[Pywps-dev] cite tests
Jachym Cepicky jachym.cepicky at gmail.com
Thu Oct 13 13:07:15 PDT 2016
thank you for the info, closing #123 for now
čt 13. 10. 2016 v 1:40 odesílatel Tom Kralidis <tomkralidis at gmail.com>
napsal:
> Update: see [1] for explanation/resolution.
> PyWPS master fully passes 29/29 tests for OGC WPS CITE tests.  Great
> job everyone!
> ..Tom
> [1] https://github.com/opengeospatial/ets-wps10/issues/9
> On Mon, Oct 3, 2016 at 10:30 AM, Tom Kralidis <tomkralidis at gmail.com>
> wrote:
> > Hi Jachym: looks like a CITE issue.  I will bring up with OGC CITE to
> > investigate.
> > Thanks
> > ..Tom
> > On Mon, 3 Oct 2016, Jachym Cepicky wrote:
> >> Date: Mon, 03 Oct 2016 13:27:51 +0000
> >> From: Jachym Cepicky <jachym.cepicky at gmail.com>
> >> To: "pywps-dev at lists.osgeo.org" <pywps-dev at lists.osgeo.org>
> >> Subject: [Pywps-dev] cite tests
> >> Hi,
> >> I've tested your demo.pywps.org against OGC cite tests and I've found
> one
> >> bug only. BUT:
> >> The test log:
> http://cite.opengeospatial.org/te2/viewTestLog.jsp?test=s0001/d1162e143_1/d1162e219_1/d253e54_1/d253e263_1
> >> It says,
> >> Log for test s0001/d1162e143_1/d1162e219_1/d253e54_1/d253e263_1
> >> Test owsTests:ows-OWS.GetCapabilities-Exceptions.1 type Mandatory
> >> default result Passed
> >> (s0001/d1162e143_1/d1162e219_1/d253e54_1/d253e263_1)
> >> Assertion: In the event that a GetCapabilities request cannot be
> >> processed for any reason, the response entity shall include an
> >> exception report. The exception code must be one of those listed in
> >> Table 5.
> >> Message d253e1209_1:
> >>   GetCapabilities with no service parameter.  Pass if all of the
> >> following conditions are true: (1) the response is schema valid; (2)
> >> the root document is an ows:ExceptionReport document; (3) the
> >> ExceptionReport shall have the "MissingParameterValue" exception code;
> >> (4) theExceptionReport @locator value shall be that of the missing
> >> parameter.
> >> Message d253e1211_1:
> >>   Version parameter: 1.0.0
> >> Request d253e1215_1:
> >>   Method: get
> >>   URL:
> >> http://demo.pywps.org/cite/wps?&version=1.0.0&request=GetCapabilities
> >> Error in call to extension function {public org.w3c.dom.NodeList
> >> com.occamlab.te.TECore.request(org.w3c.dom.Document,java.lang.String)
> >> throws java.lang.Throwable}: Exception in extension function
> >> java.lang.reflect.InvocationTargetException
> >> Result: Failed
> >> When I look at
> >> the response is
> >> E400:
> >> <ows:ExceptionReport
> >> xsi:schemaLocation="http://www.opengis.net/ows/1.1
> >> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> >> version="1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1"
> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> >> <ows:Exception exceptionCode="MissingParameterValue" locator="service">
> >> <ows:ExceptionText>
> >> service
> >> </ows:ExceptionText>
> >> </ows:Exception>
> >> <div/>
> >> </ows:ExceptionReport>
> >> what is IMHO exactly, what the test is expecting, anybody sees the
> >> problem? Because of I do not :-(
> >> Thanks
> >> Jachym
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20161013/c3982dd4/attachment.html>
More information about the pywps-dev mailing list
