[QGIS Commit] r8351 - in trunk/qgis: . debian
python/plugins/plugin_installer src/core src/gui src/providers/grass
svn_qgis at osgeo.org
Mon Apr 14 17:30:22 EDT 2008
Author: jef
Date: 2008-04-14 17:30:22 -0400 (Mon, 14 Apr 2008)
New Revision: 8351
Added:
trunk/qgis/debian/libqgis-core0.9.install
trunk/qgis/debian/libqgis-gui0.9.install
trunk/qgis/debian/libqgisgrass0.9.install
trunk/qgis/debian/python-qgis.install
trunk/qgis/debian/qgis-icon.xpm
trunk/qgis/qgis_help.man
Removed:
trunk/qgis/debian/gridmaker.1
trunk/qgis/debian/libqgis1.install
trunk/qgis/debian/qgis-config.1
trunk/qgis/debian/qgis-icon.png
trunk/qgis/debian/qgis.1
trunk/qgis/debian/qgis.postinst.debhelper
trunk/qgis/debian/qgis.postrm.debhelper
trunk/qgis/CMakeLists.txt
trunk/qgis/debian/changelog
trunk/qgis/debian/control
trunk/qgis/debian/copyright
trunk/qgis/debian/libqgis1-dev.install
trunk/qgis/debian/qgis-plugin-grass.install
trunk/qgis/debian/qgis.install
trunk/qgis/debian/qgis.menu
trunk/qgis/debian/rules
trunk/qgis/python/plugins/plugin_installer/qgis_plugins.py
trunk/qgis/qgis.man
trunk/qgis/src/core/CMakeLists.txt
trunk/qgis/src/gui/CMakeLists.txt
trunk/qgis/src/providers/grass/CMakeLists.txt
debian packaging update
- update for next release
- removed some temporary files in debian/
- add version number to shared libraries names and split them into
libqgis-core0.9, libqgis-gui0.9 and libqgisgrass0.9 (fixes #36)
- split python binding and plugins into separate package python-qgis
- merge some changes from the DebianGIS repository
- build in debian/build
- updated menu and icon
- use qgis man pages (qgis_help added)
- build on Debian unstable is lintian clean (may fix #1028)
- build also tested on OSX (Tim Sutton), MinGW (Marco Pasetti) and with MSVC
Modified: trunk/qgis/CMakeLists.txt
--- trunk/qgis/CMakeLists.txt 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/CMakeLists.txt 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,5 +1,12 @@
-PROJECT(qgis0.9.2)
+SET(CPACK_PACKAGE_VERSION_MAJOR "0")
+SET(CPACK_PACKAGE_VERSION_MINOR "9")
+SET(CPACK_PACKAGE_VERSION_PATCH "2")
+SET(PROJECT_VERSION ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH})
+PROJECT(qgis${PROJECT_VERSION})
# TODO:
# - install includes for libs
# - nice output when configured
@@ -164,10 +171,10 @@
IF (WIN32)
SET (DEFAULT_BIN_SUBDIR .)
- SET (DEFAULT_LIB_SUBDIR .)
+ SET (DEFAULT_LIB_SUBDIR lib)
SET (DEFAULT_DATA_SUBDIR .)
SET (DEFAULT_PLUGIN_SUBDIR plugins)
- SET (DEFAULT_INCLUDE_SUBDIR include)
+ SET (DEFAULT_INCLUDE_SUBDIR include)
IF (MSVC)
# Python parts need to be build with nmake not vcexpress
@@ -178,12 +185,12 @@
# put all the build products into a single directory
# under build (doesnt affect install target) to make for
# easier debugging.
- SET(OUTPUT_DIR ${CMAKE_CURRENT_SOURCE_DIR}/bin)
- SET(EXECUTABLE_OUTPUT_PATH ${OUTPUT_DIR})
- SET(LIBRARY_OUTPUT_PATH ${OUTPUT_DIR})
+ # SET(OUTPUT_DIR ${CMAKE_CURRENT_SOURCE_DIR}/bin)
+ # SET(EXECUTABLE_OUTPUT_PATH ${OUTPUT_DIR})
+ # SET(LIBRARY_OUTPUT_PATH ${OUTPUT_DIR})
#tell msvc compiler to use main instead of winmain as the
#application entry point
- SET(QT_USE_QTMAIN TRUE)
+ #SET(QT_USE_QTMAIN TRUE)
# Turn on defines for non standard maths stuff
ADD_DEFINITIONS(-D_USE_MATH_DEFINES)
@@ -197,8 +204,9 @@
ADD_DEFINITIONS(-DW_OK=2)
ADD_DEFINITIONS(-DR_OK=4)
- FILE(GLOB files "${CMAKE_SOURCE_DIR}/win_build/vcdeps/*.*")
- INSTALL(FILES ${files} DESTINATION .)
+ ADD_DEFINITIONS(-DQGISDEBUG=1)
+ INSTALL(DIRECTORY ${CMAKE_SOURCE_DIR}/win_build/vcdeps/. DESTINATION .)
