[Pywps-dev] Deactivate sqlalchemy logging
Jáchym Čepický jachym.cepicky at gmail.com
Fri Dec 23 14:08:00 PST 2016
So
try 'WARNING'
did it help?
J
Dne 23.12.2016 v 23:06 Sylvain Beorchia napsal(a):
> Hi Jachym,
> Mmm not sure to well understand.
> According to the doc, level=INFO is the default.
> In dblog.py, we have :
> level = configuration.get_config_value('logging', 'level')
> if level in ['INFO']:
>     echo = False
> try:
>     engine = sqlalchemy.create_engine(database, echo=echo)
> If we set level = INFO (which is default), log shouldn't be activated. I
> don't understand.
> Anyway, i've tried the force the setting to INFO:
> [logging]
> level=INFO
>  and no luck. I still have got lots of logs.
> I'm going to try to debug that.
> Sylvain.
> 2016-12-23 16:53 GMT+01:00 Jáchym Čepický <jachym.cepicky at gmail.com>:
>> Hi,
>> sorry for later response
>> in PyWPS configuration file, you can set log level to anything but INFO -
>> in that case, in dblog.py
>> 172   engine = sqlalchemy.create_engine(database, echo=echo_level)
>> echo_level will be set to False
>> See
>> http://pywps.readthedocs.io/en/latest/configuration.html#logging
>> for how to set this in configuration file
>> Is that ok?
>> Jachym
>> Dne 16.12.2016 v 09:41 Sylvain Beorchia napsal(a):
>>> Hi all,
>>> Using my firsts pywps processes, i've got plenty of unwanted logs. Here's
>>> an extract :
>>> [Fri Dec 16 09:34:36.637934 2016] [:error] [pid 27598]
>>> INFO:sqlalchemy.engine.base.Engine:
>>> [Fri Dec 16 09:34:36.637937 2016] [:error] [pid 27598] CREATE TABLE
>>> pywps_stored_requests (
>>> [Fri Dec 16 09:34:36.637938 2016] [:error] [pid 27598] \tuuid VARCHAR(255)
>>> NOT NULL,
>>> [Fri Dec 16 09:34:36.637940 2016] [:error] [pid 27598] \trequest BLOB NOT
>>> NULL,
>>> [Fri Dec 16 09:34:36.637942 2016] [:error] [pid 27598] \tPRIMARY KEY
>>> (uuid)
>>> [Fri Dec 16 09:34:36.637944 2016] [:error] [pid 27598] )
>>> [Fri Dec 16 09:34:36.637946 2016] [:error] [pid 27598]
>>> [Fri Dec 16 09:34:36.637947 2016] [:error] [pid 27598]
>>> [Fri Dec 16 09:34:36.637998 2016] [:error] [pid 27598] 2016-12-16
>>> 09:34:36,637 INFO sqlalchemy.engine.base.Engine ()
>>> [Fri Dec 16 09:34:36.638017 2016] [:error] [pid 27598]
>>> INFO:sqlalchemy.engine.base.Engine:()
>>> [Fri Dec 16 09:34:36.638229 2016] [:error] [pid 27598] 2016
>>> I tried to deactivate the logging by doing :
>>> logging.basicConfig()
>>> logging.getLogger('sqlalchemy.engine').setLevel(logging.WARNING)
>>> in my wsgi file, but does no work.
>>> Am i missing something ?
>>> Thank you.
>>> Sylvain.
>>> pywps-dev mailing list
>>> pywps-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
>> Jachym Cepicky
>> e-mail: jachym.cepicky at gmail.com
>> twitter: @jachymc
Jachym Cepicky
twitter: @jachymc
More information about the pywps-dev mailing list
