[Pywps-dev] Deactivate sqlalchemy logging
Sylvain Beorchia sylvain.beorchia at gmail.com
Fri Dec 23 14:37:13 PST 2016
No.
Seems like my pywps.cfg is ignored. I checked my all drive, i've got only
one pywps.cfg. You can see it there :
https://friendpaste.com/26jVmZ4v26KAzEP0ptyZ6i
I haven't changed lots of things, and somes settings are incorrect (for
exemple : serveraddress=http://localhost/cgi-bin/wps). I use my wps server
 with wsgi, configured via apache.
Is it possible that other settings cause a bad reading of the logging
section ?
2016-12-23 23:08 GMT+01:00 Jáchym Čepický <jachym.cepicky at gmail.com>:
> So
> try 'WARNING'
> did it help?
> J
> Dne 23.12.2016 v 23:06 Sylvain Beorchia napsal(a):
> Hi Jachym,
>> Mmm not sure to well understand.
>> According to the doc, level=INFO is the default.
>> In dblog.py, we have :
>> level = configuration.get_config_value('logging', 'level')
>> if level in ['INFO']:
>>     echo = False
>> try:
>>     engine = sqlalchemy.create_engine(database, echo=echo)
>> If we set level = INFO (which is default), log shouldn't be activated. I
>> don't understand.
>> Anyway, i've tried the force the setting to INFO:
>> [logging]
>> level=INFO
>>  and no luck. I still have got lots of logs.
>> I'm going to try to debug that.
>> Sylvain.
>> 2016-12-23 16:53 GMT+01:00 Jáchym Čepický <jachym.cepicky at gmail.com>:
>> Hi,
>>> sorry for later response
>>> in PyWPS configuration file, you can set log level to anything but INFO -
>>> in that case, in dblog.py
>>> 172   engine = sqlalchemy.create_engine(database, echo=echo_level)
>>> echo_level will be set to False
>>> See
>>> http://pywps.readthedocs.io/en/latest/configuration.html#logging
>>> for how to set this in configuration file
>>> Is that ok?
>>> Jachym
>>> Dne 16.12.2016 v 09:41 Sylvain Beorchia napsal(a):
>>> Hi all,
>>>> Using my firsts pywps processes, i've got plenty of unwanted logs.
>>>> Here's
>>>> an extract :
>>>> [Fri Dec 16 09:34:36.637934 2016] [:error] [pid 27598]
>>>> INFO:sqlalchemy.engine.base.Engine:
>>>> [Fri Dec 16 09:34:36.637937 2016] [:error] [pid 27598] CREATE TABLE
>>>> pywps_stored_requests (
>>>> [Fri Dec 16 09:34:36.637938 2016] [:error] [pid 27598] \tuuid
>>>> VARCHAR(255)
>>>> NOT NULL,
>>>> [Fri Dec 16 09:34:36.637940 2016] [:error] [pid 27598] \trequest BLOB
>>>> NOT
>>>> NULL,
>>>> [Fri Dec 16 09:34:36.637942 2016] [:error] [pid 27598] \tPRIMARY KEY
>>>> (uuid)
>>>> [Fri Dec 16 09:34:36.637944 2016] [:error] [pid 27598] )
>>>> [Fri Dec 16 09:34:36.637946 2016] [:error] [pid 27598]
>>>> [Fri Dec 16 09:34:36.637947 2016] [:error] [pid 27598]
>>>> [Fri Dec 16 09:34:36.637998 2016] [:error] [pid 27598] 2016-12-16
>>>> 09:34:36,637 INFO sqlalchemy.engine.base.Engine ()
>>>> [Fri Dec 16 09:34:36.638017 2016] [:error] [pid 27598]
>>>> INFO:sqlalchemy.engine.base.Engine:()
>>>> [Fri Dec 16 09:34:36.638229 2016] [:error] [pid 27598] 2016
>>>> I tried to deactivate the logging by doing :
>>>> logging.basicConfig()
>>>> logging.getLogger('sqlalchemy.engine').setLevel(logging.WARNING)
>>>> in my wsgi file, but does no work.
>>>> Am i missing something ?
>>>> Thank you.
>>>> Sylvain.
>>>> _______________________________________________
>>>> pywps-dev mailing list
>>>> pywps-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
>>> Jachym Cepicky
>>> e-mail: jachym.cepicky at gmail.com
>>> twitter: @jachymc
> Jachym Cepicky
> twitter: @jachymc
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20161223/ffcfe347/attachment.html>
More information about the pywps-dev mailing list
