[Pywps-dev] new website proposal
Tom Kralidis tomkralidis at gmail.com
Mon Jan 25 08:18:23 PST 2016
Hi Jachym: thanks.  OK, I have moved this to
https://github.com/geopython/pywps.org
and enabled push access to the PyWPS team.
..Tom
On Mon, 25 Jan 2016, Jachym Cepicky wrote:
> Date: Mon, 25 Jan 2016 08:14:09 +0000
> From: Jachym Cepicky <jachym.cepicky at gmail.com>
> To: Tom Kralidis <tomkralidis at gmail.com>,
>     "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
> Subject: Re: [Pywps-dev] new website proposal
> Hi Tom,
> I like the design and workflow
> Can you add me to the repository, so I could help with porting?
> J
> po 25. 1. 2016 v 4:14 odesílatel Tom Kralidis <tomkralidis at gmail.com>
> napsal:
>> Hi devs: FYI I've been working on a new setup of the PyWPS website
>> using GitHub pages and Jekyll.
>> It's a GitHub pages theme and works for multiple devices; the idea is
>> the website has "layout", which are pure html files.  The actual
>> pages, they are in Markdown format and the only branch is gh-pages.
>> Any `git push origin gh-pages` automagically updates the site.  Note
>> there is blog functionality which instantly provides an Atom feed.
>> The value proposition here is that the site can be easily managed and
>> built directly via GitHub, providing a new/fresh/modern/multi-device
>> look/feel/functionality, all within a single repository.
>> The GitHub repo is available at
>> https://github.com/tomkralidis/pywps.org and the result is live at
>> http://tomkralidis.github.io/pywps.org/
>> Comments/suggestions/improvements?  If this is good with everyone,
>> then I will start the grunt work of porting the content.
>> Cheers
>> ..Tom
>> pywps-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
