[Pywps-dev] pip install pywps
Tom Kralidis
tomkralidis at gmail.com
Fri Jul 1 05:32:59 PDT 2016
As verified on IRC (#python), pip cannot install from eggs, only
source distributions or wheels. Alternatively, easy_install pywps will work.
Packages on PyPI should always have a source distribution (sdist) as a minimum
reqiurement. To add an sdist, from the pywps-3.2.6 tag, run:
python setup.py sdist upload
This will add a .tar.gz file made available on
https://pypi.python.org/pypi/pywps
..Tom
On Fri, 1 Jul 2016, Jonas Eberle wrote:
> Date: Fri, 1 Jul 2016 05:26:31 -0500 (CDT)
> From: Jonas Eberle <jonas.eberle at gmx.de>
> To: Jachym Cepicky <jachym.cepicky at gmail.com>
> Cc: Tom Kralidis <tomkralidis at gmail.com>, jonas eberle <jonas.eberle at gmx.de>,
> pywps-dev at lists.osgeo.org
> Subject: Re: [Pywps-dev] pip install pywps
> Thanks, but is anyone able to install this? Still I get the same error (also on other servers):
> (sentinel_py27)we32zac at geo01:~/swos_sentinel1> pip install pywps
> Collecting pywps
> Could not find a version that satisfies the requirement pywps (from versions: )
> No matching distribution found for pywps
> ----- Am 1. Jul 2016 um 11:20 schrieb Jachym Cepicky <jachym.cepicky at gmail.com>:
>> Submitting dist/pywps-3.2.6-py2.7.egg to https://pypi.python.org/pypi
>> Server response (200): OK
>> čt 30. 6. 2016 v 13:15 odesílatel Tom Kralidis < tomkralidis at gmail.com > napsal:
>>> Jachym: I cut 3.2.6 release just now. Can you publish to PyPI adding the sdist
>>> to the upload?
>>> Sent from my iPhone
>>> On Jun 29, 2016, at 14:40, Jachym Cepicky < jachym.cepicky at gmail.com > wrote:
>>>> Hi,
>>>> I have the kyes, but not sure, what I do - I had feeling, we published the most
>>>> up-to-date version to pypi? Any hint what I should do?
>>>> J
>>>> st 29. 6. 2016 v 19:46 odesílatel Tom Kralidis < tomkralidis at gmail.com > napsal:
>>>>> I'm able to reproduce.
>>>>> Looks like the egg publishing is problematic for some reason.
>>>>> Running the following always works (for other projects):
>>>>> This uploads a tar.gz which will work.
>>>>> Perhaps we can cut 3.2.6 as I think PyPI has certain
>>>>> rules on overriding versions. I think Jachym has the keys
>>>>> to PyWPS' PyPI entry, but I can help if given access prives.
>>>>> Thanks
>>>>> ..Tom
>>>>> On Wed, 29 Jun 2016, Jonas Eberle wrote:
>>>>>> Date: Wed, 29 Jun 2016 12:06:24 -0500 (CDT)
>>>>>> From: Jonas Eberle < jonas.eberle at gmx.de >
>>>>>> To: pywps-dev at lists.osgeo.org
>>>>>> Subject: [Pywps-dev] pip install pywps
>>>>>> Dear all,
>>>>>> I downladed the current OSGeo-Live 9.5 and tried to install pywps 3. But using
>>>>>> sudo pip install pywps (Python 2.7), I get the following error:
>>>>>> "Could not find a version that satisfies the requirement pywps"
>>>>>> I can install other packages from PyPi without problems.
>>>>>> Any ideas?
>>>>>> Thanks,
>>>>>> Jonas
>>>>> _______________________________________________
>>>>> pywps-dev mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev
