[Pywps-dev] process discovery
Tom Kralidis tomkralidis at gmail.com
Thu Mar 3 17:20:42 PST 2016
Hi all: I'm setting up http://demo.pywps.org as a demo space to
serve PyWPS instances as required.  The goal here is a minimal
configuration (assuming a PyWPS install), along with some Apache
setup.
In PyWPS 3, there was functionality to define a PYWPS_PROCESSES
environment variable.  There was also the ability to define this in the PyWPS
config.  Looks like this is not available in master branch
anymore.
Any plans on adding this back in the codebase?  The value here is being
able to deploy a single WPS (in my case WSGI) wrapper which operates
against multiple configurations and processes setups driven by a given
endpoint.
Or is there another/better way to acheive this?
..Tom
More information about the pywps-dev mailing list
