[QGIS Commit] r8368 - branches/Release-0.10.0/i18n
svn_qgis at osgeo.org
Thu Apr 17 11:49:04 EDT 2008
Author: jef
Date: 2008-04-17 11:49:03 -0400 (Thu, 17 Apr 2008)
New Revision: 8368
branches/Release-0.10.0/i18n/qgis_de.ts
german translation update - r8366 commit to branch
Modified: branches/Release-0.10.0/i18n/qgis_de.ts
--- branches/Release-0.10.0/i18n/qgis_de.ts 2008-04-17 15:10:44 UTC (rev 8367)
+++ branches/Release-0.10.0/i18n/qgis_de.ts 2008-04-17 15:49:03 UTC (rev 8368)
@@ -101,7 +101,7 @@
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="21"/>
<source>Geoprocessing</source>
- <translation type="unfinished"></translation>
+ <translation type="unfinished">Geoverarbeitung</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="63"/>
@@ -116,12 +116,12 @@
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="118"/>
<source>Layer B:</source>
+ <translation type="unfinished">Layer B:</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="168"/>
<source>Parameter:</source>
+ <translation type="unfinished">Parameter:</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="189"/>
@@ -131,17 +131,17 @@
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="206"/>
<source>Layer A:</source>
+ <translation type="unfinished">Layer A:</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="235"/>
<source>Function:</source>
+ <translation type="unfinished">Funktion:</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="251"/>
<source>Select a function ...</source>
+ <translation type="unfinished">Funktion wählen...</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="256"/>
@@ -151,17 +151,17 @@
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="261"/>
<source>Convex Hull</source>
+ <translation type="unfinished">Konvexe Hülle</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="266"/>
<source>Difference A - B</source>
+ <translation type="unfinished">Unterschied A - B</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="271"/>
<source>Intersection</source>
+ <translation type="unfinished">Schnittfläche</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="276"/>
@@ -176,12 +176,12 @@
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="327"/>
<source>Add Layer to Map?</source>
+ <translation type="unfinished">Layer der Karte hinzufügen?</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="360"/>
<source>Save as:</source>
+ <translation type="unfinished">Speichern unter:</translation>
</message>
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="370"/>
@@ -191,7 +191,7 @@
<message>
<location filename="../python/plugins/geoprocessing/geoprocessing.ui" line="413"/>
<source>use selected Objects</source>
+ <translation type="unfinished">gewählte Objekte nutzen</translation>
</message>
</context>
<context>
@@ -335,12 +335,12 @@
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="13"/>
<source>Create new PostGIS layer</source>
+ <translation type="unfinished">Neuen PostGIS-Layer erzeugen</translation>
</message>
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="52"/>
<source>Available PostgreSQL connections</source>
+ <translation type="unfinished">Verfügbare PostGIS-Verbindungen</translation>
</message>
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="79"/>
@@ -365,12 +365,12 @@
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="128"/>
<source>New layer definition</source>
+ <translation type="unfinished">Neue Layerdefinition</translation>
</message>
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="152"/>
<source>Schema name:</source>
+ <translation type="unfinished">Schemaname</translation>
</message>
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="162"/>
@@ -383,12 +383,12 @@
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="172"/>
<source>New layer name:</source>
+ <translation type="unfinished">Neuer Layername</translation>
</message>
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="189"/>
<source>Index column:</source>
+ <translation type="unfinished">Index-Spalte:</translation>
</message>
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="199"/>
@@ -408,7 +408,7 @@
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="223"/>
<source>Geometry type:</source>
+ <translation type="unfinished">Geometrietyp</translation>
</message>
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="234"/>
@@ -428,7 +428,7 @@
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="252"/>
<source>SRID number:</source>
+ <translation type="unfinished">SRID-Nummer:</translation>
</message>
<message>
<location filename="../python/plugins/create_postgis_layer/main_gui.ui" line="295"/>
@@ -1519,7 +1519,7 @@
<message>
<location filename="../src/core/qgsmaplayer.cpp" line="433"/>
<source>File could not been opened.</source>