ENDIF(MSVC)
ELSE (WIN32)
@@ -258,11 +266,11 @@
MARK_AS_ADVANCED (QGIS_BIN_SUBDIR QGIS_LIB_SUBDIR QGIS_DATA_SUBDIR QGIS_PLUGIN_SUBDIR QGIS_INCLUDE_SUBDIR)
# full paths for the installation
-SET (QGIS_BIN_DIR ${CMAKE_INSTALL_PREFIX}/${QGIS_BIN_SUBDIR})
-SET (QGIS_LIB_DIR ${CMAKE_INSTALL_PREFIX}/${QGIS_LIB_SUBDIR})
-SET (QGIS_DATA_DIR ${CMAKE_INSTALL_PREFIX}/${QGIS_DATA_SUBDIR})
-SET (QGIS_PLUGIN_DIR ${CMAKE_INSTALL_PREFIX}/${QGIS_PLUGIN_SUBDIR})
-SET (QGIS_INCLUDE_DIR ${CMAKE_INSTALL_PREFIX}/${QGIS_INCLUDE_SUBDIR})
+SET (QGIS_BIN_DIR ${QGIS_BIN_SUBDIR})
+SET (QGIS_LIB_DIR ${QGIS_LIB_SUBDIR})
+SET (QGIS_DATA_DIR ${QGIS_DATA_SUBDIR})
+SET (QGIS_PLUGIN_DIR ${QGIS_PLUGIN_SUBDIR})
+SET (QGIS_INCLUDE_DIR ${QGIS_INCLUDE_SUBDIR})
# manual page - makes sense only on unix systems
IF (UNIX)
@@ -348,16 +356,13 @@
INCLUDE(InstallRequiredSystemLibraries)
SET(CPACK_PACKAGE_DESCRIPTION_SUMMARY "Quantum GIS")
-SET(CPACK_PACKAGE_VENDOR "Tim Sutton")
+SET(CPACK_PACKAGE_VENDOR "Open Source Geospatial Foundation")
SET(CPACK_PACKAGE_DESCRIPTION_FILE "${CMAKE_CURRENT_SOURCE_DIR}/README")
SET(CPACK_RESOURCE_FILE_LICENSE "${CMAKE_CURRENT_SOURCE_DIR}/COPYING")
-SET(CPACK_PACKAGE_VERSION_MAJOR "0")
-SET(CPACK_PACKAGE_VERSION_MINOR "9")
-SET(CPACK_PACKAGE_VERSION_PATCH "1")
SET(CPACK_PACKAGE_INSTALL_DIRECTORY "Quantum GIS ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}")
IF(WIN32 AND NOT UNIX)
# There is a bug in NSI that does not handle full unix paths properly. Make
- # sure there is at least one set of four (4) backlasshes.
+ # sure there is at least one set of four (4) backslashes.
SET(CPACK_PACKAGE_ICON "${CMAKE_SOURCE_DIR}/win_build\\\\sidebar.bmp")
SET(CPACK_NSIS_INSTALLED_ICON_NAME "\\\\qgis.exe")
SET(CPACK_NSIS_DISPLAY_NAME "${CPACK_PACKAGE_INSTALL_DIRECTORY} Quantum GIS")
@@ -373,4 +378,3 @@
ENDIF(WIN32 AND NOT UNIX)
SET(CPACK_PACKAGE_EXECUTABLES "qgis" "QGIS")
INCLUDE(CPack)
Modified: trunk/qgis/debian/changelog
--- trunk/qgis/debian/changelog 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/changelog 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,3 +1,9 @@
+qgis (0.9.2test2) unstable; urgency=low
+ * fixed various packaging bugs
+ -- Jürgen E. Fischer <jef at norbit.de> Sun, 13 Apr 2008 03:51:14 +0200
qgis (0.9.2test1) gutsy; urgency=low
* Testing package to see if icons deploy
Modified: trunk/qgis/debian/control
--- trunk/qgis/debian/control 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/control 2008-04-14 21:30:22 UTC (rev 8351)
@@ -9,11 +9,14 @@
sharutils, sip4 (>= 4.4), libqt4-core (>=4.2.0), libqt4-dev (>=4.2.0), libqt4-gui (>=4.2.0),
libqt4-qt3support (>=4.2.0), libqt4-sql (>=4.2.0), python-qt4 (>=4.0.0), python-qt4-dev (>=4.0.0)
Standards-Version: 3.7.2
+XS-Python-Version: current
+Homepage: http://qgis.org/
Package: qgis
Architecture: any
-Depends: ${shlibs:Depends}, ${misc:Depends}, libqgis1
-Suggests: qgis-plugin-grass, python, python-qt4, python-sip4
+Depends: ${shlibs:Depends}, ${misc:Depends}, libqgis-core0.9, libqgis-gui0.9
+Suggests: qgis-plugin-grass, python-qgis
+XB-Python-Version: ${python:Versions}
Description: Geographic Information System (GIS)
A Geographic Information System (GIS) manages,
analyzes, and displays databases of geographic
@@ -25,26 +28,51 @@
of various georeferenced raster and Digital
Elevation Model (DEM) formats including
GeoTIFF, Arc/Info ASCII Grid, and USGS ASCII DEM.
