[QGIS Commit] r8369 - branches/Release-0.10.0/debian
svn_qgis at osgeo.org
Thu Apr 17 19:14:56 EDT 2008
Author: jef
Date: 2008-04-17 19:14:56 -0400 (Thu, 17 Apr 2008)
New Revision: 8369
Added:
branches/Release-0.10.0/debian/libqgis-core0.10.install
branches/Release-0.10.0/debian/libqgis-gui0.10.install
branches/Release-0.10.0/debian/libqgisgrass0.10.install
Removed:
branches/Release-0.10.0/debian/libqgis-core0.9.install
branches/Release-0.10.0/debian/libqgis-gui0.9.install
branches/Release-0.10.0/debian/libqgisgrass0.9.install
branches/Release-0.10.0/debian/python-qgis.install
branches/Release-0.10.0/debian/changelog
branches/Release-0.10.0/debian/control
branches/Release-0.10.0/debian/qgis.install
update of debian build
Modified: branches/Release-0.10.0/debian/changelog
--- branches/Release-0.10.0/debian/changelog 2008-04-17 15:49:03 UTC (rev 8368)
+++ branches/Release-0.10.0/debian/changelog 2008-04-17 23:14:56 UTC (rev 8369)
@@ -1,8 +1,35 @@
-qgis (0.9.2test2) unstable; urgency=low
+qgis (0.10.0) unstable; urgency=low
- * fixed various packaging bugs
+ * This release includes over 120 bug fixes and enchancements
+ * over the QGIS 0.9.1 release. In addition we have added
+ * the following new features:
+ * Improvements to digitising capabilities.
+ * Supporting default and defined styles (.qml) files for file based
+ * vector layers. With styles you can save the symbolisation
+ * and other settings associated with a vector layer and they
+ * will be loaded whenever you load that layer.
+ * Improved support for transparency and contrast stretching
+ * in raster layers. Support for color ramps in raster layers.
+ * Support for non-north up rasters. Many other raster
+ * improvements 'under the hood'.
+ * Updated icons for improved visual consistancy.
+ * Support for migration of old projects to work in newer QGIS versions.
- -- Jürgen E. Fischer <jef at norbit.de> Sun, 13 Apr 2008 03:51:14 +0200
+ -- Jürgen E. Fischer <jef at norbit.de> Fri, 18 Apr 2008 00:51:58 +0200
qgis (0.9.2test1) gutsy; urgency=low
Modified: branches/Release-0.10.0/debian/control
--- branches/Release-0.10.0/debian/control 2008-04-17 15:49:03 UTC (rev 8368)
+++ branches/Release-0.10.0/debian/control 2008-04-17 23:14:56 UTC (rev 8369)
@@ -14,7 +14,7 @@
Package: qgis
Architecture: any
-Depends: ${shlibs:Depends}, ${misc:Depends}, libqgis-core0.9, libqgis-gui0.9
+Depends: ${shlibs:Depends}, ${misc:Depends}, libqgis-core0.10, libqgis-gui0.10
Suggests: qgis-plugin-grass, python-qgis
XB-Python-Version: ${python:Versions}
Description: Geographic Information System (GIS)
@@ -29,7 +29,7 @@
Elevation Model (DEM) formats including
GeoTIFF, Arc/Info ASCII Grid, and USGS ASCII DEM.
-Package: libqgis-core0.9
+Package: libqgis-core0.10
Architecture: any
Replaces: qgis (<=0.9.2rc1)
@@ -42,7 +42,7 @@
This package contains the shared core library that
provides an interface for plugins.
-Package: libqgis-gui0.9
+Package: libqgis-gui0.10
Architecture: any
@@ -55,20 +55,6 @@
This package contains the shared gui library that
-Package: python-qgis
-Architecture: any
-Section: python
-Depends: ${shlibs:Depends}, ${misc:Depends}, ${python:Depends}, libqgis-core0.9, libqgis-gui0.9
-Provides: ${python:Provides}
-XB-Python-Version: ${python:Versions}
-Description: QGIS Geographic Information System - Python bindings and plugins
- QGIS is a Geographic Information System (GIS)
- which manages, analyzes and display databases of
- geographic information.
- This package contains the Python bindings and
- plugins.