+ <translation type="unfinished">Datei konnte nicht geöffnet werden.</translation>
</message>
<message>
<location filename="../src/plugins/dxf2shp_converter/dxf2shpconverter.cpp" line="47"/>
@@ -1602,17 +1602,17 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="1529"/>
<source>Version </source>
- <translation>Version</translation>
+ <translation>Version </translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1536"/>
<source> with PostgreSQL support</source>
- <translation>mit PostgreSQL Unterstützung</translation>
+ <translation> mit PostgreSQL Unterstützung</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1539"/>
<source> (no PostgreSQL support)</source>
- <translation>(keine PostgreSQL Unterstützung)</translation>
+ <translation> (keine PostgreSQL Unterstützung)</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1556"/>
@@ -3089,18 +3089,18 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="600"/>
<source>Toggle full screen mode</source>
+ <translation type="unfinished">Vollbildmodus umschalten</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="601"/>
<source>Ctrl-F</source>
<comment>Toggle fullscreen mode</comment>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="602"/>
<source>Toggle fullscreen mode</source>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="732"/>
@@ -3121,7 +3121,7 @@
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1564"/>
- <source>Imrovements to digitising capabilities.</source>
+ <source>Improvements to digitising capabilities.</source>
</message>
<message>
@@ -3228,12 +3228,12 @@
<message>
<location filename="../src/app/qgsabout.cpp" line="118"/>
<source>QGIS Sponsors</source>
+ <translation type="unfinished">QGIS-Sponsoren</translation>
</message>
<message>
<location filename="../src/app/qgsabout.cpp" line="121"/>
<source>The following have sponsored QGIS by contributing money to fund development and other project costs</source>
+ <translation type="unfinished">QGIS wurde mit Geld für die Entwicklung oder andere Projektkosten unterstützt durch:</translation>
</message>
<message>
<location filename="../src/app/qgsabout.cpp" line="125"/>
@@ -3255,7 +3255,10 @@
<source>Enter the name of a web browser to use (eg. konqueror).
Enter the full path if the browser is not in your PATH.
You can change this option later by selection Options from the Settings menu (Help Browser tab).</source>
+ <translation type="unfinished">Bitte für den zu benutzenden Webbrowser (z.B. Konqueror) eingeben.
+Falls der Browser nicht in Ihrem PATH ist, müssen Sie den vollen Pfadnamen angeben.
+Sie können die Einstellung später in den Optionen aus dem Einstellungen-Menü ändern.
+</translation>
</message>
</context>
<context>
@@ -3708,14 +3711,14 @@
<message>
<location filename="../src/app/qgsattributetabledisplay.cpp" line="201"/>
<source>Could not commit changes - changes are still pending</source>
+ <translation type="unfinished">Konnten Änderungen nicht commiten - Die Änderungen wurden noch nicht durchgeführt.</translation>
</message>
<message numerus="yes">
<location filename="../src/app/qgsattributetabledisplay.cpp" line="376"/>
<source>Found %d matching features.</source>
- <numerusform></numerusform>
+ <numerusform>%d passende Objekte gefunden</numerusform>
</translation>
</message>
</context>
@@ -5066,7 +5069,7 @@
<message>
<location filename="../src/app/qgsdbsourceselect.cpp" line="543"/>
<source>Accessible tables could not be determined</source>
+ <translation type="unfinished">Zugreifbare Tabellen konnten nicht festgestellt werden</translation>
</message>
<message>
<location filename="../src/app/qgsdbsourceselect.cpp" line="545"/>
@@ -5075,12 +5078,16 @@
The error message from the database was:
%1
</source>
+ <translation type="unfinished">Die Datenbankverbindung war erfolgreich, jedoch konnten die zugänglichen Tabelle nicht bestimmt werden.
+Die Fehlermeldung der Datenbank war:
+%1
+</translation>
</message>
<message>
<location filename="../src/app/qgsdbsourceselect.cpp" line="550"/>
<source>No accessible tables found</source>
+ <translation type="unfinished">Keine zugänglichen Tabellen gefunden</translation>
</message>
<message>
<location filename="../src/app/qgsdbsourceselect.cpp" line="554"/>
@@ -5088,7 +5095,10 @@
Please verify that you have SELECT privilege on a table carrying PostGIS
geometry.</source>
+ <translation type="unfinished">Die Datenbankverbindung war erfolgreich, jedoch wurden keine zugänglichen Tabellen gefunden.
+Bitte stellen Sie sicher, dass Sie das SELECT-Privileg für eine Tabelle
+mit PostGIS-Geometrie haben.</translation>
</message>
</context>
<context>
@@ -8958,8 +8968,10 @@
<source>Network timed out after %1 seconds of inactivity.
This may be a problem in your network connection or at the WMS server.</source>
+ <numerusform>Netzwerk-Timeout nach %1 Sekunden ohne Aktivität.