+Package: libqgis-core0.9
+Architecture: any
+Replaces: qgis (<=0.9.2rc1)
+Conflicts: libqgis1
+Description: QGIS Geographic Information System - shared core library
+ QGIS is a Geographic Information System (GIS)
+ which manages, analyzes and display databases of
+ geographic information.
- Home page: http://qgis.org/
+ This package contains the shared core library that
+ provides an interface for plugins.
-Package: libqgis1
+Package: libqgis-gui0.9
Architecture: any
-Description: QGIS Geographic Information System - shared library
+Description: QGIS Geographic Information System - shared gui library
- This package contains the shared library that
+ This package contains the shared gui library that
+Package: python-qgis
+Architecture: any
+Section: python
+Depends: ${shlibs:Depends}, ${misc:Depends}, ${python:Depends}, libqgis-core0.9, libqgis-gui0.9
+Provides: ${python:Provides}
+Description: QGIS Geographic Information System - Python bindings and plugins
+ This package contains the Python bindings and
+ plugins.
Package: libqgis1-dev
Architecture: any
-Depends: qgis (= ${Source-Version}), libgdal1-dev | libgdal1-1.3.2-dev , libpq-dev | postgresql-dev, libgeos-dev (>= 2.0.1-1), grass-dev, libsqlite3-dev, libgsl0-dev, proj, libexpat1-dev, libqt4-core (>=4.2.0), libqt4-dev (>=4.2.0), libqt4-gui (>=4.2.0), libqt4-qt3support (>=4.2.0), libqt4-sql (>=4.2.0), python-qt4 (>=4.0.0), python-qt4-dev (>=4.0.0), qt4-designer (>=4.2.0)
+Section: libdevel
+Depends: qgis (= ${binary:Version}), libgdal1-dev | libgdal1-1.3.2-dev , libpq-dev | postgresql-dev, libgeos-dev (>= 2.0.1-1), grass-dev, libsqlite3-dev, libgsl0-dev, proj, libexpat1-dev, libqt4-core (>=4.2.0), libqt4-dev (>=4.2.0), libqt4-gui (>=4.2.0), libqt4-qt3support (>=4.2.0), libqt4-sql (>=4.2.0), python-qt4 (>=4.0.0), python-qt4-dev (>=4.0.0), qt4-designer (>=4.2.0)
Provides: libqgis-dev
Conflicts: libqgis-dev, qgis-dev
Replaces: qgis-dev
@@ -56,14 +84,20 @@
This package contains the headers and libraries
needed to develop plugins for QGIS.
Package: qgis-plugin-grass
Architecture: any
-Depends: qgis (= ${Source-Version}), libgdal1-1.4.0-grass | libgdal1-1.3.2-grass
+Depends: qgis (= ${binary:Version}), ${shlibs:Depends}, ${misc:Depends}, libgdal1-1.4.0-grass | libgdal1-1.3.2-grass, libqgisgrass0.9
Description: Plugin for accessing GRASS data from QGIS
This plugin enables a GRASS data access toolbox in the QGIS
geographic data viewer.
+Package: libqgisgrass0.9
+Architecture: any
+Description: QGIS Geographic Information System - shared grass library
+ This package contains the shared library for the grass plugin.
Modified: trunk/qgis/debian/copyright
--- trunk/qgis/debian/copyright 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/copyright 2008-04-14 21:30:22 UTC (rev 8351)
@@ -2,19 +2,23 @@
Wed, 31 Dec 2003 10:07:40 -0500.
It was downloaded from:
- http://qgis.sourceforge.net/downloads.html
+ https://svn.osgeo.org/qgis/trunk/qgis
The upstream contributors are listed in the AUTHORS file.
+Copyright:
+ (C) 2008 the authors
-This program is free software; you can redistribute it and/or
-modify it under the terms of the GNU General Public License as
-published by the Free Software Foundation; either version 2 of
-the License, or (at your option) any later version.
+ This program is free software; you can redistribute it and/or
+ modify it under the terms of the GNU General Public License as
+ published by the Free Software Foundation; either version 2 of
+ the License, or (at your option) any later version.
-This program is distributed in the hope that it will be useful,
-but WITHOUT ANY WARRANTY; without even the implied warranty of
-MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-GNU General Public License for more details.
+ This program is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ GNU General Public License for more details.
-On Debian systems, the complete text of the GNU General Public
-License can be found in the /usr/share/common-licenses/GPL file.
+ On Debian systems, the complete text of the GNU General Public
+ License can be found in the /usr/share/common-licenses/GPL file.
