[Pywps-dev] pip install pywps
Jonas Eberle
jonas.eberle at gmx.de
Fri Jul 1 03:26:31 PDT 2016
Thanks, but is anyone able to install this? Still I get the same error (also on other servers):
(sentinel_py27)we32zac at geo01:~/swos_sentinel1> pip install pywps
Collecting pywps
Could not find a version that satisfies the requirement pywps (from versions: )
No matching distribution found for pywps
----- Am 1. Jul 2016 um 11:20 schrieb Jachym Cepicky <jachym.cepicky at gmail.com>:
> Submitting dist/pywps-3.2.6-py2.7.egg to https://pypi.python.org/pypi
> Server response (200): OK
> čt 30. 6. 2016 v 13:15 odesílatel Tom Kralidis < tomkralidis at gmail.com > napsal:
>> Jachym: I cut 3.2.6 release just now. Can you publish to PyPI adding the sdist
>> to the upload?
>> Sent from my iPhone
>> On Jun 29, 2016, at 14:40, Jachym Cepicky < jachym.cepicky at gmail.com > wrote:
>>> Hi,
>>> I have the kyes, but not sure, what I do - I had feeling, we published the most
>>> up-to-date version to pypi? Any hint what I should do?
>>> J
>>> st 29. 6. 2016 v 19:46 odesílatel Tom Kralidis < tomkralidis at gmail.com > napsal:
>>>> I'm able to reproduce.
>>>> Looks like the egg publishing is problematic for some reason.
>>>> Running the following always works (for other projects):
>>>> python setup.py sdist upload
>>>> This uploads a tar.gz which will work.
>>>> Perhaps we can cut 3.2.6 as I think PyPI has certain
>>>> rules on overriding versions. I think Jachym has the keys
>>>> to PyWPS' PyPI entry, but I can help if given access prives.
>>>> Thanks
>>>> ..Tom
>>>> On Wed, 29 Jun 2016, Jonas Eberle wrote:
>>>> > Date: Wed, 29 Jun 2016 12:06:24 -0500 (CDT)
>>>> > From: Jonas Eberle < jonas.eberle at gmx.de >
>>>> > To: pywps-dev at lists.osgeo.org
>>>> > Subject: [Pywps-dev] pip install pywps
>>>> > Dear all,
>>>>> I downladed the current OSGeo-Live 9.5 and tried to install pywps 3. But using
>>>> > sudo pip install pywps (Python 2.7), I get the following error:
>>>> > "Could not find a version that satisfies the requirement pywps"
>>>> > I can install other packages from PyPi without problems.
>>>> > Any ideas?
>>>> > Thanks,
>>>> > Jonas
>>>> _______________________________________________
>>>> pywps-dev mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160701/3b7e02ab/attachment.html>
More information about the pywps-dev
