[Pywps-dev] Import qgis.core into PyWPS process
Salvatore Larosa
lrssvtml at gmail.com
Mon Jan 2 11:31:42 PST 2017
On Mon, Jan 2, 2017 at 4:31 PM, Eduardo Silverio da Silva <
eduardosilverio1990 at gmail.com> wrote:
> Hello people,
> I have a python script that uses some classes from qgis and it runs
> correctly in my standalone app (IDLE Python). But when I try to publish the
> script through PyWPS (3.2.5), the process does not apear in the list of
> GetCapabilities. I think the problem is with the following imports:
> from qgis.core import *
> from qgis.gui import *
> from processing.core.Processing import Processing
> When I comment these lines the algorithm is showed.
I guess the problem is with your environment variable, you should add the
QGIS python and plugins paths to PYTHONPATH and probably the QGIS lib path
to LD_LIBRARY.
Also, any error message could be useful in order to get some help from the
community. :)
Regards,
-SL
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20170102/16c7aec6/attachment.html>
More information about the pywps-dev