Deleted: trunk/qgis/debian/gridmaker.1
--- trunk/qgis/debian/gridmaker.1 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/gridmaker.1 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,11 +0,0 @@
-.TH gridmaker 1 "August 2004" "gridmaker" "User Commands"
-.SH NAME
-gridmaker \- Graticule builder
-.SH SYNOPSIS
-.PP
-.B gridmaker
-[OPTIONS]
-.SH DESCRIPTION
-.PP
-The \fIgridmaker\fP qgis plugin will help you to build a graticule shapefile
-that you can use as an overlay within your qgis map viewer.
Added: trunk/qgis/debian/libqgis-core0.9.install
--- trunk/qgis/debian/libqgis-core0.9.install (rev 0)
+++ trunk/qgis/debian/libqgis-core0.9.install 2008-04-14 21:30:22 UTC (rev 8351)
@@ -0,0 +1 @@
+usr/lib/libqgis_core.so.*
Added: trunk/qgis/debian/libqgis-gui0.9.install
--- trunk/qgis/debian/libqgis-gui0.9.install (rev 0)
+++ trunk/qgis/debian/libqgis-gui0.9.install 2008-04-14 21:30:22 UTC (rev 8351)
@@ -0,0 +1 @@
+usr/lib/libqgis_gui.so.*
Modified: trunk/qgis/debian/libqgis1-dev.install
--- trunk/qgis/debian/libqgis1-dev.install 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/libqgis1-dev.install 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,22 +1 @@
-#usr/bin/qgis-config
-#usr/lib/libqgis*a
usr/include/qgis/*
-#usr/share/aclocal/qgis.m4
-#usr/lib/qgis/copyrightlabelplugin.a
-#usr/lib/qgis/libqgsprojectionselector.a
-#usr/lib/qgis/delimitedtextplugin.a
-#usr/lib/qgis/northarrowplugin.a
-#usr/lib/qgis/delimitedtextprovider.a
-#usr/lib/qgis/ogrprovider.a
-#usr/lib/qgis/georefplugin.a
-#usr/lib/qgis/pggeoprocessingplugin.a
-#usr/lib/qgis/gpsimporterplugin.a
-#usr/lib/qgis/postgresprovider.a
-#usr/lib/qgis/gpxprovider.a
-#usr/lib/qgis/scalebarplugin.a
-#usr/lib/qgis/grassplugin.a
-#usr/lib/qgis/spitplugin.a
-#usr/lib/qgis/grassprovider.a
-#usr/lib/qgis/wmsprovider.a
-#usr/lib/qgis/gridmakerplugin.a
Deleted: trunk/qgis/debian/libqgis1.install
--- trunk/qgis/debian/libqgis1.install 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/libqgis1.install 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,5 +0,0 @@
-#usr/lib/libqgis_composer.so*
-usr/lib/libqgis_core.so*
-/usr/lib/libqgis_gui.so
-#usr/lib/libqgis_legend.so*
-#usr/lib/libqgis_raster.so*
Added: trunk/qgis/debian/libqgisgrass0.9.install
--- trunk/qgis/debian/libqgisgrass0.9.install (rev 0)
+++ trunk/qgis/debian/libqgisgrass0.9.install 2008-04-14 21:30:22 UTC (rev 8351)
@@ -0,0 +1 @@
+usr/lib/libqgisgrass.so.*
Added: trunk/qgis/debian/python-qgis.install
--- trunk/qgis/debian/python-qgis.install (rev 0)
+++ trunk/qgis/debian/python-qgis.install 2008-04-14 21:30:22 UTC (rev 8351)
@@ -0,0 +1,4 @@
+usr/share/qgis/python/*
+usr/lib/python*/site-packages/qgis/__init__.py
+usr/lib/python*/site-packages/qgis/qgisconfig.py
+usr/lib/python*/site-packages/qgis/*.so
Deleted: trunk/qgis/debian/qgis-config.1
--- trunk/qgis/debian/qgis-config.1 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/qgis-config.1 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,44 +0,0 @@
-.TH qgis-config 1 "August 2004" "qgis-config" "User Commands"
-.SH NAME
-qgis-config \- returns information about installed qgis libraries and binaries
-.SH SYNOPSIS
-.PP
-.B qgis-config
-[OPTIONS]
-.SH DESCRIPTION
-.PP
-The \fIqgis-config\fP shell script is designed to retrieve the
-configuration information about the libraries and binaries dealing with
-QGIS
-.SH OPTIONS
-.TP
-\fB\-\-cflags\fR
-print the prefix used by qgis
-.TP
-\fB\-\-bindir\fR
-print destination of executable(s)
-.TP
-\fB\-\-cflags\fR
-print the compiler flags that are necessary to compile a
-plug-inshow location of C++ header files
-.TP
-\fB\-\-libs\fR
-print the linker flags that are necessary to link a plug-in
-.TP