+Dies könnte auf ein Problem mit Netzwerkverbindung oder WMS-Server hindeuten.</numerusform>
</translation>
</message>
</context>
@@ -9752,8 +9764,8 @@
<source>- %1 features found</source>
<comment>Identify results window title</comment>
+ <numerusform>%1 Objekte gefunden</numerusform>
</translation>
</message>
</context>
@@ -11033,12 +11045,12 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="492"/>
<source>Zoom to mouse cursor</source>
+ <translation type="unfinished">Zur Mouseposition zoomen</translation>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="709"/>
<source>Default Snap Mode:</source>
+ <translation type="unfinished">Voreingestellter Fang-Modus</translation>
</message>
</context>
<context>
@@ -11198,7 +11210,7 @@
<message>
<location filename="../src/plugins/geoprocessing/qgspggeoprocessing.cpp" line="80"/>
<source>Create a buffer for a PostgreSQL layer. </source>
+ <translation type="unfinished">Puffer für einen PostGIS-Layer erzeugen</translation>
</message>
</context>
<context>
@@ -12006,47 +12018,47 @@
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="133"/>
<source>Unable to determine table access privileges for the </source>
+ <translation type="unfinished">Konnte Tabellenzugriffrechte für die Tabelle </translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1867"/>
<source>Error while adding features</source>
+ <translation type="unfinished">Fehler beim Hinzufügen von Objekten</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1901"/>
<source>Error while deleting features</source>
+ <translation type="unfinished">Fehler beim Löschen von Objekten</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1933"/>
<source>Error while adding attributes</source>
+ <translation type="unfinished">Fehler beim Hinzufügen von Attributen</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1972"/>
<source>Error while deleting attributes</source>
+ <translation type="unfinished">Fehler beim Löschen von Attributen</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2036"/>
<source>Error while changing attributes</source>
+ <translation type="unfinished">Fehler beim Ändern von Attributen</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2115"/>
<source>Error while changing geometry values</source>
+ <translation type="unfinished">Fehler beim Ändern von Geometrien</translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2538"/>
<source>Qgis was unable to determine the type and srid of column </source>
+ <translation type="unfinished">QGIS konnte Typ und SRID der Spalte </translation>
</message>
<message>
<location filename="../src/providers/postgres/qgspostgresprovider.h" line="497"/>
<source>unexpected PostgreSQL error</source>
+ <translation type="unfinished">Nicht erwarteter PostgeSQL-Fehler</translation>
</message>
</context>
<context>
@@ -13619,8 +13631,8 @@
<location filename="../src/app/qgssearchquerybuilder.cpp" line="167"/>
</translation>
</message>
</context>
@@ -13695,8 +13707,8 @@
<location filename="../src/app/qgsserversourceselect.cpp" line="588"/>
<source>Coordinate Reference System (%1 available)</source>
+ <numerusform>Koordinatensystem (%1 verfügbar)</numerusform>
</translation>
</message>
</context>
@@ -14379,7 +14391,7 @@
<message>
<location filename="../src/plugins/spit/qgsspit.cpp" line="830"/>
<source>%1 of %2 shapefiles could not be imported.</source>
+ <translation type="unfinished">%1 von %2 Shape-Dateien konnte nicht importiert werden.</translation>
</message>
</context>
<context>
@@ -14502,22 +14514,22 @@
<message>
<location filename="../src/plugins/spit/qgsspitbase.ui" line="131"/>
<source>Import options and shapefile list</source>
+ <translation type="unfinished">Importoptionen und Shape-Dateiliste</translation>
</message>
<message>
<location filename="../src/plugins/spit/qgsspitbase.ui" line="214"/>
<source>Use Default SRID or specify here</source>
+ <translation type="unfinished">Eingestellte SRID nutzen</translation>
</message>
<message>
<location filename="../src/plugins/spit/qgsspitbase.ui" line="227"/>
<source>Use Default Geometry Column Name or specify here</source>
+ <translation type="unfinished">Eingestellten Spaltennamen nutzen</translation>
</message>
<message>
<location filename="../src/plugins/spit/qgsspitbase.ui" line="250"/>
<source>Primary Key Column Name</source>
+ <translation type="unfinished">Primärschlüsselspalte</translation>
</message>
</context>
<context>
@@ -15421,7 +15433,7 @@
<message>
<location filename="../src/plugins/quick_print/quickprintguibase.ui" line="93"/>
<source>Page Size</source>
+ <translation type="unfinished">Seitengröße</translation>
</message>
</context>
<context>
