[PyWPS-dev] WPS-REST binding
Carsten Ehbrecht ehbrecht at dkrz.de
Thu Dec 10 04:12:33 PST 2020
Hi Idan,
There is no wps-rest-api implementation in PyWPS yet. But there is a middleware application called weaver which has a wps-rest-api (close to the current specs) and can delegate to the PyWPS WPS 1.0.0  api:
https://github.com/crim-ca/weaver/tree/master/weaver/wps_restapi
Cheers,
Carsten
Carsten Ehbrecht
Abteilung Datenmanagement
Deutsches Klimarechenzentrum GmbH (DKRZ)
Bundesstraße 45 a • D-20146 Hamburg • Germany
Phone: +49 40 460094-148
FAX:   +49 40 460094-270
Email: ehbrecht at dkrz.de
URL:   www.dkrz.de
Geschäftsführer: Prof. Dr. Thomas Ludwig
Sitz der Gesellschaft: Hamburg
Amtsgericht Hamburg HRB 39784
> On 26. Nov 2020, at 22:10, Idan Miara <idan at miara.com> wrote:
> Hi,
> Did anyone work on implementation for WPS-REST binding in PyWPS?
> https://github.com/opengeospatial/wps-rest-binding
> https://github.com/opengeospatial/wps-rest-binding/blob/master/implementations.adoc
> Idan
> On Fri, 1 May 2020 at 23:47, Jachym Cepicky <jachym at cepicky.ch> wrote:
> Hi,
> sorry for late response
> even pywps internally is using json encoding, there is no way so far,
> how to send such request from the client
> you may have a look at
> https://github.com/opengeospatial/wps-rest-binding/blob/master/README.md
> which somehow defines the future development
> Jachym
> čt 2. 4. 2020 v 21:25 odesílatel Idan Miara <idan at miara.com> napsal:
> > Hi all,
> > I would like to inquire about building an Angular based client for a pyWPS service.
> > What would be an idiomatic way to create WPS requests in Angular (preferably) or in JavaScript?
> > As far as I could find WPS only accepts simple requests by GET and complex requests by POST with XML content type.
> > Is there a way to send POST requests in JSON format instead of XML?
> > Is there a way to send BoundingBoxInput or ComplexInput by GET or is it just LiteralInput?
> > Any pointers are appreciated!
> > Kind regards,
> > Idan
> > pywps-dev mailing list
> > pywps-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/pywps-dev
More information about the pywps-dev mailing list