-\fB\-\-plugindir\fR
-print the path where the plugins are installed
-.TP
-\fB\-\-major_version\fR
-print major version of qgis
-.TP
-\fB\-\-minor_version\fR
-print minor version of qgis
-.TP
-\fB\-\-micro_version\fR
-print micro version of qgis
-.TP
-\fB\-\-extra_version\fR
-print extra version of qgis
-\fB\-\-help\fR
-show help, then exit
Deleted: trunk/qgis/debian/qgis-icon.png
(Binary files differ)
Added: trunk/qgis/debian/qgis-icon.xpm
--- trunk/qgis/debian/qgis-icon.xpm (rev 0)
+++ trunk/qgis/debian/qgis-icon.xpm 2008-04-14 21:30:22 UTC (rev 8351)
@@ -0,0 +1,170 @@
+/* XPM */
+static char *qgis_icon[] = {
+/* columns rows colors chars-per-pixel */
+"32 32 132 2",
+" c #070C05",
+". c #0B2605",
+"X c #072E01",
+"o c #0A2F04",
+"O c #063300",
+"+ c #083602",
+"@ c #1F3E11",
+"# c #203115",
+"$ c #0A4301",
+"% c #094A00",
+"& c #1A4A0D",
+"* c #095100",
+"= c #0A5B00",
+"- c #1C550D",
+"; c #1E4810",
+": c #31431F",
+"> c #0B6300",
+", c #0C6A00",
+"< c #156707",
+"1 c #1C660B",
+"2 c #1A6A09",
+"3 c #0E7400",
+"4 c #0F7B00",
+"5 c #147605",
+"6 c #147A04",
+"7 c #187D07",
+"8 c #20720F",
+"9 c #266614",
+"0 c #267B11",
+"q c #327A1A",
+"w c #364E21",
+"e c #44472C",
+"r c #505334",
+"t c #555837",
+"y c #5C5F3C",
+"u c #426E26",
+"i c #427F26",
+"p c #47722B",
+"a c #646740",
+"s c #6C6F48",
+"d c #717549",
+"f c #74794A",
+"g c #797E4E",
+"h c #7B7E51",
+"j c #7C7E5B",
+"k c #0F8001",
+"l c #118401",
+"z c #118A01",
+"x c #1A8C07",
+"c c #1C8109",
+"v c #1C8B09",
+"b c #2D8E15",
+"n c #2F9315",
+"m c #549431",
+"M c #67903F",
+"N c #53A62F",
+"B c #60A738",
+"V c #6A8F41",
+"C c #728D47",
+"Z c #78914F",
+"A c #7E8251",
+"S c #7DAD57",
+"D c #7CB255",
+"F c #808352",
+"G c #858A56",
+"H c #91975E",
+"J c #959D5F",
+"K c #83AD51",
+"L c #90A75C",
+"P c #94A85E",
+"I c #969A60",
+"U c #9EA266",
+"Y c #95A866",
+"T c #9BAC62",
+"R c #A2AA69",
+"E c #A1B866",
+"W c #A6B36A",
+"Q c #ACB26F",
+"! c #A9AD73",
+"~ c #ACB672",
+"^ c #B1B477",
+"/ c #B7BE77",
+"( c #B8BE76",
+") c #B9BF79",
+"_ c #B9C476",
+"` c #BCC47A",
+"' c #BCCD79",
+"] c #C3CB7D",
+"[ c #BCBF86",
+"{ c #B9C887",
+"} c #BEC98B",
+"| c #C1C483",
+" . c #C7CE80",
+".. c #C8CF80",
+"X. c #C4CA8D",
+"o. c #CCD383",
+"O. c #C7DC80",
+"+. c #D0D786",
+"@. c #D2DB87",
+"#. c #D2D788",
+"$. c #D4DC88",
+"%. c #C6C792",
+"&. c #D1D396",
+"*. c #D9DE93",
+"=. c #DCDE9B",
+"-. c #DCE38D",
+";. c #DEE491",
+":. c #DEE19B",
+">. c #E4EC93",
+",. c #E4E69D",
+"<. c #E7E89E",
+"1. c #E8E99C",
+"2. c #EAF296",
+"3. c #EDF599",
+"4. c #F1F69D",
+"5. c #F5F99F",
+"6. c #D5D6A0",
+"7. c #DADBA2",
+"8. c #ECEEA1",
+"9. c #E2E4AD",
+"0. c #EEF2A3",
+"q. c #F2F7A3",
+"w. c #F5F9A3",
+"e. c #FAFCA4",
+"r. c #F2F5AB",
+"t. c #F7FBAA",
+"y. c #F9FAAC",
+"u. c #F9FCB1",
+"i. c #F3F4BA",
+"p. c #FAFBBB",
+"a. c #FCFCC4",
+"s. c None",
+/* pixels */
+"s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.l s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.z z 4 s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.z z z 3 s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.4 z z z 4 3 = s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.< , 4 3 , * s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.s.s.s.s.9.6.%.&.=.:.Z 9 = 3 , > % s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.s.a.p.u.! h s.s.` ;.O.N l 4 > * O s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.a.u.0.;.s s.s.s.s.' B n l 1 $ X s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.p.p.w.>.o.e s.s.s.s.K n v c u w s.s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.a.p.w.3.$.Q s.s.s.s.s.5 z 7 q J H s.s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.u.t.3.2.o.H s.s.s.s.l l l i C o.o.` s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.p.y.w.3.2.o.G s.s.s.s.l l 0 M T >.-. .s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.p.w.4.3.2...g s.s.s.4 l x p T o.3.>.+.s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.u.4.3.3.2...d s.s.3 z 3 2 U o.>.3.2. at .A s.s.s.s.s.s.",
