[Pywps-dev] fixing setup.py
Jonas Eberle jonas.eberle at gmx.de
Sat Mar 29 04:08:19 PDT 2014
Hi Jachym,
I tried the installation on OSGeo Live 7.0 version and everything works fine. No further adjustment was needed to execute an example process from the command line. Also execution from localhost after creation of wps.cgi in cgi-bin directory was successful.
Please check dummyprocess.py: There is an error (cannot concatenate str and int objects) when the user does not specify the inputs. The default values are strings, should be integer values.
Cheers,
Jonas
----- Ursprüngliche Mail -----
> Hi all,
> could you please verify and (would be the best) confirm, that the
> python setup.py build
> python setup.py install
> In PyWPS 3.x - at master branch in git is now doing, what we wanted since
> many
> years?
> If you confirm that, I would like to proceed, to get PyWPS finally on
> OSGeo-live
> Thank you
> Jachym
> Jachym Cepicky
> URL: http://les-ejk.cz
> e-mail: jachym.cepicky at gmail com
> PGP: http://les-ejk.cz/pgp/JachymCepicky.pgp
> @jachymc
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20140329/5f36fbf0/attachment.html>
More information about the pywps-dev mailing list
