[Pywps-dev] [GSOC] First week & my progress
Jachym Cepicky jachym.cepicky at gmail.com
Sun May 22 14:20:23 PDT 2016
thanks for the info. About "controlling": we need at least "kill", "pause"
and "resume" process. As far as I understand it, kill could be implemented
using os.kill (if you know the process ID from the operating system point
of view - it should be stored in the sqlite database for now). For pause
and resume, I would suggest to find similar way as hitting "ctrl-z" in the
command line, which "pauses" running process in the terminal and to get it
in frontend again, you run the "fg" command - if you undestand what I'm
talking about. I did not study, how this is usually done on system level
(in unix systems), this is just my practical observation
J
so 21. 5. 2016 v 23:14 odesílatel Jan Rudolf <rudolja1 at fit.cvut.cz> napsal:
> Hello,
> I want to inform you about my status: my semester in school ends
> tomorrow. I've got final exams from Graph algorithms this Thursday and
> from Linear algebra a week after. Hope, I make it without problems
> (these two are the hardest), the rest will be ok/not that time
> consuming.
> Jachym specified top 4 goals for me on IRC meeting:
> step 1: you get PyWPS up and running and you will be able to run several
> asynchronous processes on your computer
> step 2: find out, what is the python way to control (and if possible) in
> background running processes
> step 3: create API (rest) for this controlling
> step 4: if there is time, create web UI
> I have working PyWPS with Apache on my computer. Don't know if it's the
> case, that I have Mac OS, but I had a little bit trouble to set up
> according to Github - so I can check it later on Ubuntu for example
> and/or make a manual for Mac. So step 1 is done.
> Next is step 2. I would like to in next week or two create demonstrative
> applications (not interfering PyWPS repo) about possibilities of the
> control of processes in Python (with the focus on our functionality) as
> template cases for an integration into PyWPS source code. Then
> integration, REST API, so on...
> All the best, Jan Rudolf
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160522/83e2eca0/attachment.html>
More information about the pywps-dev mailing list