+"s.s.s.s.s.s.y.4.3.3.2...d s.s.k l , - | ;.3.3.2. at .G s.s.s.s.s.s.",
+"s.s.s.s.s.s.e.4.3.3.2...d s.6 z 4 * # 1.3.3.3.2.$.G s.s.s.s.s.s.",
+"s.s.s.s.s.s.w.3.3.3.2.] f 5 l x + s.s.y.4.3.3.2.o.d s.s.s.s.s.s.",
+"s.s.s.s.s.s.4.3.3.3.2. at .R S D D Y ~ s.y.4.3.3.>...y s.s.s.s.s.s.",
+"s.s.s.s.s.s.2.2.3.3.2.-.` { } X.,.<.8.y.q.3.3.-.` e s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.>.3.3.3. at .W & o I #.5.w.3.3.2.] U s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.-.>.2.2.-._ @ . s.s.>.5.3.3.2.-.U f s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.] @.>.2.-.o.: s.s.s.4.w.3.2.>.o.A s.s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.L o.>.>.>.A s.s.s.w.w.3.>.o.g s.s.s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.z x b m E ] -.] / s.s.q.w.3.o.~ s.s.s.s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.4 4 6 8 V P ] ] ) s.7.8.w.3.o.Q s.s.s.s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.$ $ % = % ; t G U ^ [ *.4.3.-.] s.s.s.i.j s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.= $ s.s.s.s.s.s.-.3.3.>.>.3.r.:.! s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.> $ s.s.s.s.s.s.+.-.>.>.>.3.*.| h s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.> s.s.s.s.s.s.s.s.( $.-.-.$.R F s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.a a r s.s.s.s.s.s.s.s.s.",
+"s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.s.",
Modified: trunk/qgis/debian/qgis-plugin-grass.install
--- trunk/qgis/debian/qgis-plugin-grass.install 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/qgis-plugin-grass.install 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,4 +1,3 @@
-usr/lib/libqgisgrass.so*
usr/lib/qgis/libgrassplugin.so
usr/lib/qgis/libgrassprovider.so
usr/share/qgis/grass/*
Deleted: trunk/qgis/debian/qgis.1
--- trunk/qgis/debian/qgis.1 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/qgis.1 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,35 +0,0 @@
-.\" Hey, EMACS: -*- nroff -*-
-.\" First parameter, NAME, should be all caps
-.\" Second parameter, SECTION, should be 1-8, maybe w/ subsection
-.\" other parameters are allowed: see man(7), man(1)
-.TH QGIS 1 "Januray 6, 2004"
-.\" Please adjust this date whenever revising the manpage.
-.\" Some roff macros, for reference:
-.\" .nh disable hyphenation
-.\" .hy enable hyphenation
-.\" .ad l left justify
-.\" .ad b justify to both left and right margins
-.\" .nf disable filling
-.\" .fi enable filling
-.\" .br insert line break
-.\" .sp <n> insert n+1 empty lines
-.\" for manpage-specific macros, see man(7)
-.SH NAME
-qgis \- geographic data viewer
-.SH SYNOPSIS
-.B qgis [project-file.qgs] | [shapefile.shp] [raster-file.tif] ...
-.br
-.SH DESCRIPTION
-This manual page documents briefly the
-.B qgis
-command.
-This manual page was written for the Debian distribution
-because the original program does not have a manual page.
-.PP
-\fBqgis\fP displays shapefiles, georeferenced raster files, and digital elevation models. You can specify a QGIS project file on the command line to be displayed at startup. Or you can specify a combination of multiple shapefiles and/or raster files to be displayed at startup.
-.SH SEE ALSO
-HTML and PDF documentation in /usr/share/doc/qgis and at http://qgis.sourceforge.net/docs/
-.SH AUTHOR
-This manual page was written by Steve Halasz <debian at adkgis.org>,
-for the Debian project (but may be used by others).
