[Pywps-dev] unify PyWPS and pycsw configurations
Jachym Cepicky jachym.cepicky at gmail.com
Mon Jan 25 00:25:37 PST 2016
so +1 for this proposal, btw
po 25. 1. 2016 v 9:25 odesílatel Jachym Cepicky <jachym.cepicky at gmail.com>
napsal:
> Tom, I was about suggest the same - sections and renaming. Do you already
> have some documentation page, we could stick to?
> J
> so 23. 1. 2016 v 23:49 odesílatel Tom Kralidis <tomkralidis at gmail.com>
> napsal:
>> Hi all: the PyWPS and pycsw configurations are quite similar:
>> PyWPS: https://github.com/PyWPS/pywps-4-demo/blob/master/pywps.cfg
>> pycsw: https://github.com/geopython/pycsw/blob/master/default-sample.cfg
>> Given the similarities and that both PyWPS and pycsw are heading into
>> major releases (PyWPS 4, pycsw 2.0), it's a great time to work on unifying
>> these for common objects to align.
>> Proposal:
>> - unify server sections
>> - move PyWPS [wps] and [provider] sections into a single section called
>>   [metadata:main]
>> The benefit here would be a single config for both installs.  This would
>> not
>> limit each project from their own specific additional config sections
>> or options,
>> but would make the ones they share in common consistent and clear.
>> Thoughts?
>> ..Tom
>> pywps-dev mailing list
>> pywps-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160125/31824fe7/attachment.html>
More information about the pywps-dev mailing list
