[Pywps-dev] Import qgis.core into PyWPS process
Jáchym Čepický
jachym.cepicky at gmail.com
Mon Jan 2 12:22:11 PST 2017
as Salvatore is writing, check your error.log file, there should be more
and maybe you will have to either fix PYTHONPATH, as Salvatore is
pointing out, or add
import sys
sys.path.append('/path/to/your/qgis/libs')
at beginning of the script
J
Dne 2.1.2017 v 20:31 Salvatore Larosa napsal(a):
> Hi,
> On Mon, Jan 2, 2017 at 4:31 PM, Eduardo Silverio da Silva <
> eduardosilverio1990 at gmail.com> wrote:
>> Hello people,
>> I have a python script that uses some classes from qgis and it runs
>> correctly in my standalone app (IDLE Python). But when I try to publish the
>> script through PyWPS (3.2.5), the process does not apear in the list of
>> GetCapabilities. I think the problem is with the following imports:
>> from qgis.core import *
>> from qgis.gui import *
>> from processing.core.Processing import Processing
>> When I comment these lines the algorithm is showed.
> I guess the problem is with your environment variable, you should add the
> QGIS python and plugins paths to PYTHONPATH and probably the QGIS lib path
> to LD_LIBRARY.
> Also, any error message could be useful in order to get some help from the
> community. :)
> Regards,
> -SL
> pywps-dev mailing list
> pywps-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pywps-dev
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
twitter: @jachymc
More information about the pywps-dev
