[Pywps-dev] [GSoC] Web-based administration plans
Jachym Cepicky jachym.cepicky at gmail.com
Fri May 13 01:47:59 PDT 2016
jan, start with the rest api first
I would suggest, we meet in prague and make some wire frames and we send it
to mailing list for wider community review - would that be ok?
are you free wednesday 18th May afternoon ?
J
st 4. 5. 2016 v 23:55 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz> napsal:
> Thanks for answers Jachym, they help a lot with understanding. Thanks
> for suggesting the 65_maxoperations branch. I've already set up git with
> this branch and I am going to look closer at it in near future.
> > I would like you to do application, which is part of PyWPS
> > distribution, wich uses REST interface for process control (maybe you
> > can re-use some of Calin's work) and ideally provides WEB UI  too
> If will everybody agree, I would like to start with basics of Web UI.
> The reasons are that, with the start of the coding period, semester ends
> and I've got finals, main time period about 2-3 weeks and it's very
> important to me to succeed. So with this pressure, I would like to start
> with something easier to me. Thank you for understanding.
> Could you specify, what do you want to be part of UI? How do you imagine
> the layout and all functions (or first for now)?
> Thank you, Jan
> Dne 2016-05-04 12:30, Jachym Cepicky napsal:
> > Hi Jan,
> > first of all, I suggest, you go on with the 65_maxoperations branch,
> > where basis for the administration interface is set and described in
> > my mail
> > https://lists.osgeo.org/pipermail/pywps-dev/2016-April/000624.html
> > I've added sample wsgi script (wsgi directory) to the branch, which
> > works with my Apache configuration. If I understand it correctly,
> > flask is not good, when you need to run several threads in one
> > incetance - it can not handle it (therefore there are some attempts
> > with starting flask on different ports - bad solution IMHO)
> > The demo is there, so you can run your local instance of PyWPS with
> > flask server.
> > rest.html was removed by @Calin (cced)
> > https://github.com/PyWPS/pywps-4-demo/commits/master/templates - maybe
> > he could tell us, why that?
> > In 65_maxoperations, processes are controlled with metadata stored in
> > sqlite database - they are running using multiprocessing package - it
> > chould be clear from pywps/app/Process.py
> > ehm, I hope, I clarified at least some of your questions - if not,
> > please keep pinging me
> > J
> > po 2. 5. 2016 v 22:34 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz>
> > napsal:
> >> Hello everyone,
> >> I ran PyWPS and the demo application on my computer, read almost all
> >> documentation text, and want to discuss:
> >> 1. In the demo application - there should be available /wpsadmin
> >> page
> >> and others /wpspadmin/* (declared in demo.py), there is an error, I
> >> added rest_app.debug = True after the Flask initialization (line 94
> >> in
> >> demo.py) and there is rest.html template missing. Can you add it,
> >> please?
> >> 2. I first thought (before I was looking into code), that the
> >> user/administrator just need to install PyWPS (and other libraries)
> >> and
> >> set up Apache (or any other server) to some entry point and he is
> >> done.
> >> Is the user/administrator need to make some script like demo.py with
> >> the
> >> declaration of all URLs and so on? Or is it also going to be the
> >> purpose
> >> of my work, because I will be creating web administration for it, is
> >> it
> >> suppose to be built-in into PyWPS library?
> >> 3. I ran search about controlling processes through Python - found a
> >> way
> >> through the combination of  multiprocessing and psutil, but they are
> >> already there, but also in demo.py. Should be integrated into PyWPS?
> >> Thank you, Jan Rudolf
> >> _______________________________________________
> >> pywps-dev mailing list
> >> pywps-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160513/54a8ede7/attachment.html>
More information about the pywps-dev mailing list
