[PyWPS-dev] WPS-REST binding
Idan Miara idan at miara.com
Thu Dec 10 05:31:06 PST 2020
Hi Jachym, Carsten and all,
Thanks for your references.
I haven't got the time to look at the `current specs`.
I wanted to make a minimalistic JSON request support that would be easy to
use.
By minimalistic I mean much less verbose then the XML request spec.
https://github.com/geopython/pywps/pull/554
I'd be happy to get your feedback.
Also, I see that `Master` and `pywps-4.2` were diverged at 4.2.4, was that
intentional?
Idan
On Thu, 10 Dec 2020 at 14:12, Carsten Ehbrecht <ehbrecht at dkrz.de> wrote:
> Hi Idan,
> There is no wps-rest-api implementation in PyWPS yet. But there is a
> middleware application called weaver which has a wps-rest-api (close to the
> current specs) and can delegate to the PyWPS WPS 1.0.0  api:
> https://github.com/crim-ca/weaver/tree/master/weaver/wps_restapi
> Cheers,
> Carsten
> Carsten Ehbrecht
> Abteilung Datenmanagement
> Deutsches Klimarechenzentrum GmbH (DKRZ)
> Bundesstraße 45 a • D-20146 Hamburg • Germany
> Phone: +49 40 460094-148
> FAX:   +49 40 460094-270
> Email: ehbrecht at dkrz.de
> URL:   www.dkrz.de
> Geschäftsführer: Prof. Dr. Thomas Ludwig
> Sitz der Gesellschaft: Hamburg
> Amtsgericht Hamburg HRB 39784
> > On 26. Nov 2020, at 22:10, Idan Miara <idan at miara.com> wrote:
> > Hi,
> > Did anyone work on implementation for WPS-REST binding in PyWPS?
> > https://github.com/opengeospatial/wps-rest-binding
> https://github.com/opengeospatial/wps-rest-binding/blob/master/implementations.adoc
> > Idan
> > On Fri, 1 May 2020 at 23:47, Jachym Cepicky <jachym at cepicky.ch> wrote:
> > Hi,
> > sorry for late response
> > even pywps internally is using json encoding, there is no way so far,
> > how to send such request from the client
> > you may have a look at
> > https://github.com/opengeospatial/wps-rest-binding/blob/master/README.md
> > which somehow defines the future development
> > Jachym
> > čt 2. 4. 2020 v 21:25 odesílatel Idan Miara <idan at miara.com> napsal:
> > > Hi all,
> > > I would like to inquire about building an Angular based client for a
> pyWPS service.
> > > What would be an idiomatic way to create WPS requests in Angular
> (preferably) or in JavaScript?
> > > As far as I could find WPS only accepts simple requests by GET and
> complex requests by POST with XML content type.
> > > Is there a way to send POST requests in JSON format instead of XML?
> > > Is there a way to send BoundingBoxInput or ComplexInput by GET or is
> it just LiteralInput?
> > > Any pointers are appreciated!
> > > Kind regards,
> > > Idan
> > > _______________________________________________
> > > pywps-dev mailing list
> > > pywps-dev at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20201210/f1626344/attachment.html>
More information about the pywps-dev mailing list
