[Pywps-dev] new website proposal
Tom Kralidis tomkralidis at gmail.com
Mon Jan 25 19:58:31 PST 2016
Update: the website has been ported over in its entirety.  If
possible, please review and comment and change as desired. Notes:
- news items have been broken out into blogposts.  Result in
http://geopython.github.io/pywps.org/news/ (along with RSS feed
inhttp://geopython.github.io/pywps.org//feed.xml)
- if anyone has cloned the repository, please delete and clone again
as I have squashed a series of commits.  Should be stable moving
forward
- the 'docs' link is not populated yet as I am still trying to figure
out/navigate PyWPS docs (more on this later)
Thanks
..Tom
On Mon, Jan 25, 2016 at 11:18 AM, Tom Kralidis <tomkralidis at gmail.com> wrote:
> Hi Jachym: thanks.  OK, I have moved this to
> https://github.com/geopython/pywps.org
> and enabled push access to the PyWPS team.
> ..Tom
> On Mon, 25 Jan 2016, Jachym Cepicky wrote:
>> Date: Mon, 25 Jan 2016 08:14:09 +0000
>> From: Jachym Cepicky <jachym.cepicky at gmail.com>
>> To: Tom Kralidis <tomkralidis at gmail.com>,
>>     "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
>> Subject: Re: [Pywps-dev] new website proposal
>> Hi Tom,
>> I like the design and workflow
>> Can you add me to the repository, so I could help with porting?
>> J
>> po 25. 1. 2016 v 4:14 odesílatel Tom Kralidis <tomkralidis at gmail.com>
>> napsal:
>>> Hi devs: FYI I've been working on a new setup of the PyWPS website
>>> using GitHub pages and Jekyll.
>>> It's a GitHub pages theme and works for multiple devices; the idea is
>>> the website has "layout", which are pure html files.  The actual
>>> pages, they are in Markdown format and the only branch is gh-pages.
>>> Any `git push origin gh-pages` automagically updates the site.  Note
>>> there is blog functionality which instantly provides an Atom feed.
>>> The value proposition here is that the site can be easily managed and
>>> built directly via GitHub, providing a new/fresh/modern/multi-device
>>> look/feel/functionality, all within a single repository.
>>> The GitHub repo is available at
>>> https://github.com/tomkralidis/pywps.org and the result is live at
>>> http://tomkralidis.github.io/pywps.org/
>>> Comments/suggestions/improvements?  If this is good with everyone,
>>> then I will start the grunt work of porting the content.
>>> Cheers
>>> ..Tom
>>> pywps-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