Modified: trunk/qgis/debian/qgis.install
--- trunk/qgis/debian/qgis.install 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/qgis.install 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,29 +1,26 @@
-#usr/bin/gridmaker
usr/bin/qgis
usr/bin/qgis_help
+usr/share/qgis/doc/AUTHORS usr/share/qgis/doc/SPONSORS usr/share/qgis/doc/CODING usr/share/qgis/doc/favicon.ico usr/share/qgis/doc/index.html usr/share/qgis/doc/qgisdoc.css usr/share/qgis/doc/userguide.pdf usr/share/qgis/doc/images usr/share/doc/qgis
+usr/share/pixmaps/*
+usr/share/qgis/i18n/*
+usr/share/qgis/images/*
+usr/share/qgis/resources/*
+usr/share/qgis/svg/*
+usr/share/qgis/themes/*
usr/lib/qgis/libcopyrightlabelplugin.so
usr/lib/qgis/libdelimitedtextplugin.so
+usr/lib/qgis/libdelimitedtextprovider.so
usr/lib/qgis/libgeorefplugin.so
usr/lib/qgis/libgpsimporterplugin.so
usr/lib/qgis/libgpxprovider.so
usr/lib/qgis/libgridmakerplugin.so
-#usr/lib/qgis/liblauncherplugin.so
usr/lib/qgis/libnortharrowplugin.so
usr/lib/qgis/libogrprovider.so
usr/lib/qgis/libpggeoprocessingplugin.so
usr/lib/qgis/libpostgresprovider.so
+usr/lib/qgis/libquickprintplugin.so
usr/lib/qgis/libscalebarplugin.so
usr/lib/qgis/libspitplugin.so
usr/lib/qgis/libwfsplugin.so
usr/lib/qgis/libwfsprovider.so
usr/lib/qgis/libwmsprovider.so
-usr/share/qgis/doc/* usr/share/doc/qgis
-#usr/share/man/*
-usr/share/pixmaps/*
-usr/share/qgis/i18n/*
-usr/share/qgis/images/*
-/usr/share/qgis/python/*
-usr/share/qgis/resources/*
-usr/share/qgis/svg/*
-usr/share/qgis/themes/*
Modified: trunk/qgis/debian/qgis.menu
--- trunk/qgis/debian/qgis.menu 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/qgis.menu 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,3 +1,3 @@
-?package(qgis):needs="X11" section="Apps"\
- icon="/usr/share/pixmaps/qgis-icon.png" title="QGIS"\
+?package(qgis):needs="X11" section="Applications/Science/Geoscience"\
+ icon="/usr/share/pixmaps/qgis-icon.xpm" title="Quantum GIS"\
command="/usr/bin/qgis"
Deleted: trunk/qgis/debian/qgis.postinst.debhelper
--- trunk/qgis/debian/qgis.postinst.debhelper 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/qgis.postinst.debhelper 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,5 +0,0 @@
-# Automatically added by dh_installmenu
-if [ "$1" = "configure" ] && [ -x "`which update-menus 2>/dev/null`" ]; then
- update-menus
-fi
-# End automatically added section
Deleted: trunk/qgis/debian/qgis.postrm.debhelper
--- trunk/qgis/debian/qgis.postrm.debhelper 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/qgis.postrm.debhelper 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,3 +0,0 @@
-if [ -x "`which update-menus 2>/dev/null`" ]; then update-menus ; fi
Modified: trunk/qgis/debian/rules
--- trunk/qgis/debian/rules 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/debian/rules 2008-04-14 21:30:22 UTC (rev 8351)
@@ -25,20 +25,25 @@
INSTALL_PROGRAM += -s
endif
-CMakeCache.txt: CMakeLists.txt
+debian/build/CMakeCache.txt: CMakeLists.txt
dh_testdir
# Add here commands to configure the package.
uudecode -o $(CURDIR)/src/plugins/georeferencer/pencil.png $(CURDIR)/debian/pencil.uu
- cmake -D CMAKE_INSTALL_PREFIX=/usr \
+ [ -d debian/build ] || mkdir debian/build
+ [ ! -e CMakeCache.txt ] || rm CMakeCache.txt
+ cd debian/build; cmake \
+ -D CMAKE_INSTALL_PREFIX=/usr \
+ -D CMAKE_SKIP_RPATH=TRUE \
+ -D BINDINGS_GLOBAL_INSTALL=TRUE \
build: patch build-stamp
-build-stamp: CMakeCache.txt
+build-stamp: debian/build/CMakeCache.txt
dh_testdir
# Add here commands to compile the package.
- $(MAKE)
