[Pywps-dev] fixing setup.py
Jachym Cepicky jachym.cepicky at gmail.com
Sat Mar 29 04:15:58 PDT 2014
Thanks Jonas for feedback.
Any windows user around?
Jachym
On Sat, Mar 29, 2014 at 06:08:19AM -0500, Jonas Eberle wrote:
>    Hi Jachym,
>    I tried the installation on OSGeo Live 7.0 version and everything works
>    fine. No further adjustment was needed to execute an example process from
>    the command line. Also execution from localhost after creation of wps.cgi
>    in cgi-bin directory was successful.
>    Please check dummyprocess.py: There is an error (cannot concatenate str
>    and int objects) when the user does not specify the inputs. The default
>    values are strings, should be integer values.
>    Cheers,
>    Jonas
>      Hi all,
>      could you please verify and (would be the best) confirm, that the
>          python setup.py build
>          python setup.py install
>      In PyWPS 3.x - at master branch in git is now doing, what we wanted
>      since many
>      years?
>      If you confirm that, I would like to proceed, to get PyWPS finally on
>      OSGeo-live
>      Thank you
>      Jachym
>      Jachym Cepicky
>      URL: http://les-ejk.cz
>      e-mail: jachym.cepicky at gmail com
>      PGP: http://les-ejk.cz/pgp/JachymCepicky.pgp
>      @jachymc
>      _______________________________________________
>      pywps-dev mailing list
>      pywps-dev at lists.osgeo.org
>      http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
Jachym Cepicky
@jachymc
More information about the pywps-dev mailing list