Package: libqgis1-dev
Architecture: any
Section: libdevel
@@ -87,12 +73,12 @@
Package: qgis-plugin-grass
Architecture: any
-Depends: qgis (= ${binary:Version}), ${shlibs:Depends}, ${misc:Depends}, libgdal1-1.4.0-grass | libgdal1-1.3.2-grass, libqgisgrass0.9
+Depends: qgis (= ${binary:Version}), ${shlibs:Depends}, ${misc:Depends}, libgdal1-1.4.0-grass | libgdal1-1.3.2-grass, libqgisgrass0.10
Description: Plugin for accessing GRASS data from QGIS
This plugin enables a GRASS data access toolbox in the QGIS
geographic data viewer.
-Package: libqgisgrass0.9
+Package: libqgisgrass0.10
Architecture: any
Description: QGIS Geographic Information System - shared grass library
Copied: branches/Release-0.10.0/debian/libqgis-core0.10.install (from rev 8367, branches/Release-0.10.0/debian/libqgis-core0.9.install)
--- branches/Release-0.10.0/debian/libqgis-core0.10.install (rev 0)
+++ branches/Release-0.10.0/debian/libqgis-core0.10.install 2008-04-17 23:14:56 UTC (rev 8369)
@@ -0,0 +1 @@
+usr/lib/libqgis_core.so.*
Deleted: branches/Release-0.10.0/debian/libqgis-core0.9.install
--- branches/Release-0.10.0/debian/libqgis-core0.9.install 2008-04-17 15:49:03 UTC (rev 8368)
+++ branches/Release-0.10.0/debian/libqgis-core0.9.install 2008-04-17 23:14:56 UTC (rev 8369)
@@ -1 +0,0 @@
-usr/lib/libqgis_core.so.*
Copied: branches/Release-0.10.0/debian/libqgis-gui0.10.install (from rev 8367, branches/Release-0.10.0/debian/libqgis-gui0.9.install)
--- branches/Release-0.10.0/debian/libqgis-gui0.10.install (rev 0)
+++ branches/Release-0.10.0/debian/libqgis-gui0.10.install 2008-04-17 23:14:56 UTC (rev 8369)
@@ -0,0 +1 @@
+usr/lib/libqgis_gui.so.*
Deleted: branches/Release-0.10.0/debian/libqgis-gui0.9.install
--- branches/Release-0.10.0/debian/libqgis-gui0.9.install 2008-04-17 15:49:03 UTC (rev 8368)
+++ branches/Release-0.10.0/debian/libqgis-gui0.9.install 2008-04-17 23:14:56 UTC (rev 8369)
@@ -1 +0,0 @@
-usr/lib/libqgis_gui.so.*
Copied: branches/Release-0.10.0/debian/libqgisgrass0.10.install (from rev 8367, branches/Release-0.10.0/debian/libqgisgrass0.9.install)
--- branches/Release-0.10.0/debian/libqgisgrass0.10.install (rev 0)
+++ branches/Release-0.10.0/debian/libqgisgrass0.10.install 2008-04-17 23:14:56 UTC (rev 8369)
@@ -0,0 +1 @@
+usr/lib/libqgisgrass.so.*
Deleted: branches/Release-0.10.0/debian/libqgisgrass0.9.install
--- branches/Release-0.10.0/debian/libqgisgrass0.9.install 2008-04-17 15:49:03 UTC (rev 8368)
+++ branches/Release-0.10.0/debian/libqgisgrass0.9.install 2008-04-17 23:14:56 UTC (rev 8369)
@@ -1 +0,0 @@
-usr/lib/libqgisgrass.so.*
Deleted: branches/Release-0.10.0/debian/python-qgis.install
--- branches/Release-0.10.0/debian/python-qgis.install 2008-04-17 15:49:03 UTC (rev 8368)
+++ branches/Release-0.10.0/debian/python-qgis.install 2008-04-17 23:14:56 UTC (rev 8369)
@@ -1,4 +0,0 @@
-usr/share/qgis/python/*
-usr/lib/python*/site-packages/qgis/__init__.py
-usr/lib/python*/site-packages/qgis/qgisconfig.py
-usr/lib/python*/site-packages/qgis/*.so
Modified: branches/Release-0.10.0/debian/qgis.install
--- branches/Release-0.10.0/debian/qgis.install 2008-04-17 15:49:03 UTC (rev 8368)
+++ branches/Release-0.10.0/debian/qgis.install 2008-04-17 23:14:56 UTC (rev 8369)
@@ -24,3 +24,7 @@
usr/lib/qgis/libwfsplugin.so
usr/lib/qgis/libwfsprovider.so
usr/lib/qgis/libwmsprovider.so
+usr/share/qgis/python/*
+usr/lib/python*/site-packages/qgis/__init__.py
+usr/lib/python*/site-packages/qgis/qgisconfig.py
+usr/lib/python*/site-packages/qgis/*.so