+ $(MAKE) -C debian/build
touch build-stamp
@@ -51,9 +56,8 @@
rm -rf debian/tmp
# Add here commands to clean up after the build process.
- -$(MAKE) clean
+ rm -rf debian/build
- rm -f CMakeCache.txt
rm -f $(CURDIR)/src/plugins/georeferencer/pencil.png
dh_clean
@@ -65,11 +69,11 @@
dh_installdirs
# Add here commands to install the package into debian/tmp.
- $(MAKE) install DESTDIR=$(CURDIR)/debian/tmp
+ $(MAKE) -C debian/build install DESTDIR=$(CURDIR)/debian/tmp
# Install menu pixmap
install -o root -g root -d $(CURDIR)/debian/tmp/usr/share/pixmaps
- install -o root -g root -m 644 $(CURDIR)/debian/qgis-icon.png $(CURDIR)/debian/tmp/usr/share/pixmaps/qgis-icon.png
+ install -o root -g root -m 644 $(CURDIR)/debian/qgis-icon.xpm $(CURDIR)/debian/tmp/usr/share/pixmaps/qgis-icon.xpm
# Build architecture-independent files here.
binary-indep: build install
@@ -83,11 +87,12 @@
dh_installdocs
dh_installexamples
dh_install --sourcedir=debian/tmp
+ dh_pycentral
dh_installmenu
dh_icons
dh_desktop
- dh_installman -pqgis debian/gridmaker.1
- dh_installman -plibqgis1-dev debian/qgis-config.1
+ dh_installman -pqgis qgis.man
+ dh_installman -pqgis qgis_help.man
dh_installmime -pqgis
dh_link
dh_strip
Modified: trunk/qgis/python/plugins/plugin_installer/qgis_plugins.py
--- trunk/qgis/python/plugins/plugin_installer/qgis_plugins.py 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/python/plugins/plugin_installer/qgis_plugins.py 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,4 +1,3 @@
-#!/usr/bin/env python
qgis_plugins.py
author: Matthew Perry
Modified: trunk/qgis/qgis.man
--- trunk/qgis/qgis.man 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/qgis.man 2008-04-14 21:30:22 UTC (rev 8351)
@@ -1,6 +1,6 @@
-.TH "Quantum GIS" 1 "October 2004"
+.TH QGIS 1 "April 13, 2008"
.SH NAME
-Quantum GIS \- A Geographic Information System
+qgis \- Quantum GIS Geographic Information System
.SH SYNOPSIS
.B qgis [--snapshot
.I filename]
@@ -11,6 +11,9 @@
.B " [--project"
.I projectfile]
.br
+.B " [--extent"
+.I xmin,ymin,xmax,ymax]
+.br
.B " [--help]"
.br
.B " [file]..."
Added: trunk/qgis/qgis_help.man
--- trunk/qgis/qgis_help.man (rev 0)
+++ trunk/qgis/qgis_help.man 2008-04-14 21:30:22 UTC (rev 8351)
@@ -0,0 +1,15 @@
+.TH QGIS_HELP 1 "April 13, 2008"
+.SH NAME
+qgis_help \- help viewer for qgis, the geographic data viewer
+.SH SYNOPSIS
+.B qgis_help [helpfile]
+.br
+.SH DESCRIPTION
+.B qgis_help
+is internally used by
+.B qgis
+to view help files.
+.SH SEE ALSO
+qgis(1)
+.SH AUTHOR
+This manual page was written by Jürgen Fischer <jef at norbit.de>.
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/src/core/CMakeLists.txt 2008-04-14 21:30:22 UTC (rev 8351)
@@ -112,7 +112,6 @@
renderer
symbology
spatialindex/include
- ${QT_QTSVG_INCLUDE_DIR}
${PROJ_INCLUDE_DIR}
${GEOS_INCLUDE_DIR}
${GDAL_INCLUDE_DIR}
@@ -159,6 +158,10 @@
ADD_LIBRARY(qgis_core SHARED ${QGIS_CORE_SRCS} ${QGIS_CORE_MOC_SRCS} ${INDEX_SRC})
+SET_TARGET_PROPERTIES(qgis_core PROPERTIES
+ VERSION ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}
+ SOVERSION ${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR})
# make sure to create qgssvnversion.h before compiling
ADD_DEPENDENCIES(qgis_core svnversion)
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/src/gui/CMakeLists.txt 2008-04-14 21:30:22 UTC (rev 8351)
@@ -65,6 +65,10 @@
ADD_LIBRARY(qgis_gui SHARED ${QGIS_GUI_SRCS} ${QGIS_GUI_MOC_SRCS})
+SET_TARGET_PROPERTIES(qgis_gui PROPERTIES
# make sure that UI files will be processed first
ADD_DEPENDENCIES(qgis_gui ui)
Modified: trunk/qgis/src/providers/grass/CMakeLists.txt
--- trunk/qgis/src/providers/grass/CMakeLists.txt 2008-04-14 21:02:22 UTC (rev 8350)
+++ trunk/qgis/src/providers/grass/CMakeLists.txt 2008-04-14 21:30:22 UTC (rev 8351)
@@ -32,6 +32,10 @@
ADD_LIBRARY (qgisgrass SHARED ${GRASS_LIB_SRCS})
+SET_TARGET_PROPERTIES(qgisgrass PROPERTIES
IF (WIN32)
SET_TARGET_PROPERTIES(qgisgrass PROPERTIES COMPILE_FLAGS "\"-DGRASS_EXPORT=__declspec(dllexport)\"" )
ELSE (WIN32)
