[Pywps-dev] [GSoC] Web-based administration plans
Jan Rudolf rudolja1 at fit.cvut.cz
Fri May 13 03:43:39 PDT 2016
Hello,
that's ok for me. yes, that would be great, I have time. What about in
National Library of Technology in Dejvice? I will be there all day until
18:00. If this place is ok for you, send me an email, when you will be
there, or you can call me - 603324495.
Have a nice day, Jan
Dne 2016-05-13 10:47, Jachym Cepicky napsal:
> jan, start with the rest api first
> I would suggest, we meet in prague and make some wire frames and we
> send it to mailing list for wider community review - would that be ok?
> are you free wednesday 18th May afternoon ?
> J
> st 4. 5. 2016 v 23:55 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz>
> napsal:
>> Thanks for answers Jachym, they help a lot with understanding.
>> Thanks
>> for suggesting the 65_maxoperations branch. I've already set up git
>> with
>> this branch and I am going to look closer at it in near future.
>>> I would like you to do application, which is part of PyWPS
>>> distribution, wich uses REST interface for process control (maybe
>> you
>>> can re-use some of Calin's work) and ideally provides WEB UI  too
>> If will everybody agree, I would like to start with basics of Web
>> UI.
>> The reasons are that, with the start of the coding period, semester
>> ends
>> and I've got finals, main time period about 2-3 weeks and it's very
>> important to me to succeed. So with this pressure, I would like to
>> start
>> with something easier to me. Thank you for understanding.
>> Could you specify, what do you want to be part of UI? How do you
>> imagine
>> the layout and all functions (or first for now)?
>> Thank you, Jan
>> Dne 2016-05-04 12:30, Jachym Cepicky napsal:
>>> Hi Jan,
>>> first of all, I suggest, you go on with the 65_maxoperations
>> branch,
>>> where basis for the administration interface is set and described
>> in
>>> my mail
>>> https://lists.osgeo.org/pipermail/pywps-dev/2016-April/000624.html
>>> I've added sample wsgi script (wsgi directory) to the branch,
>> which
>>> works with my Apache configuration. If I understand it correctly,
>>> flask is not good, when you need to run several threads in one
>>> incetance - it can not handle it (therefore there are some
>> attempts
>>> with starting flask on different ports - bad solution IMHO)
>>> The demo is there, so you can run your local instance of PyWPS
>> with
>>> flask server.
>>> rest.html was removed by @Calin (cced)
>>> https://github.com/PyWPS/pywps-4-demo/commits/master/templates -
>> maybe
>>> he could tell us, why that?
>>> In 65_maxoperations, processes are controlled with metadata stored
>> in
>>> sqlite database - they are running using multiprocessing package -
>> it
>>> chould be clear from pywps/app/Process.py
>> you
>>> ehm, I hope, I clarified at least some of your questions - if not,
>>> please keep pinging me
>>> J
>>> po 2. 5. 2016 v 22:34 odesílatel Jan Rudolf
>>> napsal:
>>>> Hello everyone,
>>>> I ran PyWPS and the demo application on my computer, read almost
>> all
>>>> documentation text, and want to discuss:
>>>> 1. In the demo application - there should be available /wpsadmin
>>>> page
>>>> and others /wpspadmin/* (declared in demo.py), there is an error,
>> I
>>>> added rest_app.debug = True after the Flask initialization (line
>> 94
>>>> in
>>>> demo.py) and there is rest.html template missing. Can you add it,
>>>> please?
>>>> 2. I first thought (before I was looking into code), that the
>>>> user/administrator just need to install PyWPS (and other
>> libraries)
>>>> and
>>>> set up Apache (or any other server) to some entry point and he is
>>>> done.
>>>> Is the user/administrator need to make some script like demo.py
>> with
>>>> the
>>>> declaration of all URLs and so on? Or is it also going to be the
>>>> purpose
>>>> of my work, because I will be creating web administration for it,
>> is
>>>> it
>>>> suppose to be built-in into PyWPS library?
>>>> 3. I ran search about controlling processes through Python -
>> found a
>>>> way
>>>> through the combination of  multiprocessing and psutil, but they
>> are
>>>> already there, but also in demo.py. Should be integrated into
>> PyWPS?
>>>> Thank you, Jan Rudolf
>>>> _______________________________________________
>>>> pywps-dev mailing list
>>>> pywps-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
