[QGIS Commit] r8352 - trunk/qgis/src/plugins/grass/modules
svn_qgis at osgeo.org
Tue Apr 15 11:41:15 EDT 2008
Author: jef
Date: 2008-04-15 11:41:15 -0400 (Tue, 15 Apr 2008)
New Revision: 8352
trunk/qgis/src/plugins/grass/modules/g.manual.qgm
trunk/qgis/src/plugins/grass/modules/g.proj.print.qgm
trunk/qgis/src/plugins/grass/modules/g.transform.qgm
trunk/qgis/src/plugins/grass/modules/i.fft.qgm
trunk/qgis/src/plugins/grass/modules/i.fusion.brovey.qgm
trunk/qgis/src/plugins/grass/modules/i.his.rgb.qgm
trunk/qgis/src/plugins/grass/modules/i.ifft.qgm
trunk/qgis/src/plugins/grass/modules/i.image.mosaic.qgm
trunk/qgis/src/plugins/grass/modules/i.oif.qgm
trunk/qgis/src/plugins/grass/modules/i.rgb.his.qgm
trunk/qgis/src/plugins/grass/modules/r.in.aster.qgm
trunk/qgis/src/plugins/grass/modules/v.db.what.connect.qgm
GRASS module label updates by Marco Pasetti, thanks a lot
Modified: trunk/qgis/src/plugins/grass/modules/g.manual.qgm
--- trunk/qgis/src/plugins/grass/modules/g.manual.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/g.manual.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,6 +1,6 @@
<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="display the HTML man pages of GRASS" module="g.manual">
+<qgisgrassmodule label="Display the HTML manual pages of GRASS" module="g.manual">
<flag key="i" answer="on" />
</qgisgrassmodule>
Modified: trunk/qgis/src/plugins/grass/modules/g.proj.print.qgm
--- trunk/qgis/src/plugins/grass/modules/g.proj.print.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/g.proj.print.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="print projection information" module="g.proj">
+<qgisgrassmodule label="Print projection information" module="g.proj">
<flag key="p" />
<flag key="d" />
<flag key="j" />
Modified: trunk/qgis/src/plugins/grass/modules/g.transform.qgm
--- trunk/qgis/src/plugins/grass/modules/g.transform.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/g.transform.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="computes a coordinate transformation based on the control points" module="g.transform">
+<qgisgrassmodule label="Computes a coordinate transformation based on the control points" module="g.transform">
<flag key="s" />
<option key="group" />
<option key="order" />
Modified: trunk/qgis/src/plugins/grass/modules/i.fft.qgm
--- trunk/qgis/src/plugins/grass/modules/i.fft.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/i.fft.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="fast fourier transform (FFT) for image processing" module="i.fft">
+<qgisgrassmodule label="Fast Fourier Transform (FFT) for image processing" module="i.fft">
<option key="input_image" />
<option key="real_image" />
<option key="imaginary_image" />
Modified: trunk/qgis/src/plugins/grass/modules/i.fusion.brovey.qgm
--- trunk/qgis/src/plugins/grass/modules/i.fusion.brovey.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/i.fusion.brovey.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="brovey transform to merge multispectral and high-res pancromatic channels" module="i.fusion.brovey">
+<qgisgrassmodule label="Brovey transform to merge multispectral and high-res pancromatic channels" module="i.fusion.brovey">
<flag key="l" />
<flag key="q" />
<flag key="s" />
Modified: trunk/qgis/src/plugins/grass/modules/i.his.rgb.qgm
--- trunk/qgis/src/plugins/grass/modules/i.his.rgb.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/i.his.rgb.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="hue-intensity-saturation (his) to red-green-blue (rgb) raster map color transform function" module="i.his.rgb">
+<qgisgrassmodule label="Hue Intensity Saturation (HIS) to Red Green Blue (RGB) raster map color transform function" module="i.his.rgb">
<option key="hue_input" />
<option key="intensity_input" />
<option key="saturation_input" />
Modified: trunk/qgis/src/plugins/grass/modules/i.ifft.qgm
--- trunk/qgis/src/plugins/grass/modules/i.ifft.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/i.ifft.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="inverse fast fourier transform for image processing" module="i.ifft">
+<qgisgrassmodule label="Inverse fast fourier transform for image processing" module="i.ifft">
<option key="output_image" />
Modified: trunk/qgis/src/plugins/grass/modules/i.image.mosaic.qgm
--- trunk/qgis/src/plugins/grass/modules/i.image.mosaic.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/i.image.mosaic.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="mosaic up to 4 images" module="i.image.mosaic">
+<qgisgrassmodule label="Mosaic up to 4 images" module="i.image.mosaic">
<option key="image1" />
<option key="image2" />
<option key="image3" />
Modified: trunk/qgis/src/plugins/grass/modules/i.oif.qgm
--- trunk/qgis/src/plugins/grass/modules/i.oif.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/i.oif.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="calculates optimal index factor table for landsat tm bands" module="i.oif">
+<qgisgrassmodule label="Calculates optimal index factor table for landsat tm bands" module="i.oif">
Modified: trunk/qgis/src/plugins/grass/modules/i.rgb.his.qgm
--- trunk/qgis/src/plugins/grass/modules/i.rgb.his.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/i.rgb.his.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="red green blue (rgb) to hue intensity saturation (his) raster map color transformation function" module="i.rgb.his">
+<qgisgrassmodule label="Red Green Blue (RGB) to Hue Intensity Saturation (HIS) raster map color transformation function" module="i.rgb.his">
<option key="red_input" />
<option key="green_input" />
<option key="blue_input" />
Modified: trunk/qgis/src/plugins/grass/modules/r.in.aster.qgm
--- trunk/qgis/src/plugins/grass/modules/r.in.aster.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/r.in.aster.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="georeferencing, rectification, and import of Terra-ASTER imagery and relative DEM's using gdalwarp" module="r.in.aster">
+<qgisgrassmodule label="Georeferencing, rectification, and import of Terra-ASTER imagery and relative DEM's using gdalwarp" module="r.in.aster">
<file key="input" type="old" />
<option key="proctype" />
<option key="band" />
Modified: trunk/qgis/src/plugins/grass/modules/v.db.what.connect.qgm
--- trunk/qgis/src/plugins/grass/modules/v.db.what.connect.qgm 2008-04-14 21:30:22 UTC (rev 8351)
+++ trunk/qgis/src/plugins/grass/modules/v.db.what.connect.qgm 2008-04-15 15:41:15 UTC (rev 8352)
@@ -1,7 +1,7 @@
-<qgisgrassmodule label="set/show database connection for a vector" module="v.db.connect">
+<qgisgrassmodule label="Set/Show database connection for a vector" module="v.db.connect">
<option key="map" layeroption="layer"/>
<flag key="p" answer="on" hidden="yes"/>
</qgisgrassmodule>
