>      > >>   11. [26]http://les-ejk.cz/
> >>      > >>   12. [27]http://les-ejk.cz/pgp/JachymCepicky.pgp
> >>      > >>   13. [28]http://lsi.iiit.ac.in/naveen.panwar
> >>      > ISRIC - World Soil Information Post: PO box 353, 6700 AJ,
> Wageningen,
> >>      > The Netherlands Visiting Address: Droevendaalsesteeg 3, 6708 PB
> >>      > Wageningen (Bdg. 101), Office: C.013 Office Phone: +31 (0) 317 4
> 83715
> >>      > Mobile Phone: +31 (0) 613 9 06950 OpenPGPKey: 0xA3D0065A
> >>      Jachym Cepicky
> >>      URL: [29]http://les-ejk.cz
> >>      PGP: [30]http://les-ejk.cz/pgp/JachymCepicky.pgp
> >>      @jachymc
> >>      _______________________________________________
> >>      pywps-dev mailing list
> >>      [31]pywps-dev at lists.osgeo.org
> >>      [32]http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
> >>    Regards,
> >>    Naveen Panwar
> >>    [33]http://lsi.iiit.ac.in/naveen.panwar
> >> References
> >>    Visible links
> >>    1. mailto:jachym.cepicky at gmail.com
> >>    2. http://istgeo.ist.supsi.ch/software/istsos/
> >>    3.
> >>    4.
> >>    5. mailto:jachym.cepicky at gmail.com
> >>    6. https://github.com/jachym/pywps-4/blob/master/pywps/inout.py#L227
> >>    7. http://www.opengeospatial.org/standards/wps
> >>    8. http://wiki.rsg.pml.ac.uk/pywps/Main_Page
> >>    9. http://pywps.wald.intevation.org/documentation/
> >>   10. http://pywps.readthedocs.or/
> >>   11. mailto:panwarn09 at gmail.com
> >>   12. http://lsi.iiit.ac.in/naveen.panwar
> >>   13. http://les-ejk.cz/
> >>   14. http://les-ejk.cz/pgp/JachymCepicky.pgp
> >>   15. http://lsi.iiit.ac.in/naveen.panwar
> >>   16.
> >>   17.
> >>   18. mailto:jachym.cepicky at gmail.com
> >>   19. https://github.com/jachym/pywps-4/blob/master/pywps/inout.py#L227
> >>   20. http://www.opengeospatial.org/standards/wps
> >>   21. http://wiki.rsg.pml.ac.uk/pywps/Main_Page
> >>   22. http://pywps.wald.intevation.org/documentation/
> >>   23. http://pywps.readthedocs.or/
> >>   24. mailto:panwarn09 at gmail.com
> >>   25. http://lsi.iiit.ac.in/naveen.panwar
> >>   26. http://les-ejk.cz/
> >>   27. http://les-ejk.cz/pgp/JachymCepicky.pgp
> >>   28. http://lsi.iiit.ac.in/naveen.panwar
> >>   29. http://les-ejk.cz/
> >>   30. http://les-ejk.cz/pgp/JachymCepicky.pgp
> >>   31. mailto:pywps-dev at lists.osgeo.org
> >>   32. http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
> >>   33. http://lsi.iiit.ac.in/naveen.panwar
> ISRIC - World Soil Information Post: PO box 353, 6700 AJ, Wageningen,
> Wageningen (Bdg. 101), Office: C.013 Office Phone: +31 (0) 317 4 83715
Regards,
Naveen Panwar
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20140313/54b05fab/attachment-0001.html>
More information about the pywps-dev mailing list
