[Pywps-dev] cite tests
Tom Kralidis tomkralidis at gmail.com
Wed Oct 12 16:40:13 PDT 2016
Update: see [1] for explanation/resolution.
PyWPS master fully passes 29/29 tests for OGC WPS CITE tests.  Great
job everyone!
..Tom
[1] https://github.com/opengeospatial/ets-wps10/issues/9
On Mon, Oct 3, 2016 at 10:30 AM, Tom Kralidis <tomkralidis at gmail.com> wrote:
> Hi Jachym: looks like a CITE issue.  I will bring up with OGC CITE to
> investigate.
> Thanks
> ..Tom
> On Mon, 3 Oct 2016, Jachym Cepicky wrote:
>> Date: Mon, 03 Oct 2016 13:27:51 +0000
>> From: Jachym Cepicky <jachym.cepicky at gmail.com>
>> To: "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
>> Subject: [Pywps-dev] cite tests
>> Hi,
>> I've tested your demo.pywps.org against OGC cite tests and I've found one
>> bug only. BUT:
>> The test log:
>> http://cite.opengeospatial.org/te2/viewTestLog.jsp?test=s0001/d1162e143_1/d1162e219_1/d253e54_1/d253e263_1
>> It says,
>> Log for test s0001/d1162e143_1/d1162e219_1/d253e54_1/d253e263_1
>> Test owsTests:ows-OWS.GetCapabilities-Exceptions.1 type Mandatory
>> default result Passed
>> (s0001/d1162e143_1/d1162e219_1/d253e54_1/d253e263_1)
>> Assertion: In the event that a GetCapabilities request cannot be
>> processed for any reason, the response entity shall include an
>> exception report. The exception code must be one of those listed in
>> Table 5.
>> Message d253e1209_1:
>>   GetCapabilities with no service parameter.  Pass if all of the
>> following conditions are true: (1) the response is schema valid; (2)
>> the root document is an ows:ExceptionReport document; (3) the
>> ExceptionReport shall have the "MissingParameterValue" exception code;
>> (4) theExceptionReport @locator value shall be that of the missing
>> parameter.
>> Message d253e1211_1:
>>   Version parameter: 1.0.0
>> Request d253e1215_1:
>>   Method: get
>>   URL:
>> http://demo.pywps.org/cite/wps?&version=1.0.0&request=GetCapabilities
>> Error in call to extension function {public org.w3c.dom.NodeList
>> com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String)
>> throws java.lang.Throwable}: Exception in extension function
>> java.lang.reflect.InvocationTargetException
>> Result: Failed
>> When I look at
>> the response is
>> E400:
>> <ows:ExceptionReport
>> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
>> version="1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> <ows:Exception exceptionCode="MissingParameterValue" locator="service">
>> <ows:ExceptionText>
>> service
>> </ows:ExceptionText>
>> </ows:Exception>
>> <div/>
>> </ows:ExceptionReport>
>> what is IMHO exactly, what the test is expecting, anybody sees the
>> problem? Because of I do not :-(
>> Thanks
>> Jachym
More information about the pywps-dev mailing list
