[Pywps-dev] unify PyWPS and pycsw configurations
Tom Kralidis tom.kralidis at gmail.com
Mon Jan 25 03:23:16 PST 2016
Hi Jachym: sounds good. See the pycsw configuration doc at http://docs.pycsw.org/en/latest/configuration.html
Sent from my iPhone
> On Jan 25, 2016, at 03:25, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> so +1 for this proposal, btw
> po 25. 1. 2016 v 9:25 odesílatel Jachym Cepicky <jachym.cepicky at gmail.com> napsal:
>> Tom, I was about suggest the same - sections and renaming. Do you already have some documentation page, we could stick to?
>> J
>> so 23. 1. 2016 v 23:49 odesílatel Tom Kralidis <tomkralidis at gmail.com> napsal:
>>> Hi all: the PyWPS and pycsw configurations are quite similar:
>>> PyWPS: https://github.com/PyWPS/pywps-4-demo/blob/master/pywps.cfg
>>> pycsw: https://github.com/geopython/pycsw/blob/master/default-sample.cfg
>>> Given the similarities and that both PyWPS and pycsw are heading into
>>> major releases (PyWPS 4, pycsw 2.0), it's a great time to work on unifying
>>> these for common objects to align.
>>> Proposal:
>>> - unify server sections
>>> - move PyWPS [wps] and [provider] sections into a single section called
>>>   [metadata:main]
>>> The benefit here would be a single config for both installs.  This would not
>>> limit each project from their own specific additional config sections
>>> or options,
>>> but would make the ones they share in common consistent and clear.
>>> Thoughts?
>>> ..Tom
>>> pywps-dev mailing list
>>> pywps-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160125/cba5c1d0/attachment-0001.html>
More information about the pywps-dev mailing list
